Question about Tricity Bendix TM310W Electric Dryer
Dryer tripping electrics out
Hi,tumble dryer is tripping the electrics out.have changed the plug and fuse and still the same thimg happens.took the top off and can see no signs og burning or loose wires.checked the connecting block at the back of the machine and also tried it in diffrent sockets can anyone plesa prevent us from haveing to buy a new machine please. many thanks
Can you tell mewhere is the coil foundin the tricity bendix dryers ?
Posted on Oct 19, 2008
  • 883 Answers
Try gaining access to look at the heating coil. Many times, a coil will either bend over time from repeated heat/cool cycles or simply break and one part of the coil may be touching the metal dryer chassis. I have repaired these by either replacing the coil or repairing (if broken coil wire) it by taking the broken ends and twisting them back together. Make sure no part of it touches metal. Also inspect for breakage the insulators that hold the coil.
Posted on Aug 09, 2007
MY OLD GE ELECTRIC DRYER TURNS ON BUT WILL NOT HEAT
Make sure you check these to fix the problem.
  • Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
  • Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
  • A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Thank you
Aug 02, 2010 | GE Profile Harmony DPGT750EC Electric...
Dryer won't heat up during dry cycle
Thank you
Jun 09, 2010 | GE DBSR453EBWW Electric Dryer
LG DLG2532 dryer not heating up, lint trap clean, good air flow out exhasut vent, all controls seam to be working i.e. lights on buttons and chimes good, seams like its not getting gas but valve is turned...
Hi, Make sure you check these to fix the problem.
Apr 16, 2010 | LG DLE2532W Electric Dryer
Hotpoint tcl770 condencer tumble dryer, just out of warantee. when turn on and start it keeps tripping the electrics. changed plug fuse etc, tried in various sockets but keeps tripping the system???
internal problem, either heater coil or sensor or motor, you will need to get it checked, but don't plug it in again, as short circuits on high current machines can be dangerous.
Jan 14, 2010 | Hotpoint Dryers
My Kenmore electric dryer model# 64652400 is not heating.
Hi
If your dryer doesn't heat, check these:
Fuses Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Please revert for further assistance and Do rate the solution as FixYa if found useful.
Thanks
Rylee
Mar 16, 2009 | Kenmore 64652 Electric Dryer
Frigidaire dryer will not heat  runs/tumbles sometimes the heat works & sometimes it doesn't Mdl No. CRGR7900AS2
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Heating element
Thermal fuse
Wiring
Dec 19, 2008 | Frigidaire GLER642A Electric Dryer
Dryer trips the fuse box
Hi.
Try running it with the heater disconnected. if it goes o/k then your heater needs replacing
Nov 22, 2008 | Zanussi TC180W Electric Portable Dryer
Drum Turns, but dryer won't heat up.
If the dryer does not heat at all then is either a problem with the heating elemet , or with the thermal fuse.
See the following suggestions from Repairclinic:
There's no heat If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Oct 04, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Kenmore Dryer model # 60202990.... no heat
Heating element
Thermal fuse
Wiring
Sep 13, 2008 | Kenmore 62872 Electric Dryer
TUMBLE DRYER
Allybo check how the power cord is wired to the dryer. I have seen where the hot wire has been attached to the ground of the dryer and this will create a short which will trip the breaker.
Jan 28, 2008 | Dryers
Tricity Bendix TM310W Electric Dryer Logo
132 people viewed this question
Top Tricity Bendix Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
