Question about Pioneer FH-P404
Setting the time and date.
Hi, I would like some help on setting the time and date, a simple guide on how too, would be very handy, I change my radio to a new car and I lost the manual, please can someone help me out.
    President:
  • 1,114 Answers
This is for the closest model I could find, hope it helps!
Posted on Aug 09, 2007
SOURCE:
How doI set the clock
Setting the Time (Without Date Display) If your vehicle has an AM/FM base radio with a single CD player and preset buttons numbered one through six, the radio will have a clock button for setting the time. You can set the time by following these steps: 1. Press the clock button until the hour numbers begin flashing on the display. Press the clock button a second time and the minute numbers will begin flashing on the display. 2. While either the hour or the minute numbers are flashing, turn the tune knob, located on the upper right side of the radio, clockwise or counterclockwise to increase or decrease the time. Instead of using the tune knob, you can also press the SEEK, FWD (forward), or REV (reverse) buttons to adjust the time. 3. Press the clock button again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing will stop after five seconds and the current time displayed will be automatically set. To change the time default setting from 12 hour to 24 hour, press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H are displayed, press the pushbutton located under the desired option to select the default. Press the clock button again to apply the selected default, or let the screen time out. Setting the Time (With Date Display) If your vehicle has a radio with a single CD player or a CD with DVD player, the radio will have a clock button for setting the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the clock button and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) will appear on the display. 220 3. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. If your vehicle has a radio with a six-disc CD player, the radio will have a MENU button instead of the clock button to set the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the MENU button. Once the clock option is displayed. 3. Press the pushbutton located under that label. The HR, MIN, MM, DD, YYYY will appear on the display. 4. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the MENU button and then the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. 221 To change the time default setting from 12 hour to 24 hour or to change the date default setting from month/day/year to day/month/year, follow these instructions: 1. Press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H, and the date MM/DD/YYYY (month, day, and year) and DD/MM/YYYY (day, month, and year) are displayed. 2. Press the pushbutton located under the desired option. 3. Press the clock or MENU button again to apply the selected default, or let the screen time out
Nov 10, 2016 | 2007 Pontiac Torrent
I would like to know which buttons to push on my 2008 Chevy cobalts clock to set the time
AM/FM Base Radio with a Single CD Player
This type of radio has a button for setting the time. You can set the time by following these steps:
Turn the ignition key to ACC/ACCESSORY or ON/RUN. Press the knob, located in the center of the radio, to turn the radio on.
Press the button until the hour begins flashing on the display. Press the button a second time and the minute begins flashing on the display.
While either the hour or the minute numbers are flashing, turn the knob, located on the upper right side of the radio, clockwise or counterclockwise to increase or decrease the time.
Press the button again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing stops after five seconds and the current time displayed is automatically set.
To change the time default setting from 12 hour to 24 hour, press the button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H are displayed, press the pushbutton located under the desired option to select the default. Press the button again to apply the selected default, or let the screen time out.
With Date Display
Single CD (MP3) Player
This type of radio has a button for setting the time and date.
Press the button and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) displays.
Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, increases by one.
• Another way to increase the time or date, is to press the right SEEK arrow or FWD button.
• To decrease the time or date, press the left SEEK arrow or REV button, or turn the knob, located on the upper right side of the radio.
The date does not automatically display. To see the date press the button while the radio is on. The date with display times out after a few seconds and goes back to the normal radio and time display.
Hope this helps ! hope you had a very Merry Christmas an have Happy New Year
Dec 27, 2014 | 2008 Chevrolet Cobalt
Manual download
Here's a link to the manual for your clock: http://timexaudio.com/media/uploads/product/files/T307_IB56281_07.pdf
Dual alarm settings are on page 8, and I've included the specific instructions below. I would think that the '5' setting would be for Mon. - Fri., but let me know if that's not correct. Hope this helps!
"After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week (7), weekdays only (5), or the weekend (2). Before setting the alarm, be sure that the correct date is set, as shown in the "Auto-Set" and Manual Time and Date Settings section of the manual. While the display is still flashing, press the Date/7-5-2 Button until the desired setting is shown."
Dec 17, 2013 | Timex (T307S) Clock Radio
Date and time appears scanner doesn't scan
Hi June,
Has the radio scanner been programmed with frequencies?
If not, that is the answer to your query.
All radio scanners need input to function as they should, no input, FREQUENCIES, no go.
If you have the user manual handy, it will guide you through the steps required to program frequencies into your scanner.
If you don't have the manual, then going to your local Radioshack store would be of benefit to obtain a copy.
You will also need a hard copy of frequency listings for your location.
these can be found by a simple google search.
I hope this has been useful to you.
Cheers,
Peter
Feb 26, 2013 | Uniden BC370CRS Base Scanner
How to set the date
Time and date setting
are only necessary if automatic setting by radio broadcast is unsuccessful.
To set time, date, and options:
1) With time and day showing, press and hold SET.
2) City code flashes. Press START/STOP to select city that represents your time zone. See table below
for city codes.
3) Press MODE. DST (daylight savings time) setting flashes. Press START/STOP to select AUTO (obey
setting in radio signal), ON, or OFF (disregarding setting in radio signal for ON/OFF).
4) Press MODE. Hour flashes. Press START/STOP to change hour (including AM/PM); hold button to
scan values
5) Press MODE. Minutes flash. Press START/STOP to change minutes
6) Press MODE. Seconds flash. Press START/STOP to set seconds to zero.
7) Press MODE. Year flashes. Press START/STOP to change year.
8) Press MODE. Month flashes. Press START/STOP to change month.
9) Press MODE. Day flashes. Press START/STOP to change day.
10) Press MODE. Date flashes. Press START/STOP to select M-D (month-day) or D-M (day-month) format.
11) Press MODE. Hourly chime setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch chimes on every hour.
12) Press MODE. Button beep setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch beeps for every button press.
13) Press SET, at any step, when done setting.
Press and hold MODE to switch between 12- and 24-hour time format.
Press SET to view date. Year is at top of display and date is below.
Press RECEIVE to view current city.
Press and hold RECEIVE to begin manual reception of time signal, as described in ATOMIC CLOCK
SYNCHRONIZATION section.
(from the User's manual)
May 03, 2011 | Timex 1440 Prizefighter 53032 Sports...
Please send me a simple way to set the clokc to the current time. It is an hour behind. Also how to play the radio and sleep sounds. I lost the manual and I am not electrocially inclined. So please make...
Hello
To set time manually do the following.
1. To change your time setting, press and hold the J Time Set Button so that the clock display begins flashing.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, shown by the PM Indicator.
3. After setting the time, press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the setting
to lock into place.
4. To change the calendar, press and hold the 9 Date/7-5-2 Button until the display shows the flashing year.
5. Press the 1 Reverse and 6 Forward Buttons to set the current year. When you have selected the year, press the
4 Enter Button, then use the 1 Reverse and 6 Forward Buttons to set the month/day.
6. After you have set the date, press the 4 Enter Button or wait for the display to beep twice and lock into place.
AUTO TIME SET ZONES
Z-01 Atlantic Standard Time
Z-02 Eastern Standard Time
Z-03 Central Standard Time
Z-04 Mountain Standard Time
Z-05 Pacific Standard Time
Z-06 Alaskan Standard Time
Z-07 Hawaiian Standard Time
3. Find your time zone, then press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the
setting to lock into place.
Apr 04, 2011 | Timex (T307S) Clock Radio
How do you change the clock on a 2009 Chevy cobalt.
Setting the Clock Without Date Display AM/FM Base Radio with a Single CD Player
To set the time:
  1. Turn the ignition key to ACC/ACCESSORY or ON/RUN. Press to turn the radio on.
  2. Press until the hour begins flashing on the display. Press a second time and the minute begins flashing on the display.
  3. While either the hour or the minute numbers are flashing, turn to increase or decrease the time.
  4. Press again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing stops after five seconds and the current time displayed is automatically set.
To change the time default setting from 12 hour to 24 hour, press the button until 12H or 24H is displayed. Once 12H or 24H is displayed, turn the knob to the desired option to select the setting. Press the button again to apply the setting, or let the screen time out.
With Date Display Radio with CD (MP3) and USB Port, and Radio with Single CD (MP3) Player
To set the time and date:
  2. Press and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) displays.
  3. Press the softkey located below any one of the tabs that you want to change.
  4. To increase the time or date do one of the following: • Press the softkey located below the selected tab. • Press SEEK, or FWD. • Turn clockwise.
  5. To decrease the time or date do one of the following: • Press SEEK or REV. • Turn counterclockwise.
The date does not automatically display. To see the date press while the radio is on. The date with display times out after a few seconds and goes back to the normal radio and time display.
To change the time default setting from 12 hour to 24 hour or to change the date default setting from month/day/year to day/month/year:
  1. Press and then the softkey located below the forward arrow label. Once the time 12H and 24H, and the date MM/DD/YYYY (month, day, and year) and DD/MM/YYYY (day, month, and year) displays.
  2. Press the softkey located below the desired option.
  3. Press again to apply the selected default, or let the screen time out.
Nov 21, 2010 | 2009 Chevrolet Cobalt
How do I change the date from "Jan 20 00" to the proper date?
To change te date on the OfficeJet J4580 us the following steps.
1. press the setup button (that looks like a wrench).
2. press the right arrow key until you find Basic Setting then press OK.
3. In the Basic setting menu press the right arrow key until you find Date and Time then press OK.
4. Enter the date with the keypad (DD-MM-YY) then press OK.
5. Enter the time with the keypad (HH-MM), use the right arrow key to change between AM or PM then press OK.
These simple steps should help adjust your time settings
Jun 16, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do I change the radio station on the radio alarm
Here is the full manual
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Here are the instructions from the manual.
Setting the Radio Alarm
1. Press and hold the
Radio Alarm Button. The display will flash and the Radio Alarm Indicator will
appear. If you do not begin setting the time within ten seconds of pressing the button, the display will stop
flashing and you will need to press the
Radio Alarm Button again.
2. While the display flashes, press the Reverse and  Forward Buttons to set the wake time. Hold a button
for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, you will need to select the station. First, press the  Radio Band Button
to select a radio frequency. Next, select a station using the Memory Set 1-6 Buttons. For more
information on programming radio stations into memory, see the Programming Radio Station Settings section
of this manual. Rotate the  Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting
lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that
the correct date is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the  Enter Button. The
Radio Alarm Indicator will appear on the display, showing that the radio alarm has been set.
Aug 08, 2009 | Timex T311T Clock Radio
Clock radio, small
This little guy has the most complicated date setting procedure I have ever seen! From the manual: "Manual Time and Date Settings 1. To change your time setting, press and hold the J Time Set Button so that the clock display begins flashing. 2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the time. Hold a button for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, shown by the PM Indicator. 3. After setting the time, press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the setting to lock into place. 4. To change the calendar, press and hold the 9 Date/7-5-2 Button until the display shows the flashing year. 5. Press the 1 Reverse and 6 Forward Buttons to set the current year. When you have selected the year, press the 4 Enter Button, then use the 1 Reverse and 6 Forward Buttons to set the month/day. 6. After you have set the date, press the 4 Enter Button or wait for the display to beep twice and lock into place." You can download the manual from the link below: http://www.timexaudio.com/pdf/T307_IB56281_07.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 24, 2007 | Timex (T307S) Clock Radio
Pioneer FH-P404 Logo
220 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
