Question about Canon Fax L700, L720, L760, L770, L780, L790, L3300
Canon Fax L700 Manual
Check printer message
Ajkill
  • 2035 Answers
SOURCE: Canon Fax-L700
This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located ...........................
Good luck....
Posted on Sep 20, 2008
SOURCE: Hi my fax displays the message CHECK 5100
my fax Canon JX201 displays the message CHECK 5100
Posted on Sep 14, 2009
SOURCE: Fax canon B120, Error code :##342, Error Message: "Check Printer"
15bdaa2.jpg Fax Canon B120
Posted on Jul 26, 2010
F Victor man
  • 817 Answers
SOURCE: canon Fax-L350 display check printer Alarm red "could
Open the main cover. Look into the body of the machine. The covers top left corner has a projection that when the lid is closed this projection passes through a hole in the main body and hits a micro switch to say the cover is closed. the switch has stuck. Poke a thin screwdriver (power off of course) and watch the switch pop back into its right position. All will be well. A well known fault of this model.
Posted on May 03, 2011
lbrown1806
  • 488 Answers
SOURCE: Please send me fax manual for Canon-JX200. message
Please send me an email to LBrown18062@hotmail.com and I will send you the manual right away. Please put CANON FAX JX200 in the subject line and I will send you the manual right away. Lawrence Brown
Posted on Oct 25, 2011
Memory if full message on Canon L190
I am sure a 'Memory Reset' would fix this.
As to 'how', I can only suggest you check out the precise way to do this in your CD manual.
Dec 18, 2013 | Canon Lasers FAXPHONE L190 Wireless...
Oct 24, 2011 | Canon FAX-JX200
WANT TO ATTACH A MESSAGE MACHINE
The message machine needs to be set to answer 1 ring before the fax is set to answer. When the phone rings the fax starts listening even when the answer machine picks up. If the fax hears fax tones it will receive the fax and if no tones the answer machine will take a message.
Jan 22, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Trying to fax it reads turn reg sw off. How do I
Not certain but if its the same as the L700 fax it will be a small switch that is on the right side of the keypad that will have to be flicked with the tip of a pen.
Nov 23, 2009 | Canon imageCLASS 2200 Black and White...
Canon L220 Fax ##323 Check Printer
Canon manual says ##323 is the laser beam detector defective. Try to substitute the laser assembly (RG5-3497)
Dec 22, 2008 | Canon L220 Plain Paper Laser Fax
Won't print an incoming fax; displays error message 004
I think the error is point to a fuser (temp issue) problem.
You can check out this thread for some more info that might be helpful. - LINK
Nov 11, 2008 | Canon LaserCLASS Fax 710 Printer
"DARK PAPER USED" Message
I found a copy of the manual, and on page 202 the "Dark Paper Used" message can be caused by three things:
1. Paper used is colored or stained -- replace with clean white paper.
2. Paper was pulled from machine before the fax was ejected completely.
3. The received document support is not installed correctly. Page 3 in the manual shows this support as the rear-most, and it looks like it should be installed with the upright portion angling toward the rear at about a 30 degree angle.
Sep 02, 2008 | Canon FAX-B160 Plain Paper Bubblejet
Canon Fax L700, L720, L760, L770, L780, L790, L3300 Logo
37 people viewed this question
old marine
old marine
