Question about Dishwashers
Heller aller 190a hand pump won't pump water up from 42 feet
It won't pump up water.I put on a foot valve and it has a built in foot valve .Could the extra foot valve be the problem?
robotek
  • 1512 Answers
SOURCE: foot control
Hi ande09
What make of sewing machine is it? Didnt find any sources using just the part number for the controller. Post back to me and I will find a source for you.
regards
robotek
Posted on May 07, 2008
Maytag317
  • 1136 Answers
SOURCE: Why extra water line INSIDE my refrigerator
Hi, If you are talking about the tubing behind the crisper drawer, it is there to hold water for the dispenser in the door. The old design was a canister to hold water. Now it is tubing. I hope this helps you.
Vic
Posted on Jul 18, 2009
heatman101
  • 43501 Answers
SOURCE: The machine won't pump water
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Jul 08, 2011
EsWorld
  • 1618 Answers
SOURCE: Pump won't come on, it has power to it, also the
The water from the relief valve means the boiler is very full, lets work on the water problem first then we will go to the pump.
IF the machine is not turned on does water flow out of the relief valve? ...if yes then check the manual fill to make sure it is in the off position. If no then we will need to check the level probe and or the inlet solenoid, because something is telling the machine it needs water.
For the pump is there any sound from it when you press the brew button? ....If yes then it might be blocked and you will have to remove the ring collar from the brass head, to remove pump from motor then check to see if pump head rotates, note direction on front of pump head. If no then you might have lost a fuse or there is a loose connection at the main box.
Posted on Jul 20, 2011
  • 2559 Answers
SOURCE: we have a blazemaster pump put new impellar kit in it but it still wont pump any water. have replaced all o rings and new suction pipe and foot valve there are no cracks in the casing.
Need to prime the pump. In order to overcome the air in the system you need to fill the pump with water. Check your owners manual on how to prime it.
Posted on Oct 15, 2016
I have a utilitech 1 hr convertible jet pump. My well is 58 feet. My foot valve is at 68 feet. My pump is primed. But it still won't pump water. And it us set up for deep well. Any suggestions?
I think you mean your well is 68 feet and your foot valve is at 58 feet. To properly prime a deep well jet system you must completely fill not only the pump but the entire casing also. This should take about 5 gallons of water. If you are not using anywhere near that much water to prime it may be the well casing is air locked which means the air in the well has no place to go and won't allow water in if there is a plug on top of the well adapter remove it and then try to prime system. Another method is to run the pump while priming to help break the airlock. Hope this helps.
Bob
Jul 26, 2015 | Jet Plumbing
Mastercraft 6.5 Gal.3/4 hp does not hold pressure
no it is not normal
if it is like a round tank and you use air pressure to set the operation then to have water there indicates that the diaphragm that separates the water and air has failed
nothing to with the foot valve but a non return valve at that tank or lack or set pressure
Apr 09, 2017 | Air Tools & Compressors
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
Had to replace shallow well pump. Bought jet pump (used to have centrifugal pump), and installed it. Had to replace inline check valve, losing well prime. Priming pump does not accomplish the job. ...
Aj, do you have a foot valve on the bottom of the pipe in the well?? The jet pump needs to have a foot valve to hold the water in while priming it... you also have to carefully design the system and prime it in such a way as to eliminate all of the air in the piping. A jet pump will not pull the water and expel the air like a centrifugal pump will...
I think the part you are missing is the foot valve...
heatman101
Jun 09, 2011 | Garden
Have small commercial kenmore ice maker-model 106 89583700. Replaced pump-now no ice is forming. Cleaning light stays on-won't go off. Any suggestions?
Water Inlet Valve
Your icemaker's water inlet valve could be filled with ice. If it is, simply thaw the its water tube with a hair dryer to remove the blockage. Be careful to not melt any plastic parts with the blow dryer.
An icemaker's water inlet valve has a filtering screen to block minerals and other debris from entering into your ice cubes. It is possible that the water inlet valve's screen is blocked, and not allowing any water through to make ice. Clean out any built up debris you find. You should be able to pop the screen out of place with a screwdriver and then put it back in place with the screwdriver again once it is cleaned.
Alternatively, the water inlet valve itself may have become defective. You will have to test it. If the test proves the valve is defective, replace it.
if you need more info post it and I'll see if I can locate more
please take a moment to rate my response
May 31, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Air in lines
SOUNDS LIKE A CRACKED SUCTION STUB OR LOOSE THREADED FITTING SUCKING IN AIR.
OR THE CHECK VALVE IS FAILING AND ALLOWING THE WATER TO LEAK BACK SLIGHTLY OR ALL THE WAY BACK. YOU CAN ALSO ADD A FOOT VALVE AT THE END OF THE PIPE.
LONG SHOT, BUT THE BLADDER TANK IS CHARGED WITH AIR AND MAY HAVE A HOLE IN THE BLADDER CAUSING THE TANK AIR TO ENTER THE SYSTEM. SHOULD RUN OUT QUICKLY THOUGH. HOPE THIS HELPS, JODY
Jul 18, 2009 | Flotec Corrosion Resistant Shallow Well...
Pool Sand Filter
The volume of a 24x4 pool is 1809.6 cubic feet [Volume=pi x radius squared x height, or V=3.14159 x(12x12)x4], and the 18 foot pool is 1017.9 cubic feet [V=3.14159 x (9x9)x4]. When you multiply the number of cubic feet by the conversion factor of 7.48 gallons per cubic foot, you come out with 13,536 gallons versus 7614 gallons. Since the volume is nearly double, I don't think the other filter will cut it for very long. Is the top that is cracked in the valve body or the top part of the tank? It might be cheaper and easier to just replace the defective part in the long run than to use an undersized filter that will die prematurely.
Apr 15, 2009 | Hayward Pro Series 18" Above Ground Pool...
Dishwashers Logo
49 people viewed this question
Top Dishwashers Experts
Owen Barnes
