Question about Dishwashers
Ignis adl 350
Light flashes
4 Suggested Answers
SOURCE: Manual of IGNIS Dishwasher ADL
http://www.manuals-in-pdf.com/index.php?main_page=product_info&products_id=1013968
http://www.user-manuals.com/advanced_search_result.php?keywords=IGNIS++ADL+934S+manual&forward=plist
Hi I have found you two links you can choose which one you want.
I have searched hard BUT this is all I could find.
Posted on Aug 24, 2010
ginko
  • 19396 Answers
SOURCE: IGNIS ADL 347 DISHWASHER I interupted
Hi.
The Ignis dishwasher does not need reset code. It will normally restart working after tripping the circuit breaker.If the machine is beeping, that means that the dishwasher is in fault mode because some fault condition is detected. Among conditions that can cause the issue, residual water inside the machine, clogged drain, arms jammed.
Try disconnecting circuit breaker and drying water from the inside, also remove the drain well and clean it. Eventually carefully pour some hot water intor the drain well, inside the machine tub.
Connect back circuit breaker and try restarting the machine.
Here a forum on similar problems.
Posted on Sep 11, 2010
caroldon
  • 17130 Answers
SOURCE: my ignis adl 347 dishwasher
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. The drain pump can be clogged and refuse to work as it hums. If so remove and clean the drain pump, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated.
Cleaning a pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Thank You for using fixya
Posted on Sep 21, 2011
Dishwaster not working
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
REMOVE panel and check for moisture or loose joints in the connectors. If so dry using a heater. Check also the door switch. Other wise the panel is to be replaced.
Jan 17, 2013 | Washing Machines
Not working
Flashing a dead nokia n97
Hi according to my experience your problem seems to the wrong selection of flash file.So, try to download it from here n97 or if this link doesn't works please use what you have download previously .There are many flash files with a higher version.Make sure that you should select the file of your correct phone type (RM-505 or 507).....Download the flash file what it is written on your phone.After you have done this please repeat the steps.Good luck
Jun 20, 2012 | Nokia Cell Phones
My ignis adl 347 dishwasher will not empty its self i put it on a cycle it hums for a while then it starts bleeping continually and light flashes were you turn it off
Cleaning a pump:
Sep 21, 2011 | Dishwashers
I have a nokia 5130c there is problm camra on stand by please help me
Tools & Materials required  :
  1. Mxkey Dongle with latest software installed
  2. UFS / JAF Box
  3. Nokia 5130c Fbus cable
  4. CA-101 Usb data Cable
Step By Step :
  • Backup RPL & PM
  1. Open Mxkey Software
  2. Select UFS / JAF as Interface, then connect it.
  3. Pick Nokia Module
  4. Pick BB5 Tab
  5. Pick Service Tab
  6. Connect Phone to UFS / JAF box using Nokia 5130c Fbus Cable
  7. Click on " backup RPL "
  8. Save to safe location.
  9. Pick PM Tab, read full, save to safe location.
  • Flashing / Firmware Updating via CA-101 Usb data cable
  2. Select Nokia Usb Rom as Interface
  4. Pick BB5 Tab
  5. On flashng Tab, Pick Nokia 5130c Latest Firmware Package Properly.
  6. Click on " Flash " Tab
  7. Connect Phone to PC via CA-101 Usb data cable.
  8. Wait Until All Process done
Here's the log operations :
Reading phone`s ID ...
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
productData saved.
Restarting phone ...
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 24E0000D70D27D5657572DFFD11A84578F44242B
ASIC MODE ID: 00
 SecondaryBoot: rap3gv3_2nd.fg [BB5]  version: 9.11.1 revision: 0.0 size: 0x3C00
 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982  - 0000 8A31 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM]  version: 9.50.0 revision: 0.0 size: 0x23010
 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
TransmissionMode: DDR&TX2
Reading RAP NPC (0x168 bytes).
Reading RAP VARIANT (0x0 bytes).
Reading RAP CCC (0x160 bytes).
Reading RAP HWC (0xD4 bytes).
Flash Imei: 35422303116811
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
CMLA_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
RPL saved to "C:mobileEx.4dataackupRPLBB5_35xxxxxxxxx_BACK.rpl"
Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010)
Processing file: rm495__07.97.mcusw as MCU
 [BB5,BB5 ALGORITHM]  size: 18.20 MB
 Supported RAP Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button
Waiting for USB device ...
[ADL] Pooling for ADL device
[ADL] Device found: nmwcdnsucNokia USB Flashing Generic, ID: 1FB998E3
RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
RAP EM0 ID: 00000296
RAP EM1 ID: 00000B22
RAP PUBLIC ID: 24E0000D70D27D5657572DFFD11A84578F44242B
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
RAP ROM ID: 273F6D55DFAAF68F
[ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes
[ADL] Update Server code succesfully sent to phone.
[ADL] Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
[ADL] Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes
[ADL] Device found: nmwcdnsucNokia BB5 ADL Loader USB Generic, ID: 8572D57
[ADL] Verifying communication to device OK.
Erase size: 21.00 MB
CMT NOR area [00000000-000006BF] erased in 0.500 s
CMT NOR area [000006C0-0001FFFF] erased in 0.515 s
CMT NOR area [00040000-000BFFFF] erased in 2.172 s
CMT NOR area [000C0000-0013FFFF] erased in 2.094 s
CMT NOR area [00140000-0137FFFF] erased in 1 min 17.812 s
CMT NOR area [01380000-0151FFFF] erased in 6.954 s
Flash programming ...
CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written.
Programming completed in 1 min 5.172 s
Processing file: rm495__07.97.ppm_x as PPM
 [BB5,BB5 ALGORITHM]  size: 7.72 MB
Erase size: 8.62 MB
CMT NOR area [01520000-01DBFFFF] erased in 37.188 s
Programming completed in 26.469 s
Processing file: rm495__07.97.image_x_red as CNT
 [BB5,BB5 ALGORITHM] page size: 128 K size: 12.89 MB
Erase size: 34.00 MB
CMT NOR area [01DC0000-0215FFFF] erased in 22.829 s
CMT NOR area [02160000-03FBFFFF] erased in 3 min 12.922 s
Programming completed in 45.125 s
[ADL] Restarting phone ...
[ADL] Device found: nmwcdcNokia 5130 XPressMusic USB Generic, ID: 1878DB02
Flashing completed in 9 min 5.000 s
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.97 13-09-10 RM-495 (c) Nokia
Imei plain: 3542xxxxxxxxxxx
Product Code: 0578115
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SUPERDONGLE_KEY seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354xxxxxxxxxxx
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 9 min 8.922 s
Jan 24, 2011 | Nokia 5130 Cellular Phone
Ignis dishwasher beeps and flashes constantly
salt container is full of water
Mar 10, 2010 | Dishwashers
My Ignis dishwasher ADL 348 is not dissolving the dishwasher tablet properly leaving the crockery still dirty. It is also making a really strange noise during operation. I have cleaned the filters and the...
My adl 348 is 3years old. Made strange noise and didnt really wash now it doesnt appear to be washing. What would it be and is it easy fixed?
Feb 13, 2010 | Dishwashers
I have a Ignis by Whirlpool ADL 349 A/1 fully intergrated dishwasher which has not been used yet, but the door tension is really bad you cannot keep the door fully open to load or unload as it springs back...
I also have the same problem so i rung customer care & they said it is not a fault just the spring is working too good. Said it will settle down after a while.I keep pullig door down & up just to see if it settles down. Will let you know in a week or so if there is any change
Hope this helps regards Ray.
Mar 17, 2008 | Whirlpool Dishwashers
Ignis dishwasher model no. adl 347
I have the same problem. Having spoken to an engineer I have been told that the controller has gone. £120 for a new one plus fitting. So you are looking at a £200 bill to repair. Not worth it ???
Jun 14, 2006 | AEG 24 in. Favorit 40310 Free-standing...
Dishwashers Logo
Top Dishwashers Experts
