Question about Frigidaire GLTF2940ES Front Load Washer
E70 - Frigidaire GLTF2940ES Front Load Washer
  • Official Brand Answer
  • 4,342 Answers
Hello Michelle - Typically, error code E70 indicates that the water temperatures are not correct. Often this is caused because the hoses are wrongly connected to the valves. Check the hoses and make sure they are located on the correct faucet and valve. Confirm that there aren't any restrictions or kinks in the drain hose as well. If the issue persists, it would be advisable to connect with an experienced applaince repair tech to proceed further.
Posted on May 03, 2013
AEG Lavamat 60810 keeps stopping and displaying error E50 and some time E70. What is the problem and how do I fix it?
Family error code E50 means a problem with the washing motor. Family error code E70 means a problem with the NTC sensor. In my experience, E50 is most common fault in worn carbon brushes. But in any case family error code E50 is shown to the customer. In service mode could be: E51,52,53 and 54. The same applies to family E70 error code that will be displayed in service mode as error code E71 or E74.
E50 error code could be: motor winding, power board, tachymetric generator, motor relay on power board, wiring between motor and power board and wiring between tachymetric generator and electronic.
E70 error code could be: faulty NTC sensor, wrong position of NTC sensor or to much limescale on it and finaly wiring between NTC and electronic.
Dado
May 05, 2015 | AEG Washing Machines
Aeg lavamat 63613 error code E70
Family error code E70 is shown to the customer. In service mode could be: E71 or E74
Dado
May 04, 2015 | AEG Washing Machines
Frigidaire washer LTF7000ESO error code E70
Good Morning Jazy, this is JK. I see that you are receiving an error message E70. The E70 error means that the Main Control Board is not seeing the correct water supply. I would suggest swapping the hot and cold hoses. Hope this helps!
Mar 24, 2014 | Frigidaire Washing Machines
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
Jul 14, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
KEEP GETTING E70 MESSAGE
Are you sure its a E70? If so, the hot and cold lines are reversed.
Apr 25, 2010 | Frigidaire GLTF2940ES Front Load Washer
Copystar 1810 error E70
E70 Before switching on, originals were found on the
document feeder
Mar 05, 2010 | Copystar CS-1810 Copier
What is code error E70 on kyocera km-1510
the problem e70 is concerning with the document processor of ur machine. either there is a jammed paper on it or the actuator of ur switch on the document processor is broken.
Jun 23, 2009 | Kyocera KM-1510 Copier
ViewSonic E70 VCDTS21569-3P. NO POWER
hi,
Try to check capacitor on the B+ line leakage.
Mar 29, 2008 | ViewSonic E70 17" CRT Monitor
E70 ERROR SIGN
Great news that worked!! I had other issues with my washer and had a repair man come and fix it, when he left I started washing and that's when the E70 showed up uhh he hooked the hoses up wrong.. Thanks a bunch
Mar 11, 2008 | Frigidaire GLTF2940ES Front Load Washer
E70 error
May 15, 2009
I had this exact same problem with my Frigidaire washer (E70) as bubbles100. I called an appliance repairman on 5/14/09 and paid him $60 to tell me my hot and cold water hoses were reversed/not properly installed.
This repairman was the cheapest priced $60 and he would work till he found the problem. I had one appliance repair company wanting to charge me $90 for 30 min and another wanting to charge $120 for 30 min. Hopefully this information can help save the next person some money by trying this first.
Feb 16, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire GLTF2940ES Front Load Washer Logo
35 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
