Question about HP LaserJet 4250n Printer
HP Laserjet 4250 Service error code 49.4CO2 how do yoy fix?
  • 300 Answers
SOURCE: 49.2F80 Service error
A critical firmware error has
occurred.
Try following these steps -
1. Press CANCEL JOB to clear the
print job from the printer
memory.
2. Turn the printer off, and then
turn the printer on again.
3. Go to http: www.hp.com/
support/lj2420.
Click Download Drivers and
Software
. Check for the
latest firmware image version
at the bottom of the page. If
this firmware image is newer
than the one installed on the
printer and the printer can
receive a firmware update,
download the newer firmware
upgrade. Not all printer
models can receive firmware
upgrades.
4. Try printing a job from a
different software program. If
the job prints, go back to the
first program and try printing a
different file. If the message
appears only with a certain
software program or print job,
contact the software vendor
for assistance.
1. After performing the actions
listed in the preceding item, if
the message persists when
using different software
programs and attempting
specific print jobs, disconnect
all cables that connect the
printer to the network or a
computer.
2. Turn the printer off.
3. Remove all memory DIMMs
or third-party DIMMs from the
printer. (Do not remove the
firmware DIMM in slot J1.)
4. Remove all of the
EIO devices from the printer.
5. Turn the printer on.
6. If the error message
disappears, reinstall
each DIMM and EIO device
individually, making sure to
turn the printer off and then
on again as you install each
device. To replace a DIMM,
see.
7. Replace the DIMM or
EIO device that caused the
error message.
8. Remember to reconnect all of
the cables that connect the
computer.
9. If this error message persists,
replace the firmware DIMM.
10. Replace the formatter
Posted on Jul 18, 2008
Nikhil Gedam
  • 87 Answers
SOURCE: hp laserjet 4250
This happens when the printer is printing duplex job. i.e. trying to print the other side of the page.
However check the functionality of the printer by performing Paper path test.
This would help us to know whether the printer as a stand alone ... is fine or not.
From the control panel of the printer, scroll to Diagnostic > paper path test.
Select the following in sequence.
Source: All trays
Copies: 10
Duplex: ON
Print Test Page
Check if you get the same error.
If yes, upgrade teh firmware of the printer.
Let me know the end result. We still have more depending on the above test.
- Nikhil
Posted on Nov 04, 2008
leroyal
  • 2120 Answers
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Posted on Feb 06, 2009
  • 27 Answers
SOURCE: how to enable duplex printing in hp laserjet 4250
This unit needs to have a duplex unit installed if you want to duplex. If the back of the unit is "flat" you do not have a duplexer installed.
the duplex unit slides into the back of the printer between the back door and the paper tray. when installed you will have a bulge on the back of the printer about 7 inches tall and the width of the printer that sticks out about 5 inches.
after installing the dupelxer you may need to enable it in the print driver under properties then the advanced tab you should see a spot for advanced settings.
Posted on Jun 21, 2009
  • 21 Answers
SOURCE: HP LaserJet M1522 with error 49
on hp.com you can update the firmware and that should take care of it. its a free download
Posted on Jan 07, 2010
How to fix Error 60.02 for hp 4345
Easy steps to fix Error Code Clr20r3 occur in HP Computer/Laptop/PC on Windows OS by dialing HP Customer Support Phone Number 1-844-355-5111 (toll-free) with the help of customer support services.
HP Customer Support Phone Number 1 844 355 5111 HP Help
Sep 08, 2015 | HP Office Equipment & Supplies
Hp 4250 error code 55.4
error code 55.4 on HP Laserjet 4250:-The dc controller is not communicating with
the formatter. The problem could be caused
by a timing error or an intermittent
connection
Repair:-
switch off the unit - disconnect power cord
unsrew the two screws holding the formatter in place
( silver plate to rear right)
remove the plastic side panel by sliding
remove the formatter ( silver box you just unscrewed) by sliding toward the rear.
reinstall the Formatter
and re-test
more often than not just reconnecting the controller is enough to clear the problem. theres a good chance it has moved out of position as time has gone by.
Jan 22, 2013 | HP LaserJet 4250n Printer
Laserjet 4250 error 59.00
I've found this specific error code leads you to a main motor failure, Ive found some decent priced motors if you need them: HP 4250 Main Motor
Aug 30, 2011 | HP LaserJet 4250n Printer
La impresora HP 4250 me presenta el sigueinte error 49,2F05 Service error.
This is a common issue and as such I have written a tip on how to fix this.
You will find the tip here
Jan 31, 2011 | HP LaserJet 4250dtn Printer
Maximum file size for printing on the hp color laserjet 5500n - having issues with pdf files
If you are getting 49.XXXX error codes while printing PDF files, you can try upgrading the machines firmware.
This seems to be a common "PDF file printing" problem with the LaserJet 4250.
Oct 25, 2010 | HP Color LaserJet 5500 Printer
My hp 4250 laserjet printer displays an printer error 57.4 message when i switch it on. what could be the problem? since it can not continue the printer checkup progress.
<P><A href="http://www.printertechs.com/tech/error-codes/error-codes-index.php">http://www.printertechs.com/tech/error-codes/error-codes-index.php</A></P><P>&nbsp;</P><P>Plz check the the link for the detail error codes.</P>
Aug 28, 2010 | HP 4250 Monochrome LaserJet Printer
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
Error during print 'Remove all paper from bin'
HP Laserjet 4250 Network connected laserjet printer.
Steps to be follwed to set right :
01. Please check in number of desktops or laptops it connected.
02. Give proper IP Address in the Desktop or Laptop where it has to be orignally installed.
03. Being a network printer, lot of desktop or laptop users might have printing job iniated.
04. Right click the printer properties which is available bottom right hand corner ikon and delete or cacel all printing jobs.
05. The original desktop or laptop where the IP Address created will be rebooted. System should be restarted.
06. Try to print now to close this solution.
07. Still the problem persits, kindy contact local HP Authorised printer service engineer to set right this issue.
Have a nice working day.
Jul 17, 2009 | HP 4250 Monochrome LaserJet Printer
Hp 4250 error code 50.3
FALSE FUSER OVERTEMP INDICATION, POWER SUPPLY THAT DRIVES THE FUSING UNIT. MODEL 8150 DOES THE SAME THING. TRY TO GET A REFUND ON THE FUSER?
Apr 15, 2008 | HP LaserJet 4350 Printer
Hp printer problems
Error codes starting with 13 usually indicate paper jams. Open all the doors on the printer and remove any removable modules and check for stuck paper.
Jan 11, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 4250n Printer Logo
1,263 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
