Question about Philips Televison & Video
50pfl3087/f7 cant find ok button on the front of the tv
TV won't power on
Could be an open internal fuse or power supply failure
Jan 03, 2017 | Philips Televison & Video
Magnavox MDR537H/F7 -- DEAD no power
There is usually an internal fuse in all audio/video equipment and it will normally be a 20mm glass one positioned near the power supply or somewher close on the circuit board. There may be more than one so have a good check around. Be sure to replace with the same type and rating, no sticking kitchen foil across it to short it out, this illegal and DANGEROUS.
Jun 03, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
I need to turn the internal speakers on my Philips model 42PFL7403D/F7 off so i can use my Bose sound bar
http://download.p4c.philips.com/files/4/42pfl7403d_f7/42pfl7403d_f7_pss_aenus.pdf
Try the above link to download its user manual, and make sure that the panel lock to your TV is OFF. If it is ON, you can't do anything with its front panel switches. Gopakumar Gopalan Google
Apr 02, 2014 | Philips 42PFL7403D/F7 42-Inch 1920 x 1080p...
Philips 47pfl7403d/f7 LCD TV When the TV is
first you may check the T-CON board if thats ok then the problem is coming from your set panel .
Sep 01, 2013 | Philips Televison & Video
Does Magnavox mdv 2100/F7 dvd player have front panel display
Hello
This DVD player has no front panel display. Its front panel have ony two LED light indications, out of which, one is for power On indication and the other for p-scan [Progressive Scan] which will ight up when you select Progressive Scan function.
There are three push button switches, for Open/Close, Play & Stop.
It has only ON-Screen display system, which will be active only after connection the DVD player to tV. OK.
http://www.dataentryjobs.us/67948.html
Feb 02, 2012 | Magnavox Televison & Video
How do i get regular tv channels no cable or direct tv. I have a 32' magnavox model #32MF338B/F7
Hello
I'm not sure about the model number of your TV, as here it is marked as both "27MS343S and 32MF338B/F7". Anyway I gies this solution as for the first denoted.
Insert antena to the antena socket at the back side of your TV marked as 75Ohms antena input.
[1] Press "Menu" button on the remote control handset to display menu on screen.
[2] Press "Vol+ or Vol--" button repetedly to hilight "TUN" [Tuner].
[3] Press "Ch+ or Ch--" button to hilight 'AUTOPROGRAM"
[4] Press "Vol+" to programming tv channels.
Tv will tune and store channels transmitted channels at that time, through entire bands, and will display the first channel receved after tuning process completed. It may take some minutes. You have to wait it to complete. After displaying the first channel, you can select your favourite channel Using CH+ or CH--" buttons. Ok.
Nov 03, 2010 | Philips Magnavox 27MS343S 27" TV
52PFL7403D/F7 remote does not work with my TV
Hi
First thing to do is check your remotes by aiming them at a camera or the camera on your mobile phone then pressing any button you should see the led on the remote light up white, If this happens then your remotes are ok and you would then need to look further into the problem.
I would suggest the remote sensor in the tv being short or you may need a replacement AV board (the one that has the inputs and scart sockets are on )
Hope this info helps
Apr 05, 2010 | Televison & Video
Error f7 oven wont turn off
Hello there:
The f-7 error code carries several different possiabities
here are several possiable reasons and the things to check
1. F5 or F6 or F7 EOC (Electronic Oven Control) failure Replace EOC(Electronic Oven Control)
2.
F7 Shorted touch panel Replace glass panel
3.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace clock assembly (also called the ERC)
Please test each of these carefully ok and if you disconnect the board you may want toclean the contacts really good and then try to reconnect the wires and make sure that they are properly connected ok
Best regards Michael
Jan 12, 2010 | Ovens
I hit the FPA and now i am screwed how do i fix this it I cant get into my tv
Child Lock allows you to lock the buttons on the front of the TV.
Press MENU to see the main menu.
Press CH+ or CH- to highlight
Preferences.
Press OK to enter the Preferences
submenu.
Press CH+ or CH- to highlight FPA
(Front Panel) Lock.
Press VOL+ or VOL- to turn on or off
FPA Lock. Choose On to disable all the
buttons on the front of the TV. FPA Lock
On will appear on the TV screen each
time you press buttons on the front of
the TV. You can still operate the TV with
the remote control. You can still use the
POWER button on the front of the TV, but
only to turn off the TV (not on). Set FPA
Lock to Off to cancel this feature so you
can use the buttons on the front of the TV
again.
Press MENU repeatedly to exit the
menu or the menu will automatically
disappear within a few seconds if no
buttons are pressed on the remote
control.
I hope this helps and good luck!
Nov 15, 2009 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
41 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
