Question about Pool & Spa
P2ra5e 181l My pump is making a loud noise while its on. What can it be?
  • 3 Answers
SOURCE: pump motor makes loud noise when pump comes on
If this is a high pitched sound, then this sounds like you have bearings that are starting to go out.  There is not much that you can do to prevent eventual failure.
The only other option that I see is that there is something causing friction inside the pump between the impeller and diffuser.
Posted on Jan 12, 2009
john224
  • 1378 Answers
SOURCE: when running it makes a loud continuous loud noise
Your bearing are failing. Replacing them and the seal at a local electric motor repair shop will likely cost around $50.
Posted on Jun 14, 2009
john224
  • 1378 Answers
SOURCE: when running it makes a loud noise
  • 3600 Answers
SOURCE: Sta-rite problem
Pump is heating up and kicking the breaker try cleaning the pump filter and let me know by posting to this solution.
Posted on Sep 29, 2009
  • 990 Answers
SOURCE: my hayward northstar pump makes a loud noise when
If you have a crack in your basket you may have a clogged impeller. With the power off reach back into the pump through the pump pot with a long screwdriver and feel around. If it feels spongey it there you have a clog. Take the serew driver an use an oceleting motion in a counter clockwise direction this should loosen the clog then reach in with a long set of thin pliers and pull the clog out. This should fix your problem and once water is flowing your pump should quiet down.
Posted on Oct 03, 2009
My Igloo ice 102C is making a loud noise when it pumps in water to make Ice. How do I fix this
It shouldn't make any loud noises at all. Most likely it's a water pump related problem. Most pumps make loud noises when they are lose from their base due to a broken clip or untighten screw. It could also be caused by a faulty pump. Either way, if you just bought it and have the receipt, return it and have them give you another one.
Dec 02, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Pool pump makes a loud noise
bad bearings change pump and motor
May 14, 2014 | Waterway Impeller Pump 2HP SD WW
How to wire motor sta rite p2ra5e 181L
The green wire is the ground and bolts onto the motor frame on the top part,(should see a green screw). the other two wires go to the two posts with screws to clamp down on the wires. It does not matter which way these two are hooked up, one on each post.
Most motors are pre-wired for 220v from the factory. If you have 220v you're good to go. If you happen to have a 115v setup the motor will run at half speed. The motor can be converted to 115v by moving a brown wire and a white wire in the motor. The diagram is on the motor label.Best to verify your voltage first.
Mar 21, 2013 | Sta Rite Sta - Rite 1hp Dura - Glas...
Sprinkler pump makes loud noise when it is running, how to fix?
Typically this sound indicates bearings going out. Usually this means replacing the motor, or may be repairable depending on size and make.
Jan 11, 2013 | Pool & Spa
I lost the gasket that seals the 2 halfs of a duraglas P2RA5E. Would you have a part number
this is the best pump going ! I hear a guy is going to list one on ebay for $5.00 shipped, MONDAY the part # should be STA-101-3745G retails for about 15.00..
remember to prime that pump !!!
Jay.. the pool pump repair guy in longwood Floida 32750
Nov 20, 2010 | Sta Rite StaRite DuraGlas Pump 34 HP...
Fuel pump noise 2005 Buell xb9sx
That is the fuel pump doing its job of pumping. If it stops making noise, it stopped pumping, and no gas is getting into your motor. Your bike will not run without a running fuel pump. :)
Apr 14, 2010 | 2005 Buell Lightning CityX XB9SX
Sta-rite problem
Sep 29, 2009 | Sta Rite Sta - Rite 1hp Dura - Glas...
When running it makes a loud continuous loud noise
Jun 02, 2009 | Polaris 380: Polaris Booster Pump
Will not agitate or spin,makes loud noise during those cycles
Sounds like coupling gears between transmission and motor... they did away with the belt and went direct drive with coupling gears. It can pump water out but nothing else. water pump is mounted to front of motor is why it will pump water out.
Jun 19, 2006 | Whirlpool LSN2000LW Washer
Pool & Spa Logo
71 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
