Question about Frigidaire GLTF2940E Front Load Washer
Frigidaire front load washer displays E20 what does that mean?
  • 5 more comments
  • kantbchivas Nov 28, 2007
    need to know what e30 means and how to fix it
  • Anonymous Dec 30, 2007
    We get error e20 and no water goes in to wash bin.
  • Anonymous Apr 01, 2008
    same problem. please advise
  • Anonymous Apr 02, 2008
    My washer displays e20.It doesn't spin water out the way it should.
  • Anonymous Jul 30, 2008
    e20 comes on and machine isnt running
  • Anonymous Sep 21, 2008
    same problem. Washer is only 8 months old. Any ideas? HELP! Thanks.
  • markitalynn Mar 08, 2009
    I have the same error code E20. There is no E20 in my manual, but it will not finish spinning, the clothes are wet, there is still water in the bottom and the door will NOT unlock so I can retrieve them. Tried the unplugging thing, and still nothing. After fooling around with the Options/Pause buttons I finally got it to unlock. Anyone have a clue what is going on????
    New Friend:
The last time I had this error code it was the door latch mechanism. I am not sure what it is now. I regret buying this washer.
Posted on Dec 10, 2013
E59 code means you need a new circuit board and Frigidaire knows it's a problem, but will only step up to repair if you demand it. we're on our second circuit board in 2 years!
Posted on Jan 11, 2008
SOURCE:
How do you fix e20 code
Hello John, thanks for your inquiry!
From my understanding your Frigidaire front load washer is displaying an error code of "E20" and you would like to know how to fix it. An "E20" code stands for water is not pumping out fast enough this could be a problem with your drain hose, pump, or control panel. I would suggest checking the drain line to make sure it is not restricted. If the line looks clear it could be a problem with your drain pump or control panel. I would recommend seeking assistance from a professional technician for proper repairs. I hope this information is helpful. -Matt
Apr 23, 2015 | Frigidaire GLTF2940ES Front Load Washer
E20 Error
Hello Diane Snow, thank you for your inquiry!
I understand that your Frigidaire washer is displaying "E20" error code. The "E20" error code means water is not pumping out fast enough. First, you want to check the hoses for restrictions.
If the hoses are not restricted it could be an issue with the drain pump or control board. I would suggest seeking assistance from a professional technician for proper repair. I hope this is helpful. -Matt
Oct 06, 2014 | Frigidaire Washing Machines
What do i do when my washer affinity frigidaire displays E20
Hello friend, thank you for your post!
I see your question is labeled under Frigidaire washer, ATF6000ES, and your washer is receiving an error code of "E20". "E20" stands for the water is not pumping out fast enough which means it could be an issue with your control panel or drain pump. I would recommend having a professional come out and properly repair your appliance. I hope this is helpful. -Matt
Sep 27, 2014 | Frigidaire ATF6000ES Front Load Washer
Tumble action washer keeps giveing me E20
first, find a manual or contact tech support to determine what an e20 means. it could be a clogged drain.
Jun 02, 2014 | frigidaire.com
What does the error message E20 on the frigidaire front load washer GLTF2940FS mean?
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Oct 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
Error message E20
Hi... error E20 means your washer can't drain you may need a new pump or something is in the pump
Apr 07, 2011 | Frigidaire ATF6000ES Front Load Washer
What does e20 mean? The display shows an error of e20. Looks like the water is not pumping out during the regular wash.
Hi
Error code e20 means a clogged drain pump. This might have happenned due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then remove whatever is there in the pump.
Please post back for any further assistance.
Daniel
Jul 31, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer (LTF600ES1) Error E20
Your washer is not draining properly. You need to check if the drain hose is kinked and also whether the household drain is running smoothly.
Aug 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
Open Questions:
Frigidaire GLTF2940E Front Load Washer Logo
394 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
