Question about Mtd Garden
Kawasaki lawn mower engine
Model 12A 567A795 won't stay running.
#1 Taper
  • 1040 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
buffalonyman
  • 1865 Answers
SOURCE: Change Oil
All lawn mower engines have a drain plug for draining the oil. Look for a square nut on the side of the engine
Posted on Jun 12, 2009
MOTORWIZJ
  • 1358 Answers
SOURCE: engine doesn't stay running
99% ITS WATER IN THE GAS
Posted on May 21, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have a Sears craftsman lawn mower that will not
Your engine parts list can be found here: http://www.briggsandstratton.com/maint_repair/manual_and_more/docsearch.aspx?enginelookfor=12h887-2314-E1
There are 3 different carb variations on this unit.
Primer type
Choke type
Auto-choke type?
On the Primer type with the plunger on the side of the carb the primer bulb gets a pin hole in it that allows air to be drawn through the primer bulb. So the engine will start an then die after priming.
On the Choke type carb debris in the bottom of the float bowl AND bowl nut will cause this.
On the Auto Choke type there is a diaphram under the carb that can get damaged and allow airflow where there should be fuel flow.
I am pretty sure that your mower has the float bowl on it. remove the bowl nut... take some carb cleaner and spray directly up into the hole the bowl nut screws into and clean it. Then also spray around the float needle.
If your still having problems.. just fro grins remove the fuel supply line to the carb and check for fuel flow. If there is little or no flow either the fuel slector is off or the fuel tank outlet has debris covering the tank outlet hole inside the gas tank.
Thanks for using FixYa.
Kelly
Posted on Jul 05, 2010
  • 3 Answers
SOURCE: Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
Posted on Dec 16, 2010
Battery won't stay charged
The engine will have a generator under the flywheel, this should charge the battery when the engine is running, you can use a negative shunt on the battary terminal to check what if any power is going to the battery from the engine.
Apr 02, 2013 | Garden
My Craftsman mulcher 21" 6.0 lawn mower starts but won't stay running
clean the carb left over old fuel plugs the jets inside
Jun 08, 2012 | Craftsman Garden
Lawn mower blades won't budge, even w/ 1/2' drive impact wrench
Hi, warm the nuts up with a heat gun or oxy torch then try the impact gun while they are hot, regards Phil.
May 31, 2012 | John Deere Starter Tractor Lx188 Kawasaki...
Troy Bilt self-propelled model #12A-466-M011 front wheel drive not working
would this also cause them to lock up when off???
May 10, 2012 | Troy Garden
I have a craftsman lt 1000 riding lawn mower and it runs, but it won't go into gear it goes into gear, but clutch won' engage the gear.
Look under the mower to see if the drive belt has come off or broke. It is the belt that runs from the bottom of the engine to the rear axle.
Oct 01, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
What engine oil do I need for my yardman 6.0 HP push mower?
SAE 30 only; if using conventional oil. I recommend using synthetic engine oil. If you go with synthetic, you can use a multi-viscosity oil like 10W-30, but only use staight SAE 30 if using conventional oil. Many benefits to using synthetic oil. It cleans the engine as it runs, it provides superior protection and helps cool the engine parts better, and it almost assures you 100% that your engine won't fail because of the type of oil used.
Jun 18, 2011 | kawasaki Garden
Hi I need a parts and repair manual for the yardman 12a-978q452 mower , I can not finded on line.
I know this was more than a year ago, but I just got one second hand and had to find the same thing. It's made by MTD in Canada. Here's the site to find it. They don't have the manual for the exact same model number, but I've gone through it enough to know it'll work. http://www.mtdproducts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10500&catalogId=20500&langId=-1
May 06, 2011 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
Garden Logo
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
