Question about Garden
Pro user ppw55
Fitting new pump
2 Suggested Answers
SOURCE: I am looking for the instructions manual for a Pro
Try phoning there technical helpline, they helped me out when i had problems with a similar machine, the number is 01473 747084
Posted on Mar 09, 2011
Water pump leaking
If you remove the lower front panel, you just might be able to see the pump.
I surely hope so.
If you can, try to determine whether the pump is leaking or one of the hoses or the pipe fitting ( maybe brass).
If the metal fitting is leaking, you may need teflon tape to rethread it.
If a hose is leaking, a new clamp may help, unless it is cracked.
I guess you know most built-ins can be removed about 6 - 8 inches out into the kitchen for service and inspection. The hoses and wiring should be long enough to allow this.
Usually the built-ins are secured only to the counter top with a couple of screws in the front.
If you need a new pump, you can go online and get one from "Sears Parts Direct".
God bless your efforts.
Oct 29, 2015 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Why is no fuel getting to the injectors?
Check the Fuel pump
2003 Mitsubishi Galant Repair and Maintenance - RepairPal
repairpal.com > Cars > Mitsubishi > Galant
Information on the 2003 Mitsubishi Galant, including known problems, recalls, user ...2002 Mitsubishi Galant ... it will crank but not start not getting any spark or fuel what can you suggest. would like . ... The fuel return line fitting at the fuel pump may be restricted, causing excessive fuel pressure in the fuel injection system.
Sep 25, 2015 | 2002 Mitsubishi Galant
4JH1 ENGINE ISUZU 2004 REFUSING TO START AFTER FITTING NEW PISTONS
check fuses and wiring.
try connecting a bypass wire from +ve of battery to fuel pump and crank engin mast sart to stop just disconnect the wire. try this only if you are pro. it might be dangures if you do not know what you are doing.
Apr 03, 2014 | Isuzu Trooper Cars & Trucks
How do I fit a new pump to a ppw55
New pump wet ends have an impeller inside the housing and the impeller is threaded onto the shaft of the motor.
the four bolts go all the way through the motor and thread into the four little fingers on the wet end to hold it onto the motor.
Rod
US Parts Center
May 02, 2013 | Pool & Spa
How to change powerstering pump chevy uplander
I just finished replacing mine.
It is much easier if you do these steps:
1. Remove the serpentine belt.
2. Remove the nuts holding the main fuse box over the battery.
3. Remove the reinforcing bar over the battery.
4. Remove the battery.
5. Remove the windsheild washer tank.
6. Now you have access to remove the pump pulley. Without removing the stuff, it may be possible, but it will be extremely difficult.
7. Remove the pump pulley.
8. Loosen the high pressure hose fitting.
9. Remove the return line clamp.
10. Remove the power steering pump mounting bolts.
11. Remove the high pressure hose fitting.
12. Remove the power steering pump while sliding off the low pressure hose.
13. Remove the clips holding the reservoir on the pump.
14. Remove the reservoir.
15. Install new o-ring on the reservoir.
16. Install reservoir on new pump.
17. Install clips to hold reservoir on pump.
18. Install new o-ring on high pressure fitting.
19. Place new pump in position while sliding on low pressure hose.
20. Loosely attache high pressure fitting.
21. Tighten pump to mounts.
22. Tighten high pressure fitting.
23. Install clamp on low pressure hose.
24. Install power steering pulley.
25. Install washer reservoir.
26. Install battery.
27. Install reinforcing cross member.
28. Install fuse panel.
29. Install serpentine belt.
30. Bleed the power steering system.
Dec 13, 2012 | 2008 Chevrolet Uplander
Replace power steering pump on 06 chevy uplander
Jul 08, 2012 | 2006 Chevrolet Uplander
I am looking for the instructions manual for a Pro User Petrol Pressure Washer PPW55 5.5HP, do you know where I can get this? Thanks
May 03, 2010 | Garden
My Stay Rite Pump 1 hp, 230 volt model DS3HE - 01 runs, but does not operate my irrigation system with any pressure. I resume the pump has lost its prime, but have no clue as to what I might do to fix it?
pumps lose prime for a few reasons...bad foot/check valve, crack in the suction line are probably the two most common.. see if there is a threaded fitting( most pros put one on the pipe some where) on the top feed of the pump. open it up and add water til the pump fills up. if the pump is outside turn the pump on before resealing the fitting, otherwise resael the fitting and open a spicket outside. depending on your water table it could take some time to prime but in normal circumstances up to 20 minsif it does not prime you may want to consider hiring a pro!!
Jan 12, 2010 | Flotec Corrosion Resistant Shallow Well...
Power sterring hose leaks. how is hose connected to pump
Most of the PS pressure hoses are Compression Fittings. If the fitting is straight on and is clean on the inside before you seated the hose, there may be a burr of the pump side where the fitting sits. Some of these fittings are replaceable and others require a new pump. Check your new hose also for cracks where the pipe section of the hose is that looks sort of like a trumpet end. If the fitting is in good shape, the pump fitting is clean and unmarred, you may need to tighten the hose a little more.
Jul 22, 2009 | 1989 Toyota Celica Liftback
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
