Question about Xerox DocuPrint C4350 Laser Printer
Error 004-363 please reboot printer
What does this error mean: Please reboot. printer (116-324);
power cycle the printer. switch off and on
see further here for similar printer error my okidata com
Jun 08, 2016 | OKI B6200 Laser Printer
SPC222SF IS GIVING ERROR ""PLEASE REBOOT SYSTEM ""
It is in auto reboot mode when a failure occurs. You need to take note of the SC Code that appears before it reboots. That will tell you what is malfunctioning. If it boots up with that - as in immediately - unplug the machine, remove the hard drive, plug in and reboot. Does it still occur? Yes? You need a service tech to check it out. No? Replace the HDD.
Oct 18, 2014 | Ricoh Aficio SP-C222SF Flatbed...
120.07 service fuser error
An error has occurred in the fuser. Please remove and reseat the fuser. And then reboot the printer. If the error persists, please contact our Technical Support Hotline.
Dec 21, 2012 | Lexmark C748E Laser Printer - Color - 2400...
Please reboot printer (124-315)
How to reboot printer Xerox DocuPrint C4350 error code : printer (124-315)
Oct 03, 2011 | Samsung CLP 315 Laser Printer
Computer shuts off when a document is about to print.
first you should un install your driver,then install it again.
Jun 26, 2009 | OKI B4350 Laser Printer
ERROR PROBLEM H4-01 ON SCREEN
Type in p * c * then 14 press copy key then CA. Machine will reboot, if problem is still there after reboot, one of the thermostats in the fuser has tripped. Did this happen soon after a jam?
Dec 01, 2008 | Sharp MX-2700N Color Copier
Error notice
Please reboot the Printer then check
Again reboot the Printer and PC both and then check. Let me know if the error still persists.
Regards
Ellin
Sep 25, 2008 | Lexmark T642 Laser Printer
Installation
please click here to download the drivers for you printer please select your operating system and follow the screen setup.
im gonna guess off the top of my head that you have a antivirus/firewall on.
this ushally prevents software to be installed expessually when you get a error on the install.
please uninstall then software then reinstall the software without the firewall or antivirus activated. here is what you need to do.
Start--->Run--->type: msconfig---->in the general go to diagnostic startup---->accept, close and reboot
Install the software it should install now.
Then reboot
then goto
Start--->Run--->msconfig---->in the general options to to normal startup--->accept, close and reboot
Aug 11, 2008 | HP Photosmart 7450 InkJet Printer
Error Message - PLEASE REBOOT PRINTER (116-330)
Somewhere in the addressing there is an error.
You can call 1-800-821-2797 and ask for second level support. They can narrow down your problem.
116-XXX or 119_xxx codes normally have to do with addressing issues within the network.
Jul 24, 2008 | Office Equipment & Supplies
Xerox DocuPrint C4350 Laser Printer Logo
56 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
