Question about Innovage 1502084 Corded Phone
Ringer volume Is there a way to turn the ringer volume up or down? My son lost the manual and I can't find a Menu option on the keypad.
  • 2 more comments
  • D Spence Apr 12, 2008
    How do lower the ring volume?
  • gregmail Nov 11, 2008
    There are no "hi / low" volume switches anywhere.  Is there a programming solution?
  • derango3 Feb 02, 2009
    I would like to know how to turn the ringer off!
  • Anonymous Mar 20, 2009
    Innovage (1502084) Corded Phone cant find button its done off key pad
On the back of the base there is a volumr high low switch.
Posted on Dec 08, 2007
Can't turn the ringer on to notify when a call is coming in.
Without the model, I can't be sure of the method you need to enable the ringer.
Some Uniden phones toggle on a Silent Mode if you press and hold the # key (below 9 on the keypad) for 3+ seconds on one handset. When turned on, the phone will ask how long (1-9 hours) you want the ringer to be disabled for the handset. If no key is pressed within 5 seconds, the handset will not ring until the # key is pressed and held again.
Other Uniden phones have a Do Not Disturb mode. This disables the ringer on all handsets.To disable this, press and hold the DND button on the base. The answering system will be turned on if it isn't already on when DND is in use.
The other options to mute the ringer include the volume down on the handset when the phone is in standby. Some phones will also adjust the ring tone volume in the menu.
I hope this helps. Please add a comment with the model of your phone for additional information.
Apr 29, 2016 | Uniden Cordless Phone
How do I turn off the ringer on my AT&T 832 telephone? I do not see a ringer button and I do not have a manual. The phone is about 12 years old.
Hi
You can turn off the ringer completely so it no longer makes an audible sound when the phone receives an incoming call. The phone's ringer options can be accessed in the handset's menu.
Press the "Menu" button on the phone.
Press the up or down arrows until the phone's display says "Ringer Volume."
Press the "Select" button on the phone.
Press the up or down arrows until the phone's display says "OFF."
Press the "Select" button to save your settings.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 14, 2011 | Cell Phones
Message box says, "ringer off".
Ringer Settings
Handset ringer volume
4 levels (high/medium/low/off) are available. The default setting is HIGH.
1. Press "Menu."
2. Scroll to "Ringer setting" by pressing up or down arrows.
then press the arrow that looks like a play button arrow pointing to the right.
"Ringer Setting"
3. Scroll to "Ringer volume" by pressing arrow down or arrow up, then press the play button type arrow.
4. Press arrow down or arrow up repeatedly to select the desired volume.
5. Press "Save."
(To turn the ringer off, press down arrow repeatedly until "off?" is displayed, THEN PRESS "SAVE.")
Here's the manual:
http://service.us.panasonic.com/OPERMANPDF/KXTG2431.PDF
Please give me positive feedback if this helps you.
Thanks.
Feb 23, 2011 | Panasonic KX-TG2431 Cordless Phone
Phone shows ringer is off..how do I turn it on?
Follow the steps
Press Menu--->Ringer setting--->Ringer volume----> press up button to ON the ringer.
You can reduce ringer volume by down arrow and increase volume by up arrow.
Thanx
Jul 24, 2010 | Panasonic KX-TG2343 Cordless Phone
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
Apr 17, 2009 | Uniden Cordless Phone
Model GE 27951 - Unable to Turn Ringer back on
The headset volume is turned to zero. Hit the "menu" key on the headset and it should take you to "ringer setting", hit select for the ringer volume and turn the volume up. Not very intuitive but that should get you going!
Jan 28, 2009 | General Electric 27951EE1 - - Phone
Ringer not working
On the base press the volume up [^] key. Repeat pressing to get higher volume. Press volume down [V] for reducing the volume. Press and hold volume down for two seconds to turn ringer off. On the handset, you can use the menu to turn ringer on and off.
Nov 19, 2008 | Panasonic KX-TG2313 Cordless Phone
Keypad sound
go to menu/settings/ring styles/style detail/ keypad volume
Oct 26, 2008 | Motorola Mobility RAZR V3
Panasonic cordless phone,
press menu,scroll down to ringer settings,hit select,scroll to ringer volume and hit select then press up the round button in the middle until you hear it make a "ring" sound. adjust your preferred volume and hit save.
Oct 16, 2008 | Panasonic KX-TG5632 Phone
Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Dec 31, 2007 | Panasonic KX-TG2357 Cordless Phone
Innovage 1502084 Corded Phone Logo
260 people viewed this question
Top Innovage Lands Phones Experts
wiccan8thhouse
wiccan8thhouse
Computer Repairing
Computer Repairing
k24674
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
