Question about Acer Aspire 9810-6829 Notebook
Replace cmos battery Acer 9810
4 Suggested Answers
todd0708
  • 247 Answers
SOURCE: acer travelmate 342t CMOS Battery bad, How do I
it is inside,on the motherboard,it is a watch type battery or a vinyl coated battery pack that plugs in the board,if it is the watch battery type,be carefull removing it.the holder can break off the motherboard very easy,might be able to get to it by removing the plastic piece above the keyboard that surrounds the power button,otherwise dissassembly will be necessary
Posted on Oct 05, 2009
nblady
  • 206 Answers
SOURCE: Replacing CMOS battery - Acer aspire 3000
Before you begin, back up your data and remove the battery. CMOS Bios will be lost but will reset on restart.
    Instructions
  1. Step 1 Open the laptop computer's screen and lay it back as far as it will go. Be careful not to stress the screen and cause any damage, but press it hard if needed.
  2. Step 2 Press a flathead screwdriver under the front of the plastic bar lining the back of the laptop's keyboard. Pry the bar up slightly and hold it with one hand.
  3. Step 3 Pry up the other side of the bar with the flathead screwdriver and fully pull out the bar. Keep its ribbon cord connected and set the bar on the laptop's screen.
  4. Step 4 Remove the two Phillips screws securing the computer's keyboard. Then, slide the keyboard up and out to remove it. Again, do not remove its ribbon cord, and set the keyboard over the laptop's touch pad.
  5. Step 5 Remove the four screws securing the cover plate over the motherboard and remove it as well.
  6. Step 6 Locate the CMOS battery at the bottom right corner of the motherboard.
  7. Step 7 Remove the battery by prying it up gently with the flathead screwdriver. Then, replace the battery with a new one of the exact same specifications.
  8. Step 8 Replace all the parts in the laptop in the reverse order that you removed them. -Battery Replacement
User Manual
Good Luck
Posted on Feb 15, 2010
SOURCE: how do i remove acer aspire 9810 keyboard
to remove the keyboard, remove the screws at the back of your laptop. Then remove the Hard drive, then remove the Optical drive then remove the video card, and then power supply. Then remove the fan from the motherboard and you may remove the screws on top of the keyboard. Finally you may replace the keyboard.
Posted on Jul 15, 2010
Bl51 motherboard
All laptops have a CMOS, or "Complementary Metal Oxide Semiconductor," battery.
The main purpose for the CMOS battery is to keep the system time, date and BIOS settings even if the computer is turned off or the main battery dies.
Individual Acer Aspire laptop models differ somewhat, but the general steps are the same when replacing a dead CMOS battery.Preparation
Read through the owner's manual for your particular Acer Aspire laptop to determine what kind of CMOS battery you need.
Purchase the battery through Acer or a local or online computer parts dealer.
Turn the laptop off and unplug it.
Also unplug any external hard drives, cameras or other external devices.
Turn the laptop over (bottom facing up), then touch something metal to remove static charge.
Removal
Remove the Phillips screws that secure the motherboard cover (refer to your owner's manual if necessary), then release the cover from the clips on the bottom of the plastic casing.
Lay the cover aside, then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable, then remove the battery.
Installation
Plug the new CMOS battery cable into the motherboard.
Slide the battery partially under the laptop casing to hold it in place, then align the cover with the slots on the bottom of the laptop housing.
Replace the screws, then turn the laptop back over.
Settings
Plug the laptop in and turn it on.
Enter your BIOS (usually by pressing "F1," "F2," F10" or the "Delete" key) before the operating system loads.
Follow the BIOS prompts or refer to your Acer Aspire owner's manual to reset your time, date and desired system settings.
BIOS Reset
Any time the CMOS battery is unplugged for more than a few seconds, your BIOS will be reset to the default manufacturer settings.
If you make any changes to the BIOS that cause problems with your Acer Aspire, unplug the CMOS battery for 3-5 seconds to correct the problem.
http://support.acer.com/us/en/default.aspx
Acer aspire laptop battery replacement
http://www.youtube.com/watch?v=mQTZ1AUR0uw
Jul 24, 2013 | Acer Aspire 5100 Notebook
My acer aspire 9810 won't boot, only the lights on the board are visible but nothing is desplayed, the VGA card, RAMs and Processros were tested and are working well. Thank you for your help
If its giving out a video signal to an external monitor then most likely the display panel needs to be replaced.If is doesn't show video to the external display then your video card may be bad
Jan 21, 2011 | Acer Aspire 9810 Notebook
I need a motherboard for acer 9810
Go to www.ebay.com type in laptop, your make and model, and motherboard, hopefully you find what you are looking for.
Jan 02, 2011 | Acer Aspire 9810-6829 Notebook
How do I remove acer aspire 9810 keyboard,I have removed the base cover and screen assembly but I cant fugure out how to remove the keyboard Thanks in advance Peter
Jul 15, 2010 | Acer Aspire 9810 Notebook
Cant enter bios
Clear the motherboards CMOS. Be sure to unplug the computer's power cable from the computer, move the CMOS jumper to the "clear" position or remove the battery for a few minutes. Reposition the CMOS jumper and power up the system.
Jun 17, 2010 | Acer Aspire 9810 Notebook
In have a acer 9810 laptop .iv been trying to boot it for three weeks. And iv only just foundout the ideo model name is samsung hm120ji . Can you help please
You have got bad sectors in the hdd so try to clean the bad sectors on it by scanning it by DM it will clean the bad sectors on it
Thanks.
May 20, 2010 | Computers & Internet
Reset bios
You need to open your notebook remove first the battery and all screw at the back of your notebook. You can see there a CMOS battery together with the CMOS jamper. Just read it you can read CLRSCR which means clear cmos, just pull it with in 10 seconds and insert it back. Now you are done to reset bios.
Mar 30, 2010 | Acer Aspire 9810 Notebook
Hi have an Acer Aspire 9815k (9810). Just
Sounds Like a driver issue. Uninstall the Sound drivers in the device manager, and check with the Acer website and download the appropriate drivers for your laptop.
Oct 22, 2009 | Acer Aspire 9810 Notebook
Acer Aspire 9810-6829 Notebook Logo
127 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
