Question about Toca T2300 Castanet Machine
Diagram I need to restring the machine and it wasn't done correctly to begin with
Lap harp from first act booklet
All strings on First Act lap harps are electric guitar G strings with the gauge being .016. These may be found at any local music shop or music retailer. The manual can be found at this link- First Act Discovery FG500 Reference Manual Page 2
Feb 02, 2015 | Music
Violin doesn't stay tuned
This is an intonation issue. If you can find a music store that works with violins, talk to someone there who will certainly be better informed than I am. At least they can tell you if it's worth your time to fix it, or more cost effective to replace it.
Apr 16, 2017 | Music
Roland TD8 has no power
I would try another ac adapter. Plug in that one and stick it on your tounge and see if it bites. It should only be 9-12 volts, just to see if it works. It may have a fuse inside but I doubt it, if you have to replace the adapter, there is a diagram on the back below the plug showing polarity and specs. Voltage must be the same and mA must be as specified or higher. NOT lower except for checking for lights or signs of power. Normal usage would need its requirements or higher. Make sure the + and - are correct to avoid damage.
Feb 20, 2013 | Music
Hi, I have a mackie srm1801 and in the middle of a gig the OL LED came on and wouldn't go off. Input was unplugged and still the light wouldn't go off. After a while the fuse went and now there is no
It is likely that the O/P transistors have blown, especially if the fuse keeps blowing and the O/L led comes on. It's a repair shop jobbie
Nov 30, 2011 | Mackie SRM 1801
I recently bought two Alesis Quadrasynth Plus Pianos, complete, but not funtioning correctly. One looks relatively new, but has a solid white screen and makes no sound when fired up. The other is visually...
Assuming you've tried rebooting the white screen one? If so, You need to take both to a qualified repair man and get the job done right. If you start swapping parts without knowing what works and what doesn't, you risk screwing up the good parts,
May 15, 2017 | Alesis Sr 16 Stereo Drum Machine
Yamaha YPT-410 When playing the keyboard, the sound cuts out when playing multiple keys, and then begins again only to cut out again. Does not matter which keys. I have done a factory reset and it did not...
It's probably your keyboard. Some keyboards are limited with it's polyponic capabilities. Some can play many notes at one time, some cut out when it reaches it's limits. Check your manual for specifications.
Aug 25, 2011 | Yamaha Corporation Of America 61 Key...
I installed my new Roland SD-50 and all worked fine untill it turned off automatically (powersave mode was default). After that computer didn't find the canvas. I decided uninstall driver by hardwares...
You may have to coax it back by unplugging or even trying a different connector on the computer. It may have disabled the port due to a current spike. Using the devoce manager in the windows control panel, see if the port has been disabled. If necessary delete the device and tell it to seearch for new hardware.
Jul 17, 2011 | Cakewalk Roland SD-50 Mobile Sound Canvas
I have recently purchased a set of M-Audio Studiophile BX8a Deluxe studio monitors. I can't register them for warranty because I can't find any serial number on the monitors or box that they came...
Call M-Audio and ask them about it... It is POSSIBLE that your speakers are counterfeit. It has been happening with high value audio equipment. There has been some failures of this product as well. Also contact the company you bought them from. There is a lot of grey market stuff on Ebay... I hope that wasn't your source.
May 30, 2011 | M-Audio Studiophile BX8a Deluxe active...
Toca T2300 Castanet Machine Logo
87 people viewed this question
Top Toca Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Toca Music Expert? Answer questions, earn points and help others
