Question about Maytag M6P09S2B Portable Air Conditioner
Red light flashing
Red flashing light under caution sign.... What is wrong and how can I fix it?
My xbox 360 had one red light flashing and my av jacks did not work so i put the old casing back on and now has 3 red lights
The red flashing lights are a sign of a fault with your console.
firstly if you get the 3 red lights then microsoft reapair your console for free so long as you purchased it no more than 3 years before you send it back for repair. The 3 red lights are a sign of overheating
the 360 motherboard is able to flex a little, when the 360 was turned off and cooled down these solder balls solidified again, however they solidified in the wrong place or in two halfs etc. and so the 360 shows the 3 red lights to indicate this fault.
click here to download repair guide
Dec 15, 2010 | Microsoft Xbox 360 Console
TV won't turn on. Red power light flashing
The red flashing light is a service light. Depending on the number of flashes will tell you what is wrong with the TV. If it's under warranty, time to take it in for service! If it's not under warranty, time to decide if you want to repair or replace. Good luck!
Oct 10, 2010 | Toshiba Televison & Video
Three red lights flashing
If this is your Xbox 360 console you are referring to, then you need a repair. If you are under your 3 year warranty from MS go to www.xbox.com/support to fill out a repair request, otherwise look for someone in your area that has experience repairing the Red Ring of Death.
Jan 03, 2010 | Microsoft Xbox Console
3 flashing red lights x box 360
You need to have the motherboard fixed, do to this you need to take the xbox360 apart then reflow the board.
there is a great 6part video guide on YouTube to view for free. 6 videos from the same fellow, each video is a few mins long, and goes over everything for you.
http://www.youtube.com/user/ohiocitysales#p/u and its free unlike some eBook site.
I actually used the same method to fix over 450 Xbox360 units with no problems at all, barring a few (but i have done nearly 500 so you expect a few problems along the way), you just need a few things though like a heat gun and some thermal paste. sounds hard, but it's very easy once you start!
Hope this helps in some way.
I should also mention that that the 3 red light issue is covered by Microsoft for 3 years from the date of purchase under there extended warranty for 3red light and 1 red light E74 errors. so if your unit is under 3 years old and you have not opened it, then give them a call for free and have your unit fixed for free.
Jan 02, 2010 | Video Game Consoles & Games
Three flashing red lights
If you have the 3 red lights this is because the GPU and the CPU have heat up you need to stop the heat, you can send it in to do this or you can fix it with a good repair guide
Dec 24, 2009 | Microsoft Xbox 360 Console
3 red lights happens because the GPU and the CPU overheat and shut down to prevent damage, you will need to send it in to get it fixed, or you can fix it yourself using a good video guide
Dec 18, 2009 | Microsoft Xbox 360 Console
I have 3 red lights flashing and my disk tray gets stuck
when u have 3 red flashing lights its called RROD or red ring of death. u have a 3 year warrenty on that so just sent it in and for the disk problem, if u still have ur warrenty , you can just send it in so they can fix it.
Dec 08, 2009 | Microsoft Xbox 360 Console
Won't turn on, power button goes red, yellow, then flashing red??
it probably overheated if the fan doesn't come on if its under a year old call sony for warranty repair they will send you a box and pay for shipping and everything if it isn't under warranty anymore sony will still fix it for 149.00 includes shipping
Jan 06, 2009 | Sony Playstation 3 (PS3) Console
Red flashing light under passenger airbag sign.
The flashing red light that looks like a car is the "Security Indicator". This flashes when the vehicle is switched off, to alert potential theives that the 4Runner has an Anti-Theft system installed. Do not worry about it, the flashing is quite normal, and the bulb is really a Diode, and it will not drain the battery.
I hope this has answered your question.
Thanks for choosing FixYa to anser your question.
Dec 01, 2008 | 2008 Toyota 4Runner
Maytag M6P09S2B Portable Air Conditioner Logo
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
