Question about Nikon Coolpix 5600 Digital Camera
Will my Coolpix 5600 be able to use a 2GB SD card? Spec says only tested to 1 GB.
SOURCE:
  • 3 Answers
SOURCE: Coolpix 5200 + 4GB SD card
Any size SD card will work. The capacity limit is with the card, not the camera. All the camera does is serve as a recorder/reader for the card.
Posted on May 13, 2008
robmcd27
  • 423 Answers
SOURCE: nikon coolpix L11
I'm sorry but you can't use the camera as a webcam. Here is why. There is no function on the camera to stream video.
Also, the camera goes into standby mode after 30 seconds (by default). And 3 minutes after that, it shuts off completely. It does that to save batteries. Again. I'm sorry. Good webcams average between $20. to $50. usd and they are made to work 24 hours a day 7 days a week.
You can use a 4GB memory card in your camera, as long as it's an SD card.
If you get that message, it means you haven't formatted the card for use in that camera. You have to format the card in the camera before you use it.
Even though the solution was not what you prpbably wanted, don't let it stop you from rating it a fixya. I would appreciate it. Let me know if I can help you with anything else, and thanks for coming to FixYa.
Rob
Posted on Feb 23, 2009
SS PAI
  • 55 Answers
SOURCE: new nikon coolpix s570. sd card is not uploading
Use a good antivirus software to scan the SD card. Your SD card could be infected.
Hope this helped.
Posted on Jan 05, 2010
  • 1705 Answers
SOURCE: My Coolpix 4200 does not recognise SD cards
Try re-formatting the card. It should be one of your camera menu options.
If that doesn't work, buy or borrow another card and try that. If a new card doesn't work you've a camera problem.
If its a camera problem, I'd try the Nikon web site, follow links to support and/or downloads to see if there's a firmware upgrade for the camera.
Posted on May 02, 2010
  • 102366 Answers
SOURCE: Nikon Coolpix 5900/4 GB Kingston SD Card
The 5900 uses SD cards. The 4GB card you have is actually an SDHC card and will not work in the 5900. You'll have to stay with cards 2GB and smaller.
Posted on May 19, 2010
Camera will not recognize a SanDisk SDHC Card, 4 GB
The Coolpix 3200 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible. You need to use SD cards, 2GB and smaller.
Feb 04, 2011 | Nikon Coolpix 3200 Digital Camera
Is the memory card removale
Yes, the memory card is removable. The following web site gives different cards.
http://support.nikonusa.com/app/answers/detail/a_id/16778/~/approved-sd-cards---coolpix-s4000
The following is a list of approved memory cards for the Coolpix S4000 digital still camera. These cards have been tested and approved for use with the Coolpix S4000.
The S4000 uses SD (Secure Digital) memory. Memory cards with an SD Speed Class1 Memory of 6 or faster are recommended for recording movies. Movie recording may stop unexpectedly when memory cards with a lower Speed Class rating are used.
SanDisk 2GB2, 4GB3, 8GB3, 16GB3, 32GB3 TOSHIBA 2GB2, 4GB3, 8GB3, 16GB3, 32GB3 Panasonic 2GB2, 4GB3, 8GB3, 12GB3, 16GB3, 32GB3 Lexar 2GB2, 4GB3, 8GB31 Specification defining minimum data transfer speeds for SD and SDHC memory cards.
2 If the memory card will be used with a card reader or similar device, check that the device supports 2 GB memory cards.
3 SDHC Compliant. If the memory card will be used with a card reader or similar device, check that the device supports SDHC.
Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
Jan 06, 2011 | Nikon Coolpix S4000 Digital Camera
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
Sep 30, 2010 | Nikon D60 Digital Camera with 18-55mm lens
How do i format my 1GB SD CARD FOR COOLPIX 5200 CAMERA
Insert it into the camera
call up the menu on the camera for the settings
select prepare card (format)
Takes about 20-30 seconds for most 1-2 Gb cards
Sep 16, 2010 | Nikon Coolpix 5200 Digital Camera
May 19, 2010 | Nikon Coolpix S210 Digital Camera
Camera works with standard SD memory card, but not SDHC
There are hardware incompatibilities between SD and SDHC cards. They're upward compatible in that SDHC devices will accept SD cards but not the other way around. You will have to hunt down SD cards, 2GB and smaller.
Apr 28, 2010 | Nikon Coolpix L1 Digital Camera
It says this card cannot be used. what is the biggest sd card i can use?
The S1 uses SD cards. SD cards top out at 2GB, any larger cards are actually SDHC (Secure Digital High Capacity). SDHC devices will accept SD cards, but SD devices will not accept SDHC cards. They will fit physically but not electronically.
In fact, the S1 manual does not list any cards larger than 1GB.
Jan 26, 2010 | Nikon Coolpix S1 Digital Camera
Bying a new SD-card and wondering how big can it be...
You should be able to use SD cards up to 2GB. Don't go any larger; those are SDHC cards and will not work in the L4.
Dec 22, 2008 | Nikon COOLPIX L4 Digital Camera
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
May 07, 2008 | Nikon Coolpix 4600 Digital Camera
Incompatiblity of R300 & Toshiba 2 GB SD Memory Card
Epson Printers & All-In-Ones:
MEMORY CARD TYPE MAXIMUM CAPACITY TESTED Compact Flash 4 GB Secure Digital 1 GB Sony Memory Stick 1 GB MagicGate Memory Stick 128 MB xD Picture Card 512 MB Smart Media 128 MB
These are the Epson tested memory cards that will work, also includes the suported memo capacity..
Hope this is helpful, pls dont forget to rate solution.
Apr 08, 2008 | Epson Stylus Photo R300 InkJet Printer
Nikon Coolpix 5600 Digital Camera Logo
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
