Question about ixl.com Computers & Internet
Download cheat 1 pint times 93 = quarts pints Submit
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • ixl.com Master
  • 102,366 Answers
93 pints is 46 quarts and 1 pint.
Posted on May 03, 2013
  • Muna Alzuhairi Apr 12, 2015
    Thnx but hw do i do it
What equals 48 ounces??
Hi Yesenia
There are a couple of possible answers, depending on whether you're talking about liquid ounces, or weight ounces.
For liquids, there are 8 fluid ounces in a kitchen '1 Cup' measuring cup. That means 48 fluid ounces are the same as 6 cups, 3 pints (2 cups per pint) , or 1-1/2 quarts (two pints per quart).
For weight, there are 16 ounces in a pound. (One fluid ounce of water also weighs one weight ounce, which is the basis of the adage 'A pint's a pound, the world around', since a pint is 16 fluid ounces, and 16 fluid ounces of water, or near-water like some beer, will then weigh a pound' ).. Anyhow, in this case, 16 goes 3 times into 48 ounces, so it will weigh 3 pounds.
For metric, 2.2 pounds per kilogram, or 29.5735 milliliters per fluid ounce.
Cheers!
Nov 18, 2015 | Office Equipment & Supplies
How many pints in a court?
Do you mean pints in a QUART? A quart (amazingly) is one quarter of a gallon and there are eight pints in a gallon, so a quart is two pints.
Mar 03, 2015 | Cars & Trucks
Need recommended Fluid specs and amounts to change oil for 1996 Toyota Tacoma 4 wheel drive front and rear axles
Hello there,
From this page https://www.worldsbestoil.ca/product-cross-reference.php?year=1996&make=TOYOTA&model=TACOMA&engine=2.7L&vin=1
Extract.......
.Engine, 2WD, with filter - 5.4 quarts [1]
Engine, 4WD, with filter - 5.3 quarts [1]
Cooling System, Initial Fill - 9 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, A340E Initial Fill - 1.7 quarts
Automatic Transmission, A340F Initial Fill - 2.2 quarts
Automatic Transmission, A43D Initial Fill - 2.6 quarts
Automatic Transmission, Total Fill
4 speed A340F - 10.4 quarts
4 speed A340E - 7.7 quarts
4 speed A43D - 6.9 quarts
Manual Transmission, - 5.3 pints
Differential, With ADRD Front - 2.6 pints
Differential, Without ADRD Front - 2.4 pints
Differential, 2WD Without LSD Rear - 6 pints
Differential, 4WD Extra Long Rear - 4.5 pints
Differential, With LSD Rear - 6.4 pints
Differential, Standard Rear - 6 pints
Transfer Case, - 2.2 pints\'
Sep 13, 2014 | 1996 Toyota Tacoma
How many qts of oil do i need
Depends on your engine.
1980 JEEP CJ-7 2.5L 4-cyl Engine Code [B]
CAPACITIES
Engine, GM without filter..........2.4 quarts[1]
Wix Filter ........ 51040
Cooling System, Initial Fill..........8.0 quarts
Automatic Transmission, A904, 30RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, A999, 32RH Initial Fill..........4.0 quarts[2]
3 speed A999, 32RH..........8.4 quarts
3 speed A904, 30RH..........7.0 quarts
Manual Transmission, 4-SPD, SR-4..........3.0 pints
Manual Transmission, 4-SPD, T176..........3.6 pints
Differential, Front..........2.5 pints[3]
Differential, Rear..........4.9 pints
Transfer Case,..........4.0 pints
1. Add extra oil when replacing filter. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all gears.
Check fluid level in NEUTRAL and add fluid as needed.
3. 1984-1992 Models with command-Track, add 5 oz of 75W-90 GL-5 to shift motor housing opening.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission T176
Fill Plug.....15 ft-lbs
Drain Plug.....15 ft-lbs
Manual Transmission SR4
Fill Plug.....20 ft-lbs
1980 JEEP CJ-7 4.2L 6-cyl Engine Code [C]
CAPACITIES
Engine, without filter..........5.0 quarts[1]
Wix Filter..... 51522
Cooling System, Initial Fill..........11.0 quarts
TORQUES
Oil Drain Plug.....30 ft-lbs
1980 JEEP CJ-7 5.0L 8-cyl Engine Code [H]
CAPACITIES
Engine, without filter..........4.0 quarts[1]
Wix Filter..... 51258
Cooling System, Initial Fill..........13.0 quarts
TORQUES
Oilman
Feb 02, 2013 | 1984 Jeep CJ7
What type of Dana is in the rear of the 98 4cyl wrangler
Engine, with filter..........6.1 quarts [1]
Cooling System, Initial Fill..........10.6 quarts
Automatic Transmission, 30RH Initial Fill..........4.1 quarts
Automatic Transmission, 32RH Initial Fill..........4.1 quarts
3 speed 30RH..........7 quarts
3 speed 32RH..........8.6 quarts
Manual Transmission, AX-5 2WD..........7.4 pints
Manual Transmission, AX-15 2WD..........6.8 pints
Manual Transmission, AX-15 4WD..........6.8 pints
Differential, 181 FBI Front..........2.6 pints [2]
Differential, With 194 RBI Rear..........3.6 pints
Differential, With 216 RBI Rear..........4.1 pints
Transfer Case, 242..........3 pints
Transfer Case, 247..........3.4 pints
Transfer Case, 249..........3.4 pints
Transfer Case, 231..........2.2 pints
Feb 14, 2011 | 1998 Jeep Wrangler
What is the fluid capacity of the gear oil in a 1997 nissan 5 speed 2 wd truck
CAPACITIES
Engine, 2WDwithout filter..........3.5 quarts[1]
Engine, 4WDwithout filter..........4.0 quarts[1]
Cooling System, Initial Fill..........8.5 quarts
Automatic Transmission, Total Fill..........7.4 quarts
Manual Transmission, 2WD..........4.2 pints
Manual Transmission, 4WD..........8.4 pints
Differential, 2WD Rear..........3.2 pints
Differential, 4WD Rear..........2.7 pints
Differential, Front..........2.7 pints
Transfer Case,..........4.6 pints
TORQUES
Oil Drain Plug.....22-29 ft-lbs
Transfer case
Fill Plug.....18-25 ft-lbs
Drain Plug.....18-25 ft-lbs
Manual Transmission
Oct 17, 2010 | 1997 Nissan Pickup
How many quarts of transmission fluid goes in a 2000 ford explorer /
Hello there
abar_a.gif?v=72006
2000 FORD TRUCKS EXPLORER 5.0L 8-cyl Engine Code P
FILTERS
AMSOIL Ea Oil Filter.........EAO11
Wix Oil Filter.........51372
AMSOIL Ea Air Filter.........EAA122
Wix Air Filter.........46253
Wix Fuel Filter.......33595
Wix Trans Filter.....58955 [1]
[1] 4R70W
CAPACITIES
Engine, with filter..........5.0 quarts[1]
Cooling System, Initial Fill..........15.0 quarts
Automatic Transmission, Others Initial Fill..........3.9 quarts[2]
Automatic Transmission, 4R70W Initial Fill..........5.0 quarts[2]
4R70W..........14.0 quarts
2wd ..........10.0 quarts
4wd ..........10.0 quarts
Manual Transmission, ..........5.5 pints
Differential, Rear..........5.7 pints[3]
Differential, Dana 35 Front..........3.6 pints[4]
Transfer Case,Full-Time 4WD..........2.7 pints
1. When refilling, remove dipstick to provide adequate venting and allow oil to flow into crankcase.
2. With ENG at operating temperature, shift through all gears. Check fluid level in PARK and add fluid as needed.
3. Fill to no more than 1/4 to 9/16" below fill plug hole.
4. Fill no higher than 9.5 mm or 3/8" below fill plug.
Aug 07, 2010 | 2006 Ford Explorer
What kind of ATF goes in my 1992 cherokee?
Use ATF+4
Do not use Dexron or Mercon
Aug 08, 2009 | 1992 Jeep Cherokee Sport
Transmission light on, but no problems with the transmission, is the fluid low?
Hard to know. You fill it to the fill mark. If it is 2 quarts low, put 2 quarts in it. 1 pint, add 1 pint.
May 29, 2009 | 2002 Dodge Durango
What;s the oil capacity for a 2002 chevy trailblazer 4.2 6 cyl?
Here are the Fluid CAPACITIES & MORE:
Engine, with filter..........4.6 quarts[1]
Cooling System, Initial Fill..........12.0 quarts
4 speed 4L60, 60E..........11.0 quarts
Manual Transmission, NV1500..........5.7 pints
Manual Transmission, NV3500..........4.2 pints
Differential, with 8.6 ring gear Rear..........4.0 pints
Differential, with 7.25 ring gear Front..........2.5 pints[2]
Differential, with 8.25 ring gear Front..........4.2 pints[2]
Differential, with 9.25 ring gear Front..........5.9 pints[2]
Differential, Rear..........4.0 pints
Transfer Case,BW4472..........2.5 pints
Transfer Case,NV136/236/246..........4.0 pints
Transfer Case,NP207..........4.6 pints
Transfer Case,NP231, NP233..........2.3 pints[3]
Transfer Case,NV231/233..........2.1 pints[3]
1. After refill check oil level.
2. Do not use synthetic lubricant in axles using RTV sealant.
Synthetic lubricant will chemically atack RTV sealant.
3. Identification: check tag on case.
Apr 13, 2009 | 2002 Chevrolet TrailBlazer
Computers & Internet Logo
995 people viewed this question
Top ixl.com Computers & Internet Experts
paulgbrandon
Are you an ixl.com Computer and Internet Expert? Answer questions, earn points and help others
