Question about Iwill P4ES Motherboard
Stop opperation after 4 years my pc mother board (iwill)stop opperation and power led and restart led are on every time and no noise hear from chasis
    Scholar:
  • 125 Answers
Does the PSU fan run? If not, try removing and reseating the RAM and any cards you have in there, and give it all a good blow down while you are there.
Posted on Aug 09, 2007
    Novelist:
    Champion:
  • 231 Answers
Hi, it sounds to me as though your PROCESSOR has failed, If you are confident enough, then remove it and try another one. If you can't do this then take the processor to your nearest computer repair person and ask if he/she will test it in a board for you. Regards mistyman
I need ntv3200 s LED .nikai tv mother board,whare iwill get
You must go directly to the manufacturer for this part. You have to send your TV into their shop and they will replace it. The part is too static sensitive to handle by normal hands, a professional to handle the installation process.
May 16, 2015 | Iwill Computers & Internet
I cant find where do i connect power switch there no slot indecated on the board help me pls.
Hello Friends,
If you are ask mother board power option. There are two power option every mother board, one option is SMPS power and sec option is Power Jumper. SMPS two power socket indicate 24 Pin and 4 pin also same option 24 pin and 4 pin socket available in mother board. Second option is 9 pin jumper socket hear connect to HDD power, reset power, cabinet power, power LED, and +5v DC. So you open PC and see all section and solved you problem.
Thanks.
Aug 22, 2013 | Gateway Computers & Internet
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sony vaio pcg-k33p Won't power up
I had one with the same symptoms, the way i fixed it is by taking it all apart and resolder the system chasis grounds on the mother board, then reseting the motherboard's memory battery. A bit complicated for those with little knowledge on computer repair. You may have to take it to a computer shop, or try fixing it yourself. It took a while to figure it out.
Feb 11, 2010 | Sony VAIO PCG-K33P Notebook
TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
May 21, 2009 | Sony KV-29FX30 29" TV
Pwr/slp/msg led not glow but the hdd led is always on
hi im josh in cebu phils. may i help you? not open or no boot. If it doesn't boot or power on and no prsence of current on your pc. The main problem is motherboard. it may be no current is running on the board.because the supply chord was lost or not enough supply to make the motherboard execute.check if your power cable 16 pins is connected and the 4 pins 12 volts power support.if it loosen thats the problem. Sometimes the compatibility of your processor and the mainboard is needed.if both of these is for the first time check the compatibility of the mainboard and the processor in your support manual. good luck!
Feb 20, 2009 | EliteGroup P4M800-M7 Motherboard
I am looking for the manual for the DVD266-r
Here you go
http://www.motherboards.org/mobot/manuals/IWill/DVD266-R/
post again if you have any more to ask.:)
Remember to rate Ty
Jan 09, 2009 | Iwill Computers & Internet
PC won't 4power on.
Failures in the motherboard, memory, or any installed card could cause that symptom. All I can suggest based on the above information is remove memory one piece at a time and retest, remove/reseat video card if you have one, and attempt to reset the CMOS using the jumper on the board. You might also try removing the battery on the board and unplugging everything, then attempt to reboot.
Jan 03, 2009 | Acer Aspire™ T180 PC Desktop
PC build problem I am building a pc with a IWill SDVD266u-RN motherboard. I have installed all new components but the pc wull not start. There is no indication that the mother board is geting any power. I...
DO YOU HAVE A MOTHERBOARD MANUAL?.Are you sure you have power to the correct plug in on the board?some boards require more tahn one plug in.http://www.computerhope.com/comp/iwill.htm.http://www.computerhope.com/help/mb.htmhttp://www.computerhope.com/help/mb.htm#support.These links will help.I can be of further help if you have the need.RICHARDM69
Jan 03, 2009 | Computers & Internet
New Computer Wont Boot!
when you say "the fan makes a noise like its getting ready to spin", which fan...power supply's or cpu? if you answer power supply, then the POWER OK signal is not returning to power supply and it then quickly shuts down to prevent further damage. double check a firm connection to mother board. If you answer CPU, then it becomes far more complicated. Try re-seating the memory chips.
Jun 05, 2007 | Systemax Venture PC Desktop
Iwill P4ES Motherboard Logo
Top Iwill Computers & Internet Experts
Alun Cox
David
David
Nathaniel Berrios
Nathaniel Berrios
Are you an Iwill Computer and Internet Expert? Answer questions, earn points and help others
