Lanier ld360 How to stop a print job when in process and if number of copies requested is way too high?
5 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: HP Laserjet 4050 hangs on processing job
Unplug printer cable.
turn off
turn back on and wait for READY
turn off
connect printer cable
turn on
Posted on Jan 05, 2009
ChobPT
  • 220 Answers
SOURCE: HP 4250 WILL ONLY PRINT 1 COPY OF A PRINT JOB WHEN
that problem is easily solvable with a driver update.
HP has released a driver package do fix that issue
Posted on Jun 22, 2009
seeker5211
  • 1089 Answers
SOURCE: I have a HP 4000 connected to my laptop via
Go to www.hp.com/#support
download the latest PCL5 drivers.
while you are there, download the latest firmware.
Posted on Jan 08, 2011
  • 3 Answers
SOURCE: I have a Lanier (Ricoh)
download latest print driver and within printer properties, change from spool job to print direct to printer.
Posted on Jul 26, 2011
How can I get A Lanier LD-620C parts manual
The LD-620 appears to be a Ricoh Aficio MP-C2051 or C2551.
You should be able to find a parts list on the net. Whichever one looks the same as your lanier (who don't make anything) will be the one.
Good luck
Oct 03, 2014 | Lanier Office Equipment & Supplies
Document will not print; status reads deleating-printing; printer appears to be frozen; does not print any other items...
Kill the job on computer that sent the print job. If the job fails to clear you can stop and start the print spooler
Right click My Computer > Manage > Services.
Right click Print Spooler > Stop then Start. That should clear the job.
Same principle pertains to a network printer, but needs to be done print server.
Sep 24, 2012 | Lexmark International Lexmark 8300 Series
HP Lazer 4300dtn keeps trying to print from tray 1. How can I set the default to tray 2?
Selecting which tray is used for printing
You can select how the printer pulls paper from the trays.
Understanding tray order
When the printer receives a print job, it selects the tray by trying to match the requested paper
type and size with what has been loaded in the trays. Using an "autoselect" process, it searches
all available trays for the paper that satisfies the request, starting with the bottom tray and ending
with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/
size.
Note The "autoselect" process occurs only if no specific tray is requested for the job. If a specific tray
is requested, the job prints from the requested tray.
 If paper is loaded in tray 1 and tray 1 is set TRAY 1 TYPE=ANY and TRAY 1 SIZE=ANY on the
Paper Handling menu, the printer will always pull paper from tray 1 first. See "Customizing
tray 1 operation" on page 47 for more information.
 If the search fails, a message appears on the printer control panel display requesting that
you load the correct paper type/size. You can load that paper type/size, or you can override
the request by selecting a different type/size at the printer control panel.
 If a tray runs out of paper during a print job, the printer automatically switches to any tray that
contains the same paper type/size.
The autoselect process changes somewhat if you customize tray 1 operation (as explained in
"Customizing tray 1 operation" on page 47) or set tray 1 for manual feed (as explained in
"Manually feeding paper from tray 1" on page 49). See if this works. Good luck !
Jan 08, 2011 | Computers & Internet
Lanier ld 435 color print code sc548
re install fixing unit and do the sc reset. press clear mode 2x 107 press clear/stop until COPY SP appears press Copy Sp then exit, turn off machine then on after 5 to 10 seconds
Aug 23, 2010 | Lanier Office Equipment & Supplies
Lanier MPC 3000 copier won't print faxes
Try opening up your web browser and type in the ip address of your lanier.
You should to access the facsimile function located on the left side. Once youre in the facsimile function, you should see a thumbnail view of the faxes stored in your lanier. Simply click on the faxes and delete them.
Sep 22, 2009 | Lanier Office Equipment & Supplies
Bizhub 250 slow to print files
When you ask to print the page are you asking for more the one copy? If you are there is a collate check button next to the requested sets box, in the print dialog box. Make sure its not check. Collating the print means your PC sends a copy of the file for each requested copy. IE: you print one page and ask for six copies, your PC sends the file six times, one copy of the file for each print requested.
Also because your printing from a windows application IE: Excel you should be using the PCL print driver as apposed to a PostScript print driver. The time it takes to convert the file into PostScript for the printer to process it is time consuming.
May 08, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Dark copies with overprinting
Cleaned the coronas as per instruction book. Done this before but this time it made a difference.
May 07, 2009 | Lanier 1205 Copier
Canon IR7105 Photocopier
Hello tophams,
I wish I had a magic wand to help you...but the answer is YES! You can fully control the priorities of how the 7105 handles printing/copying/scannng requests. I truly understand your dilemma, it is merely a matter of how the device has been configured. You can program the device to give priority to copies, which will cause print jobs to wait in the que until your copies are done. You can have the print jobs sent to a "mailbox" so that the person requesting a print job will have to walk up to the device and "summon" their print job. There are so many ways to help you with this. You will have to get "THE BOOK" out. I can't type all of the options available to you.
Jul 03, 2008 | Canon NP 6551 Black and White Copier
Will not print multiple collated two sided publications without individually sending each job
I would try changing the driver you are using. There are multiple drivers and it really sounds like that will resolve your problem.
For the drivers go to Xerox.com.
on the tool bar select Support and Drivers.
Then enter your printer number, being phaser enter phaser 7300 in the search .
Select your operating system and there will be PS and PCL drivers.
I am 99.9 percent sure the issue is in the driver.
Dec 26, 2007 | Xerox Phaser 7300DN Laser Printer
k24674
