Question about Echo Garden
Factory carb settings
I have an cs-3450 type 1e what are the carb H L factory settings
3 Suggested Answers
  • 4088 Answers
SOURCE: Yes I have a echo CS-3450 type 1-E and have to
Check the fuel lines for decay or other damage. Make sure the muffler is not plugged. If the jet screws have slot heads, turn the H jet screw CCW somewhat until the engine 4-strokes at speed, but immediately 2-strokes when cutting. If the engine lags behind the throttle when accelerating, turn the L jet screw CCW about 1/8 to 1/4 turn. Hope this helps!
Posted on Oct 30, 2010
  • 2239 Answers
SOURCE: I have an Echo CS-3450 16" Chain saw that starts
This is classic fuel starvation, it needs to run a little rich when free running, when it goes under load it needs the extra fuel to keep it going, if you have replaced the fuel filter, and the fuel hoses are good ( no leaks, or cracks in the pipe, give the pipe a tug to see if fuel squirts out ) then there is dirt in the main fuel screen under the pump diaphram, remove the carb, remove the alloy pump cover, normally held with a single screw, under here will be a gasket, and a pump diaphram, in that order, pressed into the carb is a very fine screen, this should be replaced, or at least cleaned, check the condition of the diaphram, this should be supple not hardened, rebuild and try again, the H screw on the side of the carb controls fuel to the main jet, if need be increase ( screw out ) 1/4 turn.Somewhere from the tank will be a breather, this allows air into the tank to stop a vacume occuring, to check this slacken the filer cap when the machine starts to die, if it picks up again it is a breather issue.
Posted on Jul 18, 2011
Chainsaw only runs with choke wide open??
If it is a saw that has electronic ignition like some of the newer Husky or Stihl models then take it back to the dealer - they have had loads of problems with the electronic control modules. If not then it sounds like either the fuel filter and / or air filter needs changing or there is muck in the carb that needs cleaning out. It is best to blow the jets in the carb through using compressed air if you can.
Jan 11, 2015 | Echo Cs300 Cs 300 3000 345 3450 Choke...
Clutch removal tool?
not recommended, if you use a impact the end of the crank and bolts and nuts are small you can snap off the bolt or worse snap the crank end
also many drums are held on with a snap ring and then the clutch can
be held in place with a both or nut on the end and there may be set screws on some models as well
as in most saws the drum and sprockets are what wear first, normally you can just replace the drum and sockets before you have to replace the entire clutch assembly, so if you have never replaced the drum or sprokets before once you remove the drum if the clutch spring is not broke, just replace the drum and sprocket will save you a bunch of money
Mar 09, 2014 | Echo Garden
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
I have an Echo CS-3450 model... The throttle trigger has become disengaged somehow. When I depress it, no reaction from the engine or bar. Any ideas how to fix it?
the trigger is connected to the carb with a linkage rod. it has probably come off. usually you will need to disassemble the saw to get to it. not a easy job. some times best to take it to a shop
Feb 12, 2011 | Echo Garden
Where is the carbuerator on a 1993 toyota corolla?
if the engine is a 2E type,then it will have a carb directly under the aircleaner on top of the engine.there a 2 types of carb basically on this model,one is conventional type venturi,the other has a bell shaped body lying sideways.If the model is an FE or AG type engine,then it is fuel injected,no carburettor,the aircleaner will be off to one side of engine,connected by a long air duct.check engine/model ID plate usually on the rear firewall for engine code.eg:1E,2E,3AFE,4AGE etc
Feb 09, 2011 | 1994 Toyota Corolla
Echo cs-3400 wont start . no spark. what are the primary and secondary coil readings?
if you have no spark
check for faulty plug 1st, then pull kill wire off at kill switch, then check for grounding ht lead ,
then pull kill wire off at armature , if still no spark most likley faulty ignition armature
i suspect the part number you need if its type 1 is 15662639130
replace it and set air gap and reassemble and test
here is web site for parts
http://www.ereplacementparts.com/echo-cs3400-type-chainsaw-parts-c-35043_35970_36021.html
or you could try www.partstree.com , go to echo saws , then find your model
cheers hope it helps
pauly 46
Jan 28, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Yes I have a echo CS-3450 type 1-E and have to work the throttle just to keep it running.changed the fuel filter,sparkplug,gas ratio 40:1
Oct 30, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Open Questions:
Garden Logo
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
