Question about Gateway FPD2275W LCD Monitor
Monitor Goes Black
My Monitor On hte computer is on and the light on the power is blue like its on but theres no picture on the screen its just grey. When the computer first starts you see the gateway and the windows xp start up things but when the computer starts the screen goes grey
  • 1 more comment
  • ATLmidtown Nov 19, 2007
    I have the same Sony monitor and the same thing happened but my screen isn't gray it goes black. If I hit the green power button to turn it off... when i turn it on it's stays in for about 5 seconds then goes black again. I am now using my TV as a monitor and it works fine so it's definitely the Sony monitor that has the issue. I've seen a few other troubleshooting blogs that mention the inverter board but when I call Sony parts they have no clue what i'm talking about. Has anyone had this same problem that has resolved it???
  • mbhs1578 Jul 09, 2008
    I have a similar issue with my Gateway LCD monitor, after only 14 months use, It just goes grey with the blue power light on, and regardless of where I plug it into, same results. Called Gateway support, and they also eluded to me buying another one , would not even provided service options. This model does not use the standard power cord, so to rule out the power cord, I would have to purchase one from them. If anyone has stumbled into a solution, the help will be much appreciated.
  • rebornmusikg Sep 25, 2008
    my screen just goes grey as well. please help me with this problem. thanks
Every now and then I inadvertently push a button on the lower right side of the monitor that causes the display to go blank as if it has stopped receiving a signal from the computer. Unfortunately I can not recall what the settings or buttons are that are involved, but I suspect it is the top or bottom button. Each time it happens I rediscover which button it is using trial and error. Eventually I push a button several times to 'scroll' through what I *think* are display input options. The normal desktop appears with one of the options. I think the button might be the one that includes the PIP option on the menu.
Posted on Aug 27, 2007
  • 98 Answers
Try to start in safe mode and check if you can change some of the video settings (resolution, refresh rate, etc). Maybe one of these settings is such that the monitor cannot handle properly. To get into Safe Mode, press F8 as soon as you see the Gateway logo on the screen while booting the PC.
Posted on Aug 09, 2007
SOURCE:
I recently bought a Hp Lcd w1907 Monitor off craigslist, the screen worked fine for about an hour then went black, button stays blue. Now every time I power on the monitor it stays lit for 3 seconds...
hi the cause is screen back light not working properly. you need to remove the back cover of the monitor to access the internal part of the monitor. then look for the connector of the cold cathode fluorescent tube back light going to the power inverter board of the back light you will noticed a dry joints which cause a loose connection that is why you hear a sound that cause of spark. you need to re soldered the connector or replaced if totally burned.
Nov 08, 2012 | HP w1907 LCD Monitor
Recently when I boot up my computer I get the monitor to display an image for about 2 seconds and then it goes to a black screen. if I unplug the monitor from the back of the computer and plug it back in,...
The capacitors for the power source are failing. This causes a short burst of power to get to the lamps, but then they cannot hold a charge to continuously power the lamps. You will have to replace the monitor. I suggest checking your warranty status and replacing the monitor.
Jul 19, 2011 | Gateway FPD2275W LCD Monitor
Viewsonic monitor vx2035wm goes black with a steady blue light on power button when the monitor is turned off or computer is restarted. Disconnecting it and letting it sit for a minimum of 24 hours makes...
I've been having the same problems with my Viewsonic.I plug it in and the blue light blinks but there's no picture it's just a black screen.I do know if Viewsonic doesn't repair my monitor I'll never buy anything from them again.I have the LCD Viewsonic 22' Vx2235wm monitor.
Does anyone have any idea what could be wrong with mine?I've bought a new video cable & video card but the monitor still does the same thing?Thanks
Oct 29, 2010 | ViewSonic VX2035WM LCD Monitor
The l226wtq goes black
Try shining a flashlight on the screen, or without the flashlight, try to see if you can distinguish anything on the screen at all, if you do, the backlight is dead, or the monitor has an internal most likely unfixable problem.
May 01, 2009 | Computers & Internet
Monitor Goes Black
There are defect at the main board.
Try checking the capacitors.
Apr 24, 2008 | Mag Innovision LT776s 17" LCD Monitor
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
Gateway FPD2275W LCD Monitor Logo
685 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
