Question about Kitchen Appliances - Others
Toaster 2 slice delonghi CT02R toaster
What kind of a screwdriver do I have to by to open the toaster. It is a 6star shape screw, but with a small pin in the middle, and due to this pin I can't open it!!! thank you
  • 3 Answers
SOURCE: tfal 2-slice toaster repair
look inside your toaster. there must be something inside it turn it down and see if something comes out.. if nothing is inside then try to see if the cord that you switched on is not broken. if you see a liitle bit scratch mark on it- switch off. You can get a electric shock. it is your favorite toaster so try to consult a electricion to fix the cord for you.
Posted on Feb 27, 2008
  • 32 Answers
SOURCE: Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Jun 05, 2008
cactus bob
  • 267 Answers
SOURCE: Sunbeam 3831 Toaster (2-slice) -- toast/carriage won't stay down
great ! its a great fealing when you save a appliance from the junkyard .
Posted on Apr 03, 2009
SOURCE: the toaster does not work but the egg portion does
Call the company. They will send you a new one. At least they did for my neighbor.
Posted on May 28, 2009
SOURCE: T-Fal Avante Bagel Tpaster - 4 slice
Energized coil (Magnet) which holds down lever mechanism may be coated and in need of scraping for it to make full contact
Posted on Aug 31, 2009
De Longhi CT021.A x 2 slice toaser - Won't stay down
Is it plugged in. You may have to do a little handy work, unplug the unit and look to see where it catches when the handle is in down position, you may have to open the bottom door. There is a little catch when the handle is down it may need to be bent a little not much.
Oct 15, 2012 | DeLonghi RT200 Retro 2-Slice Toaster
I am trying to repair a Sunbeam Model T-35 radiant control toaster. Everything is working but I can't seem to get the timer control (for setting light and dark) set correctly. Is there some...
I have/had a similar problem. Here's how I fixed it.
UNPLUG THE TOASTER
1. Clean the crumbs out throughly. I removed the bottom of the toaster (6 screws) to make sure all the debris was removed. Use a soft brush. Replace bottom and tighten screws. 2. Gently brush the sensor area in the 'one slice' slot with a soft brush. 3. Remove 'darker-lighter' knob. I gently pried mine off with a small screwdriver. 4. Plug toaster in. 5. Put a slice of your usual bread in the 'one slice' slot. 6. Watch it toast. 7. When 'done' to your liking slowly rotate the control counter clockwise using a small screwdriver until the toaster stops toasting. 8. Replace knob with the pointer at the mid point (up and down) to allow for minor adjustments.
Aug 18, 2011 | Sunbeam Vacuums
4 slice toaster when pressed down to start toaster they won't stay down.(either side) Yes I have it plugged in
Try cleaning the bread crumbs out of it. If you get enough piled up under the latch mechanism, you can't push it down far enough to engage it.
You may be able to do an adequate job by opening the bottom cover - most toasters are made so it's easily removed for this very purpose. If not, you'll need to pull off the knobs and remove screws so you can take off the top cover. Be careful not to touch the heater wires with any tools - after they've been used a while they become rather brittle and break easily, and even a scratch can cause them to erode and fail. I assume you know to unplug the toaster before working on it.
Jan 06, 2011 | DeLonghi RT400 Retro 4-Slice Toaster
I am trying to take apart the toaster, but am having problems figuring out how to. On the bottom I removed the cord clamp and there is a black plastic piece on the bottom that appears to be a snap, however...
You need to remove the four rubber feet at the four corners, and that's where the screws are. Get a small flathead screwdriver and pry the rubber feet out of their sockets and you'll see small screws.
Jul 06, 2010 | KitchenAid KTT340 2-Slice Toaster
What kind of screw head is the star shaped one on tefal toaster
If its star shaped it's a Torx. Is there a small protrusion in the center of the star?
That would be a "Security Torx" screw and requires a special Torx bit... one with a hole in the center.
These are readily availble in most tolls supply places such as Sears
Apr 03, 2010 | Kitchen Appliances - Others
The lever doesn't stay down anymore, what should I do?
It sounds like the latch is broken. Unless you are very comfortable opening appliances and know very well what you are doing, it is best to have the toaster replaced. Check if it's still under warranty, or buy a new one.
Any workarounds to block the lever in its down position are very dangerous and a potential fire hazard. You may be able to wiggle the lever into place so it catches whatever is left of the latch, but make sure it will pop up easily when the toast is ready.
I hope this helps.
Nov 16, 2009 | DeLonghi RT200 Retro 2-Slice Toaster
Delonghi toaster oven wont turn off
have you cleaned the inside of the oven lately?  With the unit unplugged!
Mar 26, 2009 | DeLonghi DTT900 2-Slice Toaster
Removing bottom cover to access fuse etc - toaster not working
Hi.. the screws on mine are pozidrive (plus sign shaped slots).. what do yours look like?
What's your toaster problem?
Dec 02, 2008 | Breville CT20 Retro Classic 2-Slice...
Removing face of DeLonghi AR1070
This is a two slice Delonghi toaster, model CT12 and is has stopped heating on the right side
Jun 14, 2008 | DeLonghi AR1070 Retro 1500 Watts Toaster...
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
