Question about Exercise & Fitness
Where is the battry on the dp air toner exercise bike
Where is the battery on the dp air toner exercise bike
  • 31 Answers
SOURCE: The tension on the recumbent exercise bike does not get hard
If your bike has magnetic resistance and you changed the batteries this should make your tension work properly. Since it did not I believe that there are magnets somewhere on your bike that are wearing out. Or it could be a computer part. Your manual should tell what part you need to order and replace. I hope this information has been helpful.
Also make sure the batteries that you put in your bike are really new ones. Sometimes you can purchase new batteries at a store and they are actually a little weak. I had this problem with an elyptical trainer and I went and got other batteries and this fixed the problem.
Posted on Mar 16, 2009
OakRun
SOURCE: Wanted:Owners manual for DP Air gometer exercise bike
Scanned image of the 14 page manual that came with a DP AIR GOMETER Model 14-3800B that was purchased in 1991 is available at http://sites.google.com/site/oakrunsite/
Posted on Apr 12, 2009
SOURCE: battery missing for exercise bike
I have a Schwinn airdyne (model AD-3) that uses a button type battery in the count-down timer, which is above the work load indicator or the 'speedometer'. According to the manual I was given with the bike, it utilizes a 1 1/2 volt watch - type battery (LR44, A 76 or equivalent).
Hope this helps.
Posted on Apr 23, 2009
SOURCE: edge 491 exercise bike monitor panel dead
http://www.academy.com/images/pdf/Fitness_Quest/Edge_Recumbent_Bike_491r.pdf
Mine went dead last Spring. I ordered a replacement part from Fitness Quest. I think the link is above. Actually, while I was waiting for the part, I reconnected all the wires on the whole bike and the panel worked. So I actually have an extra new working panel if Fitness Quest doesn't have the part for some reason and u want mine. Double check ALL the connections of the wires first. They come loose easily.
Nancy
Posted on Aug 10, 2009
SOURCE: DP Air Gometer Exercise Machine manual
When excercising faster it seems to make a lound clicking noise.Dose not happen when going slow.HELP
Posted on Oct 16, 2009
I cant seem to get the timer to do anything on my excercise bike
The display (timer) needs to be connected to a sensor on the bike.
Make sure the display is plugged into a cable coming out of the bike.
If it's plugged in and still doesn't work, then contact the manufacturer.
It could be,
1. a bad display. (possibly a broken PCB connection)
2. a bad sensor inside of the bike. They typically use a Reed switch.
3. a broken connection in the cable or connector
4. the magnet fell out of its location.
You can get a replacement monitor from the manufacturer. If this doesn't solve the problem then it's either the sensor or the connection.
You can also place a continuity tester across the 2 contacts of the connector that plugs into the display. The continuity tester should flash when you pedal the bike.
Here's a link where you can purchase a continuity tester.
http://www.amazon.com/Extech-ET40-HD-Continuity-Tester/dp/B0025PK724
You can also pickup a continuity tester at any auto parts store.
Apr 27, 2015 | Body Sculpture Bc1510 Exercise Bike
Where can I buy a comfortable seat for my exercise bike?
I cameacross this website that sells seats for exercise bikes with extra padding andcomfort http://www.derri-air.com/exercise-bike-seat-pads.htm
Jul 30, 2012 | Exercise & Fitness
Looking for the manual for the DP Air Geometer Exercise Bike
http://training.fitness.com/running-cycling/dp-air-gometer-airgometer-ecercise-bike-owner-s-manual-i-have-tjtyle-aol-48387.html
or
http://www.webstatschecker.com/stats/keyword/dp_fit_for_life_manual
i couldn't find the exact manual, but this should be able to help since a lot of the parts are interchangeable. so i really hope that I've helped you in some way. enjoy your day/night
Aug 19, 2011 | Health & Beauty
The readout on my NR1000 does not work, I have repalced the battries.
Welcome to FixYa.
There are only two things that we can do to the readout/computer problem of the NR 1000.
1. Make sure that the batteries has power. 2. Turn it on then press and hold the reset button for 5 to 10 seconds.
If it does not resolve the problem, the device has a mechanical error and servicing it is the best way.
Thank you for using Fixya. Have a great day.
Jas247
Jul 12, 2011 | Nautilus Nr Recumbent Exercise Bike
Edge 491 exercise bike monitor panel dead
Nancy
Jul 12, 2009 | Fitness Quest Eclipse 1100 Hr/A Elliptical
Apr 04, 2009 | Cycling
Oct 19, 2008 | Sport & Outdoor - Others
Exercise & Fitness Logo
88 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
