Question about Nakamichi SoundSpace 8 System
Have misplaced owner's manual and lost several essential wire connectors
This system was a gift to my then 13 yo son who put it in storage about 18 months ago. We now cannot find the manual and do not know what connectors are needed to make it function. I'm hoping to be able to identify the connectors and figure out how to replace any that are missing. I believe a manual would help. Suggestions greatly appreciated. CMurkofskyMD cmurkofsky@aol.com
  • Copake Aug 10, 2007
    I thank you for the prompt reply...the aforementioned manual is a service manual...I am looking for an owner's (operating manual) any possibility of locating one of those. Thanks.
    Copake
    President:
  • 317 Answers
Here is a manual for the Soundspace 9, it should be basically the same: http://www.eserviceinfo.com/download.php?fileid=25052
Posted on Aug 09, 2007
My ttr 90 is spitting and sputtering when you give it gas and i cleaned the carb multiple times and i cleaned the spark plug and put a new air filter in ?
Hi, Austin and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Dirty air filter.
10. Intake air leak.
11. Water, dirt, or rust in the fuel system, carburetor and/or filter.
12. Old dead or bad fuel.
13. Fuel tank vent system plugged or carburetor vent line closed off.
14. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
15. Carburetor controls misadjusted.
16. Damaged carburetor.
17. Incorrect valve timing.
18. Weak or broken valve springs.
19. Damaged intake or exhaust valve.
20. Check for engine trouble codes
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
ttr 90 carb issues TTR
Idles good but sputters when gas it
YAMAHA TTR90 Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-tt-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 31, 2013 | 2005 Yamaha TTR 90 E
My yamaha aerox 49cc just looses power
Hi, Nicola and the usual suspects are:
11. Water, dirt, or rust in the fuel system.
12. Carburetor damaged, contaminated, sticky float, plugged jets.
13. Fuel filter clogged.
14. Old or contaminated fuel.
15. Fuel tank vent system plugged or carb vent line closed off.
16. Gas cap diaphragm valve faulty.
17. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
18. Carburetor controls misadjusted.
19. Incorrect valve timing.
20. Valve springs floating, weak, or broken.
21. Damaged intake or exhaust valve.
22. Incompatible performance parts.
23. Check for engine trouble codes.
have lost power in my yamaha aerox
scooter keep bogging down under throttle
Yamaha YQ50 Service Manual
YAMAHA AEROX YQ50 Owner Manual
Oct 10, 2012 | 2010 Yamaha Aerox R
I have a yz 250 yamaha layed it over now it won't start put new plug in has spark when you kick it
Hi, Mark and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to carburetor or throttle body pinched or kinked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2, TPS, ETP, IAC,or BAS).
14. Faulty neutral, clutch lever, or kickstand safety switch.
15. Faulty fuel pump or fuse or relay.
16. Faulty CDI box if applicable.
17. Tilt sensor needs a reset.
18. Security system not disarming alarm needs a reset.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
250 Yz250 won start
Dirt Rider Magazine
YAMAHA YZ250 LC Owner Service Manual
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
May 11, 2012 | Yamaha YZ 250 Motorcycles
My yz250f 2004 4stroke isnt starting, how do you fix the compression timing ?
Hi, Cameronshepa and the usual suspects are:
1. Fuel tank empty.
250F 2003 yz250f not starting
Part 18 4 stroke how to set timing and determine TDC YZ250F example
YAMAHA YZ250F Owner Service Manual
Sep 11, 2011 | 2004 Yamaha YZ 250 F
Need owner's manual for a GE TV--model #27GT623
We have lost our manual to our 13' GE TV, model # is 13GP344. Could I download one.
Dec 14, 2008 | GE Televison & Video
Nakamichi SoundSpace 8 System Logo
166 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Rommel Balcita
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
