Question about Raypak Rp2100 Digital 336k Btu Propane Heater
On my raypak pool heater i get a message that Water Sw is open. What does that mean?
    Top Expert:
  • Raypak Master
  • 8,673 Answers
Pressure switch either dirty filters or bad switch or loose wires
Posted on Nov 05, 2017
johnsonr1
  • 91 Answers
SOURCE: pool heater wont fire up
Its just after 1 am here as well, Ontario Canada. Yes, you have to remove the front lower panel by raising it then pulling out at the bottom. Then compare the valve you have with the 2 in the picture on pg 5. If it is easier, you can have your husband call me while doing this and I can talk him through it. My contact information is located on the main page of my company website www.emshvac.com
Thanks
Richard
Posted on Jun 23, 2009
  • 139 Answers
SOURCE: Raypak pool heater RP2100 error message CLK
you are in fireman switch mode,which means pool timer is ready to shut down pump. clk shuts down heater approx 15 minutes before pump shuts down. this lets heater cool down before pump shuts off.
Posted on Jul 23, 2009
  • 139 Answers
SOURCE: Service light comes on our Raypak RP 2100 pool heater.
this usually indicates a high limit condition.you must first ascertain if you have a component failure or a true high tempature condition.your model has 2 limit controls and they are both located in side panel on water in/out header
Posted on Sep 19, 2009
  • 990 Answers
SOURCE: I have a Raypak model 153 pool heater. The heater
For some reason your heater is not recognising the flame when it goes on. The biggest reason for this will be small spider webs in the burner orfaces. These are on the main gas manifold where it connects to the burners. You can get a small wire and bend it to go in these orfaces but the first time you do this it will probally be easer to pull the tray and remove the orfaces from the gas line. Good luck, I hope this helps.
Posted on Nov 28, 2009
john224
  • 1378 Answers
SOURCE: raypak heater. fault cde says (ROL)
Thank you for posting your question here on Fixya.com.
Replacing the roll out switch is an easy do-it-yourself repair. Fixing the problem causing the roll out of the burner flames in the first place is a bit more of a pro job. Something is causing to much heat to roll out the the combustion chamber into the control area causing the switch to fail. You will continue to burn the link until the underlying problem is fixed.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jun 01, 2010
I have a code that says Water Sw Open...Just turned on the gas line from the winter going to start the heater and see this message.
ahh its a pool heater .
cant find a user manual for it
.gas
if not sure dont light it up ..till you know its safe
May 27, 2016 | RAYPAK R266A 266K BTU ASME DIGITAL...
What does sw open mean on the digital display mean
sw open means open switch check pressure switch to see if voltage both sides if ok check hi limits
Feb 03, 2015 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
What could becausing my raypak model 406A natural gas pool heater is not working states roll out sw open
replace fusible link but see why it overheated wind or not enough gas pressure
Aug 17, 2014 | Raypak Pool & Spa
Why does my Raypack 156ENC pool heater have error code Rollout SW open?
Either keep replacing the switch or find out what is causing the switch to fail. The "plumber friend" should know.
Jul 16, 2014 | Raypak 130,000 BTU Natural Gas Pool...
What is Raypack Pool Heater Code Vent Field Sw#1
fusible link open replace but check gas pressure if ok see if you need vent stack
May 29, 2014 | Raypak Free Hydraulic Lift Gate Delivery -...
What does water sw closed mean on my heater display panel ?
showing that pressure switch is closed see if voltage on both sides then check the safety circuit if ok check ignitor
May 05, 2014 | Raypak Pool & Spa
What does rollout sw open mean
bad fusible link check gas pressure if too low it will overheat after gas ok then replace and clean outside of heat exchange so heat can vent out
Aug 24, 2012 | Raypak RP2100 DIGITAL POOL HEATER R206...
Raypak Rp2100 Digital 336k Btu Propane Heater  Logo
59 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
