Question about Canon imagePrograf iPF8000S Large-Format Inkjet Printer 2161B002AA
Canon 038005002f2f hardware error - Canon imagePrograf iPF8000S Large-Format Inkjet Printer 2161B002AA
Error e42 22
Apr 24, 2011 ... E40 20 = Other hardware error. E42 22 = Scanner error. How to reset CANON WASTE INK COUNTER MP160/MP145 Before you reset the ... canonprintersink.com/error-code-printers-reset-canon-mp145-mp160.html canonprintersink.com/error-code-printers-reset-canon-mp145-mp160.html
have just checked this site and I am sure it will help you
Feb 20, 2012 | Canon Office Equipment & Supplies
Printer canon ip 2770 eror b200
Hello and Welcome to FixYa!
According to Canon's documentation, Error B200 is simply listed as a printer error (not very descriptive). It is likely a hardware fault on a board, a physical hardware malfunction. To resolve the error, Turn off the machine, and unplug the power cord of the machine from the power supply. Again connect it and turn on.
If the problem is not resolved,
then best option is to take it back where you purchased it or contact Canon service center about the error code.
I hope this solution helps you
Thank you and Keep Visiting FixYa
Aug 18, 2011 | Canon Pixma iP2700 InkJet Photo Printer
On Canon Pixma MP830 printer the alarm is blinking and the window read error 6500. I can't find that number of the manual. What do I have to do in order to print again. Thanks. ...
The error 6500 refers to other hardware error. This error results from printer hardware failure and the only solution is replacing the malfunctioning hardware.
It is generally logic board error code. If the printer is under warranty, you better ask for replacement.
Lucas
Jul 08, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Error 6500
The Canon website indicates that is a hardware problem, there's nothing i can do. You call a technician or the canon help support. This is the description of the code:
Other hardware error [6500] - Logic board ***'y (QM2-3393 / QM3-1654)
Take care.
Jun 21, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
Error message B200 on Canon Mx860
To solve it:
then best option is to take it back where you purchased it or contact Canon service center about the error code or
To get support by Canon on phone, then call at 1-800-OK-CANON (1-800-652-2666)
They will surely solve it.
For further assistance, I am here to help.
May 02, 2011 | Canon PIXMA All-In-One Photo Printer with...
How can i fix error b200 ?
Hello thanks for using FixYa
According to Canon's documentation, Error b200 is simply listed as a printer error (not very descriptive). It is likely a hardware fault on a board, a physical hardware malfunction.
To solve it:
For Further assistance, I am here to help,
Thanks, Keep Visiting FixYa
Regards:
Uxair Shah
Mar 15, 2011 | Canon iP4700 InkJet Photo Printer
My canon mp830 printer is saying error 6500 and i cannot get it to do anything, i have un plugged and re plugged and nothing. what does this error code mean?
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much can user do instead of replacing the malfunctioning hardware. 6500 is generally logic board error code. If the printer is under warranty, you can ask for replacement
Abhilash
$7 is the charge for the service provided.
Oct 01, 2010 | Canon MP830 All-In-One Printer
What is service error B200? The printer doesnt work and it says it has a "service error B200"
According to Canon's documentation, this is simply listed as a printer error (not very descriptive). It is likely a hardware fault on a board; a physical hardware malfunction.
This is Canon's official stance on the error:
Turn off the machine, and unplug the power cord of the machine from the power supply. If the problem is not resolved, contact your Canon service representative.
After looking a bit more, I discovered that the B200 error is a Voltage High Error on the iP4500 chip. Try calling Canon tech support at 1-800-828-4040. If your printer is still under warranty, they will probably send you a new printhead or a new printer.
May 26, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
We keep getting a 03800500 2F-2F hardware error message on our Canon IPF 9000s printer. What is this exactly? We changed both heads an we keep getting this message. Thanks Louis
That is hardware error, if you have 1.2 or earlier firmware it can be a system bug that you fix updating firmware. Call Canon to get instructions on how to update firmware.
Dec 05, 2008 | Canon Office Equipment & Supplies
Open Questions:
Erreur 161-403F ·     Largeur maximale du support de 1 118 mm ·     Largeur maximale de numérisation de 1 067 mm ·     Mémoire en standard : 1 Go de RAM ·     Connectivité en standard : Fast Ethernet 10/100Base-TX, FireWire ·     Types de support pris en charge : Papier non abrasif, vélin, mylar, sépia, bleus, film plastique, film, papier plastifié, carton plume, carton (pas de contreplaqué, marbres, tôles ni de surfaces abrasives sales, irrégulières, à bords vifs, à attaches métalliques ou brûlées) ·     Précision des lignes : +/- 0,1 % ·     Résolution de numérisation : Jusqu'à 2 400 ppp ·     Résolution optique pour la numérisation : Jusqu'à 508 ppp ·     Taille maximale pour la numérisation : 1 067 mm x limité par le disque dur et le type de fichier ·     Profondeur en bits : 24 bits en couleurs et 8 bits en noir et blanc ·     Formats de fichiers pour la numérisation : TIFF, JPEG, JPEG2000, PDF (24 bits) ; TIFF, PDF (8 bits) ; TIFF, DWF, CALS G4 (1 bit) ·     Résolution de la copie (texte et images couleur) : Jusqu'à 9600 ppp ·     Nombre maximal d'exemplaires : Jusqu'à 1000 ·     Plage de redimensionnement en mode copie : 1 à 10 000 % ·     Systèmes d'exploitation compatibles : Microsoft® Windows® 2000, XP Edition Familiale, XP Professionnel ; Mac OS 9.x, Mac OS X ; UNIX ; Linux ·     Pilotes d'impression inclus : HP Macroinstaller avec gestionnaires Windows pour imprimantes HP Designjet séries 500, 800, 1000, 4000, 4500, 5000, 5500, T610, T1100, Z2100, Z3100 et Z6100 ·     Capacité du disque dur Standard, : 30 Go ·     Alimentation électrique nécessaire : 100 à 240 V CA (± 10 %), réglage automatique, 50/60 Hz, 5 ampères maximum ·     Consommation électrique : 300 watts maximum ·     Plage d'humidité de fonctionnement : 20 à 80% HR ·     Plage de températures en fonctionnement : 5 à 40 °C ·     Dimensions (L x P x H) : 1 800 x 850 x 1 380 mm ·     Garantie : 2 ans avec intervention sur site
Feb 26, 2017 | Canon imagePrograf iPF8000S Large-Format...
Canon imagePrograf iPF8000S Large-Format Inkjet Printer 2161B002AA Logo
27 people viewed this question
old marine
old marine
