Question about Konica Minolta Bizhub C220 Color Copier
Scanning multiple pages to separate pdf files
I've got problem with scanning multiple documents to separate one page pdf files. I've choose file type as pdf, single page and scann to user box, but I always get all scanned pages in one document.
  • 214 Answers
SOURCE: Scanning documents
You have to install driver with software, you can get it from www.konicaminolta.eu
Also you can scan with MS office or other Windows software, if you installed Twain scanner driver.
Find driver and software link below:
http://download2.konicaminoltaeurope.com/openmind/technic/kmbsdwl.nsf/psearch?openform&ch=MFP&dist=BEU&ui=en&dg=sw&prod=Di1610&dsg=&os=&lang=&ml=0&rid=&sub=&pcat=&pcc=
Posted on Dec 05, 2007
SOURCE: Multiple Pages in Scan
need to fit a hard drive
Posted on Sep 24, 2008
fer_nan_14
  • 76 Answers
SOURCE: Printing failed when running big files from computer to copier
hi
try to change the speed of your copier lancard to 10mbps full duplex
Posted on Dec 23, 2008
  • 14 Answers
SOURCE: Biz pro 920 staples multiple booklets together.
Not sure on an Apple set-up but with windows if the the collate box is checked on the first page of the print properties window it will staple all sets together as one. I'm sure it is a similar setting on a Mac.
Posted on Feb 15, 2009
jqsababa967
  • 145 Answers
SOURCE: Slow prints
it may be a memory size issue check or buffer size...
good lock
Posted on Apr 26, 2009
On a Konica Bizhub c364e, how do you scan multiple pages and have them show up as separate files in your email or USB?
Go to Scan/Fax option.
choose your destination.
click on scan setting
on right hand side you will find option SINGLE or
SEPARATE/SEPARATION.
If separate or separation is selected/highlighted thats means all page will be scanned in single file.
if not selected then all single page will create separate file..
Dec 01, 2016 | Konica Minolta Bizhub C364 Color Copier /...
How can I get multiple scan multiple pages to one PDF file
Scanned to one file is only supported for Document Scan type ( you should choose shortcut with scan type =Document) and you should make sure that the box "Create one file per scanned page..." (in the Save to file Options) is unticked
May 16, 2010 | Lexmark X1290 All-in-one Inkjet Print...
Every time I scan a multiple-page document into a PDF file using my HP LaserJet M1319fMFP, in creates a separate file -- or document -- for each page, rather than simply scanning all the pages into a...
There is no easy way of doing this.
What you can do is scan each page as an image file, then use an OCR program to convert each page into a text file and save them. Then open a fresh/new Word document, then open each text file page and copy and paste each text file page into this Word document.
After you have copied all the pages into this Word document, then spell check it, edit and format the text then save the document. You can then create a PDF file from this Word document if you need to.
Nov 28, 2009 | HP Pavilion dv6000z Notebook
How do I scan multiple pages into one document
When Save as PDF file is selected: The Save as PDF file dialog box opens. Specify the file type, file name and destination folder.
Select from the following PDF file types:
PDF When multiple images are selected, each image is saved as a separate PDF file. PDF(Multiple Pages) Multiple images are saved in one PDF file. PDF(Add Page) Selected images are added to a specified PDF file. The images are added to the end of the PDF file. You cannot rearrange pages of the PDF file to which images are added.
Oct 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Can't save multiple page scan to multiple page pdf document
that should be because you scanned the pages separately, did you notice if the PDF document converted was the very last page of the 13paged document which you wanted to make a document from? if that's right, then you just only converted the last scanned page into PDF, to stick all the pages together, i recoment you treating them as images and using word to stick them all together with the "insert>image> from archive" adjusting the size of the image at 1 page and with each 13 pages do the same until you have a full document of 13 images in 13 pages then you can convert it into PDF
Sep 14, 2009 | Brother Multi-Function Center MFC-240C...
Scanning Multiple pages into one pdf
Scanning a multi-page document as a .pdf file reverts the settings for rotation, selected area, etc. to default for any pages after the first page. This applies to Mac OSX 10.3, 10.4, & 10.5. A simple, but tedious work-around is to scan each page as a separate file and easily recombine them using OSX Preview. Just open the first page, view the Sidebar, and drag-drop the additional page files into the sidebar. Save and it's all one multi-page .pdf.
Jun 26, 2009 | HP Photosmart C5280 Printer
Don't know how to set scanner for multiple page scan into single pdf file
The supplied Canon software is horrible, but it can be done!
Launch ScanGearStarter, choose advanced tab and click preferences button, then select scan tab.
Untick box "Automatically quit ScanGear....." then click ok.
(This box being ticked totally prevents multipage single file scanning).
Now choose simple mode tab, select the document type, dpi and document size.
Now click the green "Multi Scan" button, place the document on the scanner glas and press next in the new window.
The page will be scanned and the ScanGear window will return, just click "Multi Scan" again and place next document, press next. Keep repeating until all pages are scanned, then close the ScanGear window.
This will bring up a third window showing thumbnails of each page, any of these pages can be deselected if required.
The other important step is to choose from the pull down list Saved as Type: "MultiPagePDF".
Choose the location for saving the file and click save.
Hallelujah! .......stupid software.
Jun 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
hi,
For you to be able to scan multiple pages using the .pdf and save it in one file, here are the steps that i want you to follow.
SOLUTION I.
1. Open the Solution Center.
2. Click on Settings, then go to scan settings.
3. Click on Scan preferences.
4. Make sure that the "Prompt for additional scans from glass/TMA has a checkmark. then click OKAY.
SOLUTION II.
1. Solution Center is open, click on Scan documents.
2. Scan document settings is open, choose SCAN TO: .pdf and file type is .pdf
3. Click on SCAN below. It will start scanning, and just click on ACCEPT everytime it gives preview on each document.
Thank you.
adonscott
Jul 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
Konica Minolta Bizhub C220 Color Copier Logo
62 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
