Question about Sokkia Grx1 Gd Rtk Dual Receiver Systems Gps Only - Satel Models
Sokkia GRX1 RTK fixing problems
My GRX1 takes about 1 - 2 hrs to fix in RTK mode. Have tried resetting to factory default setting but to no avail. Any Help?
M'y watch is Frozen. It shows M13-535 1.0.91 on the screen How Can I fix it
Try this, take the back off the watch remove the battery and do not replace for 1 minute. After time elapses reinstall battery make sure all necessary battery holdowns are properly put back in place and replace the Back. This should put the watch back to original Factory default settings, if its not showing the code any longer just advance the setting and mode buttons to reset the time and date to their proper place.
Nov 09, 2017 | The Audio Players & Recorders
I have a Ferguson F2620LVD TV, Unable to reset tv to original state, when purchased
SYSTEM SETUP 1.In Stop mode, press the SETUP button. 2.Use the or button to select the System Setup option. 3.Press the button to highlight the Default. 4.Use the or button to select the desired setup option. 5.To exit the SETUP MENU and return to the normal screen, highlight the Exit Setup Mode ( ) and press the ENTER/ OK button.
Default It takes 3-5 seconds to reset the unit to the factory default
Nov 02, 2016 | Televison & Video
My LG TV turns off at 18:30 hrs every evening and comes at 20:00 hrs.even if I switch on at 18:00 hrs it still does that. All power saving options are off. How do I fix this?
Do a factory reset to this set, and check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
May 27, 2016 | LG Televison & Video
My Vizio E320i-A0 tv, has barley any picture when i pug in and turn on, VERY faint logo on screen, How do I fix it?
The picture settings may have been set very low. You can reset to the factory default settings using the steps below. You may also try selecting different inputs to see if the brightness is the same on all of them.
1. From the Picture Settings menu, use the
Arrow buttons to highlight 'More' , then press OK.
2 . Use the Arrow buttons on the remote to highlight 'Reset Picture Mode', then press OK. The TV displays, "Are you sure
you want to RESET Picture Settings to the factory defaults?"
3 . Highlight Yes and press OK.
4 .Press the EXIT button on the remote.
A manual is available here:
http://cdn.vizio.com/documents/downloads/hdtv/E320iA0/UM_E320iA0.pdf
Jan 17, 2015 | Vizio E320i-A0 32 Class LED Smart TV
Error e191 sokkia 1030r
Sokkia 1030r displays e191 in horizontal angle window
Jan 19, 2014 | Sokkia Set210 / Set310 / Set310 / Set510 /...
The word "Factory" has appeared on the screen in red
Hi.
Factory on screen means that the TV is stuck in service mode (Durabrand and more). The problem is fixed accessing Service mode and resetting to factory default settings.
On Durabrand TVs problem is fixed using a programmable remote, entering service code on remote, and accessing service menu.
Procedure is listed on TV service manual.Most durabrand use Menu and key combination 683 to access service mode.
If that does not work, calll manufacturer number to get the key sequence to enter factory menu.
Jul 06, 2010 | Televison & Video
I put it in bridge mode and can't but it back into routing mode (tried to fix NAT problems) tried using the default 192.168.1.1 and then command prompt to find the ip that way to no avail? any ideas?
hello Cadmb3220
Of course it won't work :)
Once you set your zyxel in bridge mode all it does is translating adsl signal to comething that any other pppoe ethernet device can understand.
so in this bridged mode zyxel has no IP, is not manageable and can't be accesed over an ip ...
only way to access it again is to do a factory reset ...
btw ... i'm almost sure that whatever nat problem you had - you had because you didn0t make the same rule in your firewall on the zyxel :)
Feb 17, 2010 | Zyxel P660HW-D1 Router
Akai PT5250A - I cannot converge correctly.
this fixed this problem
Plugs on the chassis coming from keyboard and side video input are switched (they have same plug)
redoo convergence save and auto focus in factory mode after switching plugs
Jan 13, 2009 | Akai PT5250A Television
Touch screen frozen
the best solution to fix this problem is to get it repaired or replace if it is still under warranty.
I'll let you know if there is any other solution to fix this.
Apr 12, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Sokkia Grx1 Gd Rtk Dual Receiver Systems Gps Only - Satel Models Logo
27 people viewed this question
Top Sokkia GPS Experts
Will Halftowaite
Are you a Sokkia GPS Expert? Answer questions, earn points and help others
