Toshiba rd xv48dt
How to record a vhs tape to cd
SOURCE: recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Posted on Apr 05, 2008
  • 9 Answers
SOURCE: How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
Posted on Jan 03, 2009
RFICKES
  • 51 Answers
SOURCE: Can't copy my disney vhs tapes to dvd
I'm assuming your Disney tapes are store-bought, as opposed to recorded off the air. If that's true, the reason you can't record them to your dvd recorder is because of copy-protection. Sorry...can't advise you how to break that.
Posted on Jan 04, 2009
  • 21 Answers
SOURCE: Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Posted on Jan 27, 2009
Tech5508
  • 40 Answers
SOURCE: how do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
Posted on Feb 13, 2009
Recorder switches off when I put a vcr tape in machine.
The loading mechanism is not working properly. When that happens many units are programmed to shut themselves down.
Mar 10, 2016 | Toshiba rd xv48dt
While playing vhs tape, the sound is great, but the picture comes and goes.
That's usually dirty or worn out heads or not enough take up tension in the tape
Sep 27, 2014 | Toshiba RD-XV49DT DVD/DivX/VHS...
How do I transfer stuff off a VHS on to a DVD? I have no instruction manaul for my Toshiba RD-XV47
Connect the VCR's video and audio outputs to the DVD recorder's video and audio inputs. Set up a tape in the VCR. Start recording on the DVD recorder, and immediately press "Play" on the VCR.
Aug 12, 2014 | Televison & Video
How to recover deleted video from toshiba rd xv48dt hard disk?
try hard drive data recovery software, recommended Asoftech Data Recovery which helped me before. You may take a look at this hard drive data recovery guide that helped me before
How to recover deleted video from hard drive
good luck!
Dec 07, 2012 | Toshiba rd xv48dt
Toshiba dvr670ku - vhs tape won't play, shuts recorder off
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
Oct 14, 2012 | Toshiba M754 VCR
I have a recorder that whenever i put in video cassettes stops playing after a few seconds and turns the unit off. Can anyone help. Thanks
sounds like belts and rollers and any sensors you see need to be cleaned - it sounds like the unit thinks tape is at end and is shutting down
use qtip and rubbing alcohol to clean
try using different tape just to make sure it is not just a bad tape
Mar 21, 2011 | Toshiba RD-XV49DT DVD/DivX/VHS...
Playback Problem
open the recorder, 4 screws at each corner, wipe the playing head and the voice reccognition head, to the right of the playing head head with a baby wipe, you will be amiazed what **** comes off it. DON'T scrub it just wipe lightly, spin the playing head so it's clean. If you have a lint free cloth ( a glasses cleaning cloth you get in the case is brilliant) Try the tape (before you put it in make sure everything is DRY!) and your problem should be solved. It worked for me! and that came from a TV engineer
Jul 15, 2009 | Toshiba RD-XS25 DVD Recorder/HDD Recorder
PD DVR100
Hi again,
This is a placeholder and would look forward to the diagrams.
Cheers.
Jul 28, 2008 | Protron PD-DVR100 DVD Recorder
IVE GOT A TOSHIBA RD-XV45KB VCR to DVD RECODER.
i too have the same error 03-56 the only way i have found around it is to use the really cheap basic -r discs from tesco
Feb 14, 2008 | Panasonic DVD-RV41 DVD Player
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
