Question about Technics RS-TR373 Single Cassette Deck
Double cassette deck rs tr 373 tecnicks - Technics RS-TR373 Single Cassette Deck
5 Suggested Answers
  • 189 Answers
SOURCE: connection between CD, EQ, SP technics
Each unit (the EQ and the Processor) should have left/right in/out rca jacks as well as L/R tape in/outs. The EQ or processor use the receiver's tape loop and then provide a tape loop to replace the one they've used on the receiver.
You plug the first unit (let's say the Sound Processor into your receiver/amp as if it were a tape deck (Processor's outs connect to reciever's tape ins (play) while the Processor's ins connect to the receiver's tape outs (record).
Then you chain the EQ off the Processor in the same way (EQ outs connect to Processor's tape ins (play) and EQ ins connect to the Processor's tape outs (record).
Last you connect the tape deck to the EQ as follows. Tape deck outs connect to EQ's tape ins (play) and the tape deck ins connect to the EQ's outs (record).
This will put both the Sound Processor and the EQ in the receiver's tape loop. In order to have all the receiver's source signals routed through them you may have to engage a Tape Monitor switch or button somwhere on your amp which will route the tape loop to your speakers.
Posted on Jan 09, 2008
  • 319 Answers
SOURCE: Technics RS TR-272 Model Cassette Deck
Try this: Amazon.com
http://www.amazon.com/Technics-RS-TR272-Dual-Cassette-Deck/dp/B00000K0JA
Posted on Apr 25, 2008
  • 99 Answers
SOURCE: I need to know how to record 1 tape onto another
press the synchro start button, the tape deck should now go to REC PAUSE, press the SPEED button till you get the required recording speed then press the synchro start again and it should start to record from deck 1 to deck 2.
make sure the tabs at the top of the tape you want to record on are intact,
if not just put a bit of sticky tape over holes.
hope this helps?
Posted on Jun 29, 2010
caroldon
  • 17129 Answers
SOURCE: RS-X501 DOUBLE CASSETTE
Usually the fault is the failure of the BELT on the mechanism. You will need to remove the covers to have a look on the motor drive behind the mechanism of the tape drive. Thebelt can be changed if you are technically capable to remove and reset the mechanism.
Posted on May 06, 2011
I have a rs-tr 180 that's pulling the tape out of the housing is there a solution?
The tape player recorder that pull the tape out could have the following faults: 1) It has a separate belt from the motor/capstan to the take=up turntable. 2) Capstan roller skew the gap when you bring the mechanism in can be checked and it must be PARALLEL with the surface of each other.3) Faulty cassettes they are binding in their housing due to heat or bad manufacture! Try to rewind and wind your cassette end to end both directions. 4) head alignment not set correctly 5) clutch of take up reel worn or has a bad tension spring. depending how it was made.
Mar 28, 2012 | Technics RS-TR272 Single Cassette Deck
RS-X501 DOUBLE CASSETTE DECK PROBLEM WITH TAPE DRIVE ON BOTH DECKS
May 06, 2011 | Technics RS-TR272 Single Cassette Deck
Need to find user manual. I have a problem in recording a tape. I put in deck1 --- cassette to be recorded in deck2 new cassette start play on deck1 ... turn on record and play in deck2 as...
for a start your title says "Problem with the Technics RS-TR272 Single Cassette Deck"
So is it a single or double?
i'm assuming it's a double,right only one of the decks records so put the blank tape into it make sure the tabs on the top of the tape haven't been broke or you'll need to cover the holes with the labels you get with the tape.
put the tape with the music on it, in the other deck rewind them both then press "sync rec" & they should both set off.
Mar 01, 2011 | Technics RS-TR272 Single Cassette Deck
I need to know how to record 1 tape onto another tape on a Technics rs tr-575 dual cassette deck
hope this helps?
Feb 05, 2010 | Technics RS-TR575 Single Dual Cassette...
Technics 373 Dual Cassette - Playback Stops
Suggest having a good clean and replace belts. If it stops around halfway on a C90 or near the end then there's a load problem on the take up reel, before halfway the supply reel.
Dec 13, 2008 | Technics RS-TR373 Single Cassette Deck
Remote control for Technics RS TR 272 Dual Cassette Deck
a system remote is the only option for you here. The deck does not have its own remote receiver. Sorry to break the bad news to you.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
Help
Just connect you EQ to your receiver as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop. To hear the EQed signal with all receiver sources you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Nov 22, 2007 | Technics RS-TR272 Single Cassette Deck
Technics RS-TR373 Single Cassette Deck Logo
52 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
