Question about Garden
Mountfield s38 scarifier manual - Garden
Change suffolk punch mower14 from grass cutter to scarifier
Remove grass box support cradle. Unscrew 2 allen bolts (one each side - located in front of cutting cylinder). Remove mowe side casing (drive side). Pull out entire cutting cylinder assembly. Usually they slide out without issue, but sometimes, they will jam and need levering out. There's nothing holding it in except the 2 screws.
Insert the scarifier assembly and secure with the 2 bolts.
Job done
Oct 12, 2014 | Garden
How do I change the belt on the mountfield s38?
There should be a tensioner that you can rotate with a socket on the bolt in the middle and a long ratchet handle.
Apr 24, 2013 | Cars & Trucks
How do i unlock the panasonic dvd-s38 to play all region dvds
In addtion to the S68/S38 remote this hack requires a universal remote configured for the S58/S38 with a separate 'Pause' button (or another Panasonic DVD remote with a separate 'Pause' button may work).
Neither the 'Play/Pause' nor 'Frame' buttons on the S58/S38 remote work for this hack.
1. Power on.
2. Open tray.
3. Using the S58/S38 remote press Audio, 1, 9, 8, 2, Subtitle
(it is not required but, if the TV is on, it will display the 'no go' icon after each key press - ignore it).
4. Using the other remote press Pause.
5. Using the S38 remote press 0.
The DVD front panel should now show the text "on".
If so, the DVD is region-free.
Dec 06, 2010 | Panasonic Dvds38 Dvd Player
Mountfield mower manual
it seems this mower is made by Homelite with the Mountfield name on it.
May have to see if you can locate a source for homelite to find this manual.
cheers
Sep 26, 2009 | Garden
I need onwers manual for Mountfield Laser Delta mower
Have you Contacted Mountfield about a Manual? You can Contact them Using the Options at this Site Addy;
http://www.mountfield-online.co.uk/contact?jssCart=13a24ca4de2a2610f7213de8a0539ffb .
For an Engine Manual you can Contact www.outdoordistributors @ 877-707-2787 or Contact Tecumseh @ 800-558-5402.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
How do you change the nylon cog on the scarifier 14'' cartridge
if you hold the scarifier shaft tightly and use a socket on nylon cog and turn socket anti-clockwise it will unscrew
Mar 30, 2009 | Garden
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
