Question about LG WD-3243RHD Front Load Washer / Dryer
Condensing unit how does this unit work?
Runs louder after cleaned condenser unit
The filthy condenser unit was also acting as a sound absorber. Now that the "absorbant" has been cleaned ..........................
Aug 05, 2015 | Refrigerators
Problem with GE PTAC-Model# AZ28E09DABM2 - Why won't condenser kick on when switching to AC from Fan. AC was working fine until today...Fan is still working...Pulled the unit out and could feel the h
Hummm. A bit difficult to solve this problem. Seems like the condenser outside is not working, I mean the fan of the condenser. Looks like you have a wall A/C and a wall A/C always have condensers outside the house and near the A/C. Have you checked if the fan is spinning? I don't think the compressor is at fault but check it anyway. You should be able to hear the compressor running either in the wall unit or in the outside condenser housing. The only heat you should feel is from the condenser itself. If you blows warm air, that means the fan is working, if not that means the fan is not working. But don't be confused with the fan not working because in winter time sometimes the fan is not working and some times it does. As I said, it's a difficult problem to solve but at least start with checking the situation with the fan in the condenser.
Jun 16, 2014 | GE Zoneline Deluxe Series Cooling &...
2 ton unit
6719f81e-d5d1-47c4-b80f-e11712a6cac5.pngNo oversizing the condenser will not work well, however oversizing the evaporator coil by 1/2 a ton actually increases the units efficiency and is recommended to do by most utilities on units they finance.
Jul 07, 2013 | Goodman CKL36AR36 Air Conditioner
Sub zero 736 condenser fan not running
You will need to remove the cover around the condenser fan motor then remove the screws holding it down to the base. Remove the wiring from the junction box and away you go. Do not run the unit without a working condenser fan motor, you run the chance of causing yourself many other problems. With a new fan motor the unit should run fine unless there is waxing in the cap tube from overheating. Good luck
Sep 08, 2012 | Sub-Zero Refrigerators
Outside unit doesnt start inside unit is working
This model of Goodman A/C the condenser coil get extremely dirty and what happens is when your condenser runs for a long period of time it pops the capacitor. This is the starting component for the compressor and the fan outside. the coil needs to be cleaned with a non acid condenser cleaner. Open up the side compartment of A/C look at the silver cylinder thats the capacitor if is looks swelled replace it.
May 11, 2011 | Goodman CKL30AR30 Air Conditioner
Al aluminium condenser life time
Both aluminum and copper coils should last the life of the air conditioner. What really determines the life of the unit is the compressor. You could conceivably keep a condensing unit working indefinitely, but the number of service calls, the difficulty in finding replacement parts for an older unit, and the increased energy efficiency for a new unit will make it worth your while to replace it.
Dec 24, 2009 | Heating & Cooling
Condenser fan will not work
Check to see if you have 220 to unit. May have bad breaker. Only feeding one leg. Rusty
May 23, 2009 | Heating & Cooling
Mitsubishi wall unit srk50zg condenser src50zg air con not heating new install
Double check your wiring .if the indoor fan is not blowing then you either have an electrical issue OR bad blower motor .
May 24, 2017 | Refrigerators
Clicking from Condenser
I would have to say it's your fan going out, also if the units aren't fixed the the DD should come out and fix it for free since it wasn't done the first time. I would take a look at it but I don't know where in florida you are. I'm in highlands county. If your close enough I could come take a look. If there's clicking coming from your condenser then it's one of two things, the compressor or the fan. hopefully the fan. let me know.
Sep 29, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
LG WD-3243RHD Front Load Washer / Dryer Logo
13 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
