Question about Vacuums
Bissell Parts Diagram for petwashmodel 2080f
Will not spray or suck
reddevil6
  • 1673 Answers
SOURCE: Bissell proheat
First is the smart mix valve turning like it should? If it is then replace the soap dispensor. Also is the gasket on the valve at the bottom of the bottle?
Posted on Jun 01, 2008
  • 29 Answers
SOURCE: Cleaner Solution Not Dispensing On Bissell 9200 Pro Heat Cleaner
I haven't had this particular issue (yet... knock on wood!) with my Bissell, but remember that the shampoo will not dispense with no water in the tank (the most common cause of this issue because sometimes you think it has water but it doesn't) or water not flowing through the machine due to clogged sprayers-- another issue-- but since you're getting water on the floor that is not your issue-- or with the handle locked in position. If none of that fixes it, try removing the shampoo container, stand over a sink, and push your finger up inside the grommet where the shampoo container mates with the Bissell. Shampoo should dribble out. If it doesn't, unscrew the grommet (holding the container upside down of course so the shampoo doesn't gush out) and use your finger and running water to try and the grommet cleaned out.
If this isn't helping, it may be that your soap pump or soap dispensing trigger switch are defective.
Posted on May 29, 2009
  • 5 Answers
SOURCE: water/solution flow problem
check your belts. if your brush is not spinning when you have it on, it is a belt. goto bissell.com and there you will find on line videos to help you with this troubleshooting process, it will also tell you how to change it.
Posted on May 30, 2009
  • 60 Answers
SOURCE: My Bissell ProHeat steam cleaner won't spray water. The accessory
Under the plastic under the water tank (its a pain to pull apart to get to it) there is a solenoid that actuates the water between the floor and the tools. This is toast if its not spraying the floor, its simply not reacting to the signal to let it go through to the water side.
Seems to be a common problem with the Bissell Proheats. You can order a new one online for about $12 and try to get to it to replace it yourself (if you can open up the base its obvious which part it is if you just follow the hoses).
Posted on Oct 31, 2009
  • 18 Answers
SOURCE: 1672 BIGgreen Wet/Dry Vacuum: my bissell 1672 big green machine has stopped spra...
Refer to the discussion at the other thread: http://www.fixya.com/support/t3309646-pump_motor_sounds_like_running_but_not
You will need to remove the top domed lid to access the working parts. Refer to http://www.fixya.com/support/t3543424-two_top_sections_held_together
Examine the water lines to ensure they are attached to the pump. If you feel you can do so without shocking yourself on any exposed electrical connectors, try disconnecting the inlet hose. Buy a two-foot section of the same size hose from the hardware store and connect it to the pump inlet. Plug in2_bing.gif the unit (be careful!!!) and use the pump switch to see if it draws water. Then try reconnecting the inlet and connect the outlet to the new hose to see if the pump pulls water from through its suction tube and will pump through the new hose.
Posted on May 25, 2010
My bissell will not suck the water
Check User's Guide for filters. One under the water tank cap (looks like a small screen) and one under Flow Indicator. Bissell Consumer Care 1-800-237-7691
Jul 18, 2014 | Bissell Proheat 2X Select Pet Upright Deep...
Fixing the overstretched hose on the helix bissell vacuum
Hey Trinidad! Sorry to hear the hose sucking together. You may want to purchase a new upholstery hose.
Here's a quick link to the BISSELL website.
http://www.bissell.com/parts/?cid=ccsocial
Feb 22, 2013 | Bissell Vacuums
My carpet shampooer is not sucking up water?
Hey Karen, having no suction when cleaning can be a bummer.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 04, 2013 | Bissell 1699 ProHeat Clear View Upright...
Bissell Steam Cleaner
my cleaner is not spraying or sucking up the water?
May 10, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Wont spray water on the carpet
Same Problem here- The hand piece works fine. Bissell 9500 ProHeat2X.
Both tanks full New Belt on the brushes I can not get cleaner/water to spary when trying to clean the floors.
I've taken my air-compressor and with low psi blown back to make sure teh lines are clear from the spary heads. Still not working...
Apr 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Proheat won't spray properly and suction not working.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
kjljl;
Mar 31, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
The Bissell won't spray any carpet cleaner but it is still sucking up water.
If it doesn't dispense water then that means that you need to replace the pump belt. Here is a link to the belt you nee and the manual:
Bissell ProHeat Belt and Manual
Dec 27, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell proheat
May 28, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Vacuums Logo
20 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
