User manual Belkin N600 Dual Band Wireless Range Extender
4 Suggested Answers
Tom Marvolo
  • 708 Answers
SOURCE: how do i connect my xbox 360 live to my belkin
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Now lets configure
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Scan and connect to this network and test the connection
If working then let me know
Posted on Jan 18, 2011
Geekman
  • 32281 Answers
SOURCE: N600 Belkin Dual Band N+ Router Range Problems
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default. Change to anotherchannel.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedropouts and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the otherside of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
Posted on May 31, 2012
Geekman
  • 32281 Answers
SOURCE: How to connect the ASUS EA-N66R as a range extender.
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's RJ45 port with a LAN cable. 2. Open a browser, then enter the router's URL configuration's IP address, This is usually something similar to 192.168.0.1 3. Enter the configuration user name and password. The router will display the various router settings. 4. Go to the page that changes the IP address of the router. Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to 192.168.1.1 then the repeater router should use a higher number (ie. 10), such as 192.168.1.10 or higher, depending on how many devices are on your network. 5. Disable the repeater router's DHCP server. This setting should be on the same page as the IP address, (this may be different depending on the make of the router). When the main router is operating normally, this server assigns an IP address to every device that is connected to your network. Because this router is used as a repeater, the main router on your network will still issue the IP addresses. 6. Also turn off the DNS server, if it is activated. This function will be taken over by the main router. 7. Disable any firewall settings on the repeater router. This is usually in the "Security" section, depending on the make and model of your router. 8. Remove all in the "Port Forwarding" section. Some routers may refer to this as "Applications and Gaming," and it allows less-restricted access to the internet. 9. Set the operating mode switch to "Gateway" or "Switch" if applicable. Also, if the repeater router is a wireless router then disable the wireless access or set it to access point only. 10. Save the settings for each page, and reboot the router. When the router boots up, the changes will allow it to act as a simple repeater. 11. Now, place the repeater router in a new location and connect both routers with a Ethernet cable in each of the router's RJ45 LAN ports, and power it up both routers.
Posted on Mar 09, 2013
How can I connect?
Here is a link to your extender"http://cache-www.belkin.com/support/dl/MAN_F9K1111v1_8820-01079_RevA00_N300_RangeExtendr%20%282%29.pdf".
Mar 29, 2016 | Belkin N300 Dual-Band Wireless Range...
How do i install my belkin range extender?
restart the belkin range extender . and reset the settings i hope this works
Feb 03, 2015 | Belkin Components Belkin - Dual-band...
N300 Daul-Band Wi-FI Range Extender
call time warner cable and they can help you set it up for free.
Jun 11, 2014 | Belkin Components Belkin - F9K1111 -...
Ssid number
http://www.belkin.com/us/support-article?articleNum=7986
If they are charging that much for support I would return it anyway.
Get a Netgear router
Feb 07, 2018 | Belkin Play N600 Wireless Dual Band Router...
How do you change the channel
I think first you need to setup wi-fi and enter the SSID code. setting wi-fi in iphone and ipad are all most same process..
Here is a blog to setup iphone and ipad with wi-fi
http://blog.vtechsquad.com/2013/02/28/how-to-connect-your-iphone-to-wi-fi/
Apr 08, 2013 | Belkin Play N600 Wireless Dual Band Router...
I have misplaced the start up cd for my belkin play n600, i am wanting to change the user id and password, how can i do that with no start up cd?
Simply click here and you should be in the router's setup page. Just sign in using your existing user name and pass word.
Good Luck!
Jun 09, 2011 | Belkin Play N600 Wireless Dual Band Router...
Since I purchased a Belkin N600 my download speed is about 30k/bps. My ISP says it's the N600. Help!!!
If you are wirelessly connecting you need to use a wireless card that supports dual band.
and then changnig the settings on the wireless card helps.
if you are wired the issue is with the router settings.
Upgrade the firmware on the router
see belkins website on how to do this:
http://en-us-support.belkin.com/app/answers/detail/a_id/4497
Apr 07, 2011 | Belkin Play N600 Wireless Dual Band Router...
Computers & Internet Logo
David Payne
David Payne
