Question about Watts Series 007M1QT Double Check Valve 1"
Leak Why is my valve leaking from the top?
  • Watts Master
  • 15,628 Answers
Did it get exposed to sub freezing temp?
Posted on May 19, 2013
On top of automatic trasmision on 1987 there is a valve whith a hose where do that hose go please help
manifold vacum line may have a splitter or broken --with enigne running check for wistle-ing sound.
Apr 02, 2013 | Pontiac bolt. generator adjust....
I`m sorry i don't speak inglis but the car lose oil sometimes
check valve covers, oil pan gasket, and oil filter itself for leaking. have a good day !! you may also want to replace pcv valve if bad it will draw oil into throttle body and burn it up. and deposit oil in air cleaner. a pcv valve is used for crankcase pressure. if bad it can even cause a leak from a gasket.
Jan 13, 2011 | 1999 Isuzu Trooper
I have a Inglis by Whirlpool washer and it has been leaking water. The water runs forward toward the front of the machine. What do I need to fix this?
you can check the drain valve and hoses leading to water level sensor, Is there any leakage from there or not. drain valve or a water pump, the rubber seals are usually frequent leaking of water out of there.
Jul 12, 2010 | Washing Machines
Ice tray is full and fill tube continues to run.
Your water valve is bad or the ice maker itself is bad.
Start with the water valve. Im not familer with inglis but this should help. find your water supply line frome the wall to the refrigerator, this should lead you to the water valve. Unplug the machine and then unplug the wires that are conected to the water valve. now you can check to see if the water stoped. (( of course the water has to be turned back on if you shut it off ))
If you still have water coming in then the valve is stuck open and will need to be replaced.
If the water quit coming in the fill tube then the ice maker is bad and will need to be replaced.
Jan 12, 2010 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
I have an Inglis Soundblock II Dishwasher. The
It could be that the machine isn't filling properly with water- which could be a faulty or clogged water inlet valve. I'm not quite familiar with Inglis, but if you still have the manual, check and see if there is a way to adjust the amount of time the water valve stays open at the beginning of the cycle.
Or just add a liter or so of water at the beginning of a cycle and see if that helps- but make sure you add it after you hear the soap dispenser open- the beginning of most wash cycles is a quick rinse cycle, so any water you add will only be in there for a couple minutes before the machine drains and attempts to refill.
Jul 30, 2009 | Dishwashers
Inglis washer won't agitate
Washer/motor runs but wont agitate or spin...this is often a broken motor coupler. See how to take apart info.
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
Apr 01, 2009 | Washing Machines
Not sure if manifold is leaking
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Inglis gas dryer heat loss
It sounds like you have an intermittent gas valve. The ignitor is calling for heat however the gas valve doesnt want to open.
Make sure you turn off the gas and unplug before replacing.
Check for leaks after you reassemble.
Aug 21, 2008 | Whirlpool GGQ8831L Gas Dryer
Watts Series 007M1QT Double Check Valve 1"  Logo
Top Watts Plumbing Experts
Donni Steen
Tom Chichester
Are you a Watts Plumbing Expert? Answer questions, earn points and help others
