My home theater is didnt make clear bass and vibrate in loud .what solution for this
  • Audio Player... Master
  • 16,415 Answers
First make sure that nothing on the stand where that speaker is, is causing the vibration. IF that the not the case then shake the speaker to be sure nothing is loose inside. IF that is not the case, then make sure that you have a clean signal that is not clipping. If you can rule all those out then it is time to check the speaker to see if it has something wrong with it.
Posted on May 13, 2013
RCA RT2911 Home theater with AV receiver
You will have to ask the seller whether local repair, possibly at an authorized service facility, is acceptable.
Jan 04, 2014 | RCA Audio Players & Recorders
To much bass and vibration
-5 decibels can be quite loud. Either turn down the bass, volume or both. The bass could be vibrating some items on a shelf or any other place. If you continue to play it that loud, you will more than likely, damage the amp.
Dec 19, 2013 | Audio Players & Recorders
What is the measurment between the speakers in a 5.1 home theator for installation time
If you refer to the manual it will be explained. Generally, you have to compensate for two parameters that will vary with the distance and location each speaker will be relative to your listening position. Time delay and loudness.
If you don't compensate, each speaker's sounds from each will arrive at different times and your ear/brain will process the image unclearly and unconvincingly. An echo from behind you might arrive at the same tiome or before the primary event in the recording that created it, for example. The further a speaker is away, the quieter it will seem to be.
Then there's bass management. Using bass-deficient satellites requires the bass to be routed (managed) to a speaker that CAN handle it. This avoids speaker damage of the satellites and is, IMHO, a severe compromise in sound, or a victory of form over function for those who want minimum visibility from their sound systems. Contrary to the press regarding bass as being non-directional an explosion or other loud event from the rear of the room will not be convincing if the bass segment of it comes from in front.
May 27, 2011 | Sony HTSS360 Theater System
Any time we turn up the volume...it sounds like the system is going to fly away. What is wrong?
when u say fly away do u mean vibrates A LOT? A lot of different programmes require different sound settings. have u tried to adjust the bass levels to see if that helps?
Jul 12, 2009 | Philips Magnavox MRD510/17 Theater System
Can't turn bass down
I UNPLUGGED THE SUBWOOFER SO THAT JUST HAD THE TWO SPEAKERS PLAYING
Feb 21, 2009 | Samsung HT-Q100 System
Bose home theater
It may not have bass and treble controls, since most newer TV's now have these adjustments. Play around with your TV and see if you can find bass and treble adjustments from the remote.
Dec 24, 2008 | Bose Cinemate Digital Home Theater System...
Speakers
in normal setup no wall-mount speaker- you must put subwoofer in the floor and vibration is normal for low frequencey of subwoofer.
Apr 02, 2008 | Sony DAV-SC5 System
Subwoofer Bass Level Problems
What is your sub stood on? If it is on a piece of furniture then this could be the problem. Bass frequencies travel further than higher frequencies due to their longer wavelength and will also be transmitted through any solid objects the speaker is in contact with. The solution is to mount your sub on a piece of foam to provide some damping.
Also if your sub has a port (a hole) on the back or side this needs to have a good 3 or 4 inches clearance from nearby walls or panels.
Finally the speaker cone itself needs to have a clear path to push sound energy into the room, if this path is blocked by furniture (some people like to hide them under tables) then it may make that furniture vibrate.
Nov 26, 2007 | JBL SCS200.7 Home Cinema Package System
Systems shuts off if sound gets too loud.
Yes, i had this same problem. If it was too loud, at level 37+, any loud boom would shut down the subwoofer, subsequently shutting down the speakers. As such, I figured it might have been the 8 pin dim cable, but that wasn't it. What solved the problem was lowerin the BASS level. Not the level on the subwoofer, but the actual BASS level. I had it at +10 (the max) and it was too much for the system to handle. I don't think I ever had it like that so I'm assuming someone, maybe my daughters, moved the settings. But anyway, moving the bass level back down to either 0 or +3 at most maintains the "boom" effect of the subwoofer minus the shutting off of the system.
Oct 20, 2006 | JVC TH-C60 System
29 people viewed this question
 Grubhead
Grubhead
