Question about Roberts 10-46 Super Six 6" Jamb Saw
How can the blade with the spanner wrench - Roberts 10-46 Super Six 6" Jamb Saw
How do you lock the blade to change it on a skilsaw model 5500
generally you put a screwdriver thru the hole in the saw blade and rotate blade until it stops against something and then remove bolt that holds blade on.
Aug 10, 2015 | Skilsaw 5500 Circular Saws
I have a DW402 4.5'' angle grinder and do not know how to remove the blade to install a new one. Could someone help please?
On top of the head there is a button to press to lock the blade arbor. Press it down and turn the blade by hand until it locks in place. Then you need either a spanner wrench or nut wrench depending on which arbor nut you have. Grinders usually come with whichever wrench they need. Most grinders have an arbor nut with two or four holes and require a spanner wrench with two studs that fit into two of the holes to remove the arbor nut. Some have an arbor nut with a hex fitting, like a regular nut & bot setup, that the arbor wrench fits on. If you don't have the proper wrench sometimes you can get the arbor nut off with a pair of vice grips or pliers. You will want to turn the nut in the same direction as the blade spins when the grinder is on to remove it. When you put the new blade on, get the arbor nut hand tight, it is self tightening and will get tighter as you use the grinder.
Jul 18, 2012 | Dewalt Saws
How to change the blade.
UNPLUG tool, there are 2 wrenches usually on the side of table, remove the throat plate and place the spanner wrench on the flats of the spindle and the hex on the nut. WEAR gloves to help protect hands. The nut is standard threads. It also helps if you raise the blade. Let me know if you need more assistance.
Feb 10, 2012 | Dewalt DW745 10" Compact Job Site Table...
How do you get fan blade loose from water pump on 1998 f-150 4.2 liter
I seem to recall it is a left hand thread. They make tools for removal.
The wrench I think is a 32 mm open end looking wrench and the part to hold the water pump is a spanner wrench that is hooked shape for holding the bolts. Not sure on the size, could be a 35 mm nut on there...
The wrench for the fan blade
Spanner to grab and hold the water pump bolts.
Saw 1 person used a piece of flat stock steel, drill the holes at the same place as the bolts on the water pump, and install longer bolts through the flat stock to hold the water pump. He used a thread finder to get the correct size, and length of the factory bolts. They are a metric thread pitch, I cannot recall what they are at the moment ( M6x 0.75 is ringing a bell, but I can only be 50% sure about that )
The flat stock was used in place of the spanner to hold the water pump, and that person just used a 14" pipe wrench to grab the nut on the fan.
Aug 06, 2011 | 1998 Ford F150 Regular Cab
I bought a used stanley router and don't know how to take the old blade out. I like to change the blade.
There will be a button to push in which will lock the spindel. After locking the spindel you need to undo a nut using a wrench or spanner.
Apr 09, 2011 | Stanley Hand Tools
How do I replace the metal grinder?
Replacing the blade is simple. look for the lock button on top of the unit and use a tool or spanner wrench to loosen the blade.
Good luck
Joe
Feb 14, 2011 | Milwaukee 6140 6 4 1/2in. Sander/Grinder
I cant remove my blade! AS I try to loosen the nut, the nut on the other side of the blade also turns i.e. the blade runs free between the two. I cant seem to find a wrench/spanner to fit on the other nut
You may need to clamp the blade with a device such as a vise grip and leave the blade guide in place and undue the nut from below or bridge the space with a piece of flat steel to support the clamp or vise grip you use while turning the nut counter clockwise.
Nov 18, 2010 | Craftsman 10" Table Saw
Unable to loosen flange to remove disc on angle grinder
What sort of disc do you have on there at the mo? If its just an abrasive disc the easiest way to remove it is to use a hacksaw to cut the disc sideways so that you are actually sawing it out between the lock nut and rear flange. This will release the pressure on the nut. If it is a diamond blade and you have already snapped a pin spanner then I would suggest securing the blade in a vice and using a set of stiltsons/pipe wrench. While in the vice you could also try using a punch in the pin holes to shock it round a bit, then the pin spanner (and leverage if needed).
Nov 08, 2008 | Black & Decker 9"/230MM 5,000 Rpm Large...
2001 Dodge Ram 1500 Water Pump?
can we have a picture of fan/pump assembly?
if not, just fit the correct size of wrench on the bolts.
if you have adjustable wrench that could reach those bolts.
use socket wrenches, or close type wrench.
email me the picture. jyzomnix2@yahoo.com
Nov 06, 2008 | 2001 Dodge Ram Maxi
Panasonic FP-7113 Plain Paper Copier
Service Time imageunit can be removed with two screwsand remove tank before lifting out. You can remove drum and cleaning blade section yourself 4 screws. Two on the cleaning and two on the removablr pins on the side.Then remove blade with two screws and fit cleaning blade and drum and reinstall.
Service manual for service mode to remove spanner display F9 ??
Cheers Justin
Apr 30, 2008 | Office Equipment & Supplies
Roberts 10-46 Super Six 6" Jamb Saw Logo
Top Roberts Saws Experts
Tom Chichester
ray gallant
Are you a Roberts Saw Expert? Answer questions, earn points and help others
