Vulcan Ducted heater V3 20I
Heater wont turn on at all, so far I removed the power for 10 mins, reset the wall controller, last 4 faults are 4 5 8 15. I removed the cover and can see the Diag LED is green then the remaining 3 LED light up red for a second then turn off, repeats every minute. I have set the temp to the max 36C and cleaned the intake filter.
Soulvisitor
  • 1113 Answers
SOURCE: Error Msg: PAPER JAM in Brother MFC-8840D
one of the jam switchs is stuck down or paper concertina in fuser assy
Posted on Dec 28, 2007
hotuna
  • 288 Answers
SOURCE: Vulcan ducted heating not working
How many wires for the thermostat do you have? If you tell me I can help. The green flashing, instead of red, in my experience, means a thermostat problem.
Posted on Mar 05, 2008
  • 16 Answers
SOURCE: Failure to initialize
Your Main Logic Board failed to initialize. It needs to be replaced.
Posted on Apr 29, 2008
  • 521 Answers
SOURCE: Vulcan Quasar wall heater. The
hve u got ur device serviced recently
Posted on Aug 27, 2008
SOURCE: operating instructions for heater & remote control
visit this web site..this should be very similar to your remote.. http://www.abergas.co.nz/anytime/pdf_files/anytime48b23cc130447p314.pdf
Posted on May 28, 2009
F1/08 vulcan fault code
Hi Geoff,
Is your heater a ducted gas heater how old is it and what does the wall control look like.
May 10, 2014 | Heating & Cooling
I can't wake my Xerox Phaser 6280 from sleep mode.
The Electronics Module may be faulty but first, unplug the unit from the wall for 30 minutes. Plug it into the wall and see if it completes posting and messages display on screen. Console Panel ZNN (Control Panel) 848K19391
Control Panel (PL1.2.16)
1. Remove the Exit Out Chute (listed below)
Note
Be careful not to drop the Control Panel.
2. Disconnect the Control Panel connector P/J220.
3. Release the 6 hooks securing the Control Panel to the Front Cover
(PL1.2.9).
4. Remove the Control Panel.
P/J220
s6280-181
Exit Chute
Exit Out Chute (PL6.1.1)
1. Remove 2 screws (10 mm, flanged) securing the Exit Out Chute to the
Front Cover.
2. Remove the Exit Out Chute from the Front Cover.
s6280-217
Mar 17, 2014 | Xerox Phaser Office Equipment & Supplies
I refill the cartridge of my canon mp496 printer.I print images and everithing is ok but the ink lamps are orange .I don't know what to do ! Please ,help me !!
One of these reset methods should fix the problem
This is the procedure I used for an MP470. It is basically a modified version of that previously posted for the MP460.
1. Disconnect the power cable.
2. Hold down "On/Off" button.
3. Reconnect the power cable.
4. With the power button still down, press the "Stop/Reset" button twice.
5. Release the "On/Off" button.
6. The printer is now in "factory mode".
- wait until "idle" is displayed.
7. Press the right arrow button (next to the "OK" button) repeatedly until "Shipping Mode 3" is displayed.
8. Press the "OK" Button
9. Wait until "Without Cleaning" is displayed and then presss the "Stop/Reset" button once. (I pressed the ok button after Stop/Reset button on my MP470).
10. A test page should print.
11. Open the cover.
- the cartridges should position themselves at the far left - the cartridge removal location.
12. Disconnect the power cable.
13. Remove both cartridges.
14. Close the cover.
15. Reconnect the power cable.
16. Press the "On/Off" button once.
17. Wait until a "Replace Cartridges" message is displayed.
- insert cartridges.
18. Wait until the printer is operating in its normal mode. The display shows the normal start menu (ie: Copy).
The ink levels have been reset.
- check by going to printer>properties>maintenance>view printer status
this is what i had to do to get it to work with canon mp460
2. Hold down power button
4. With the power button still down, press twice the "Cancel/Stop" red button
5. Release the power button
6. The printer is now in factory mode...(wait about 30 seconds until it says "idle")
7. Press the down arrow (next to the "OK" button) until it says "Shipping Mode 1"
9. Now with it displaying "Without Cleaning" press the power button
11. Now open cover
12. Disconnect the power again
13. Take both cartridges out like normal
14. Close cover
15. Reconnect power cable
16. Press power button
17. Replace cartridges
MP-160 is different from MX300 so I tried my best with it...
The main solution is to reset the entire printer:
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The printes turns into a kind of factory mode...(wait for about 10 seconds, utils it says "Idle")
6. Press the ">" (next to the "OK" button) once."Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print..
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
Jul 01, 2011 | Office Equipment & Supplies
Canon MP270 keeps telling us the ink cartrige is out
If the cartridge is truely not low, use this reset to reset the level indicator.
11. Open the cover.
If the first method cannot be used, use this one:
Jun 29, 2011 | Canon Pixma MP270 All-in-One InkJet...
Replaced ink compatable cartridges in my cannon pixma 350 and now its telling me to replace them cause the ink is empty Help
This will reset your cartridges to full settings. I have found these resets to work on many Canon models. Try the top one first.
11. Open the cover.
11. Now open cover
14. Close cover
Mar 27, 2011 | Canon PIXMA MX350 Wireless All-in-One...
Canon np258 cant operate after refill
You may need to reset the ink counter. Try one of the following solutions.
THis is the procedure I used for an MP470. It is basically a modified version of that previously posted for the MP460.
11. Open the cover.
11. Now open cover
14. Close cover
Mar 27, 2011 | Canon Office Equipment & Supplies
How can i reset the Ink Level on Canon MP240
Here are three methods that have worked on Canon printers. Have no fear. None of these will cause damage if they do not reset the ink counter. Once reset you will have to monitor the cartridges by weight, as the system will always show them to be full.
The first is basically a modified version posted for the MP460.
9. Wait until "Without Cleaning" is displayed and then presss the "Stop/Reset" button once. (I pressed the ok button after Stop/Reset button on my MP470 to get the test sheet).
11. Open the cover.
11. Now open cover
14. Close cover
Mar 09, 2011 | Canon PIXMA MP240 All-In-One InkJet...
My jacuzzi has one wall timer that says set after 10 minutes marker."turn past ten then set time" There is one button on the far right corner that depresses. I am a clueless tenant. How do I...
There are a couple things you can try with your tub.. The 10 min timer is one they used on older tubs but, may still be used with yours. Turn timer all the way up. make sure tub is filled with enough water. some have little sensors that wont let it turn on with out enough water. The button may feel spongy because it is using air to turn on the pump switch so give it a good quick push.. also the last things to check will be to check the breaker box and be sure the breaker is on, turn the breaker off and on to test. also look around the room of the tub and look for gfi plugs and switches that may be tripped. they will look like the wall plugs for hair dryers but, may not have outlets on them. just reset all plugs you find in the rooms. Hope this helps you. ask more questions if you need to.
Feb 09, 2011 | Jacuzzi EE10 Luxury Bath Bellavista 5...
E-000003-0000
During printing, the main thermistor detects less than 120°C/248°F for 1
sec or more continuously.
Main cause:
The fixing film unit is faulty (main thermistor fault, thermal fuse blow, fix-
ing heater fault).
Or the power supply PCB is faulty.
Or the DC controller PCB is faulty.
Action1.
Malfunction
Turn off the power; wait for 10 min, and turn on the power. Is the problem
corrected?
YES:End.
2.Wiring
Is the wiring from the DC controller PCB to the fixing film unit normal?
NO:Correct the wiring.
3.Fixing film unit
Try replacing the fixing film unit.
Is the problem corrected?
YES:End.
4.Power supply PCB, DC controller PCB
Try replacing the power supply PCB. Is the problem corrected?
YES:End.
NO:Replace the DC controller PCB
Nov 07, 2009 | Canon imageCLASS D320 Digital Copier
Flashing lights
This is a copy of the post on your premium solution thread.
According to Singer guidelines , if there is only red blinking light, then there is an fault inside the machine, unless it reset disconnecting from power.
If there is an error code with format EM-01 - EM-09 tell me which error you get and I should find a fix.
Here is a complete user guide, check pages 90-92 for common errors.
If you have no error message, and light does not go out with power disconnect then it may be a faulty control board.
In this case I suggest doing a last attempt removing all threads, and reset design unplug from power 10/15 mins.
Let me know if you still have the problem.
Regards
Apr 12, 2008 | Singer CE-100 Futura Computerized Sewing...
Open Questions:
57 people viewed this question
k24674
