My Simpson SWF1076 does not complete a cycle
Is does not complete a cycle. I checked drain is good. Spin is good and rinse is good. Please tell me how to fix it? Thanks
  • 1527 Answers
SOURCE: spin cycle not activating with simpson eziset 950.
hello any spin problems could be down to the module circuit board all the best
shaun
Posted on Aug 02, 2009
  • 183 Answers
SOURCE: Amana Speed Queen (LWS34AW)
Probable gear box fault Regards Engineer
Posted on Jul 30, 2007
kevin000
  • 1847 Answers
SOURCE: Simpson Esprit 750 Washing Machine.
the control panel has gone bad needs replacement.
Posted on Jul 15, 2008
cbrown801
  • 3 Answers
SOURCE: washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Posted on Mar 30, 2009
  • 9 Answers
SOURCE: Beko washing machine will not complete wash cycle. it will not rinse anf then spin. You have to manually select spin and drain after wash is done. can the maching be reset in anyway.
your timer is most likely bad
Posted on Apr 20, 2009
Simpson 7.5kg EZISet750 machine is noisy (loud) whilst Rinse and drain spin - but clothes are well rinsed. your advise please.
Needs new bearings. Machine has to be dismantled to get at and replace the tub seal and two bearings.
Jan 10, 2018 | Simpson Washing Machines
Simpson ezi 950 9.5 will not empty, rinse, spin dry.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
Feb 20, 2014 | Washing Machines
My Simpson Eziset 550 will not drain after a (normal) wash cycle. When the drain hose is lowered to the floor drain water flows heavily from the hose (gravity). When the hose is returned to the sink d
Hi Erin just read your post,I have worked on these machines alot.Now I need you to manually drain the machine of all the water. Once drained i want you to select drain and spin cycle. Now push the start button,do you hear the pump working?If you do stop the machine and select normal cycle on small water level and push the start button.The machine will then fill.Once it stops filling stop the machine and select drain an spin cycle.Does the machine pump out? Now if you do not hear the pump, could be the pump is faulty or jammed.Does the water flow very fast when you lower it to the floor? Please reply with answers to these questions and I will try my best to help you.
Jan 25, 2014 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Hi, our simpson enduro 701 washing machine does not spin back and forward in the deep rinse cycle. but operates ok and spins in spin cycle. thankyou Tina.
Hi Tina just read your posting. From the information in your posting the machine fills, then when the machine is full of water the agitator moves clockwise then anticlockwise until it gets to the rinse cycle then drains the water ,then it fills for the rinse cycle but does not move the agitator in the rinse cycle.Then it drains and spins the clothes dry .Is this assessment of your posting correct.If it is not 100% correct please reply to tell me what the machine is doing or not doing.If it is correct then the problem with your machine is the control board.Is your model the electronic one with the push buttons?Looking forward to your reply.
Jun 26, 2010 | Washing Machines
My Simpson Riviera 966 wont complete wash cycle,whats wrong with it ?
1) timer- it stays wherever you leave it and does that action.
2) No fill -cold- for rinse
3) No pump out
4) Syphoning- where is your drain hose ?
5) Set to " no spin" drip dry" -- reset control
6) Lid switch - not engaging
Sep 12, 2009 | Dishwashers
Wont drain, wont empty, wont go onto rinse, drain or spin during
The filter on this machine is behind the flat at bottom right of machine. Tilt machine back before unscrewing to avoid spillage. If filter is clear get back to me and will explore other possibilities.
Nov 16, 2008 | Washing Machines
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
