Question about Dishwashers
MDB6600AWB How does the timer on this dishwasher work?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Dishwashers Master
  • 102,366 Answers
Kenmore elite dishwasher will not shut off
There is a timer inside the door, and if it is not working properly the timer can get stuck on a cycle and not end until you change the cycle yourself or turn it off. You will need to replace the timer for the dishwasher to work properley again
Apr 14, 2014 | Dishwashers
My dishwasher will not work
Hello
Investigate these four areas if your dishwasher is not working at all:
Power Supply;
Your dishwasher may not be receiving any power. It is somewhat difficult to check for power at the plug outlet because the plug for a dishwasher is usually behind the unit. You should make sure all the circuit breakers of your circuit breaker panel are in the correct positions, or check to make sure no fuses of your house fuse panel are blown.
Door Switch
A properly functioning door switch will shut your dishwasher off when the door is opened. A defective door switch may not allow your dishwasher to operate at all. Examine the door switch and test it. If it is inoperable, it will have to be replaced.
Cycle Selector Switch
It isn't very common, but it is still possible that your dishwasher's cycle selector switch has become defective. Test the switch to determine if it is the cause of your problem. Replace it with a new one if it is.
Timer Motor
Your dishwasher timer will not function if its motor is defective. And if your timer is not functioning properly, then the dishwasher itself will not function properly. Test your dishwasher's timer motor, and if it is broken, you can replace either the entire timer assembly or just the timer motor.
Aug 11, 2011 | Stoves 23 in. Q60DW Built-in Dishwasher
Wont turn on
I would suspect a faulty latch. They are a fairly simple dishwasher, with a timer, and some option push-buttons. The power goes through the latch before going to the timer, i suspect it's looking power before getting to the timer, as if the timer fails, typically some functions will still work
Apr 08, 2010 | Frigidaire 24 in. FDB750RC Slim-Line...
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
Feb 25, 2010 | Dishwashers
Dishwasher will not run. I have checked the circuit breaker and it seems fine. does the dishwasher have a reset button?
Hello there:
My dishwasher will not work at all. Investigate these four areas if your dishwasher is not working at all:
Power Supply
Door Switch
Timer Motor
Dec 25, 2009 | KitchenAid Dishwashers
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Maytag MDB6600AWB fills, starts to wash, stops, does this 3 time
you have one of 3 problems.
1. a bad door switch
2. a bad connection under the dishwasher
3. a bad control
Feb 28, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Loud noise during cycle MDB6600AWB Maytag Quiet Series II
look for odjects in the pump cutter ie glass plastic or the cutter is bent or a rushing sound could be motor bearings
Dec 24, 2008 | Maytag 24 in. MDB5600A Jetclean II...
DISHWASHER
this is a sign of a defective timer mechanism. replacing the timer will fix this issue. Replace the timer/control model asap.
Nov 03, 2008 | Roper 24 in. RUD3000 Built-in Dishwasher
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
Owen Barnes
