Question about Freezers
Frigidaire 297241400 My hi temp light is on how to turn it off. thanks
I lost my frigidaire upright freezer key model number 297241400 where can I find a replacement one
Hey Special lady, thank you for your post!
I understand that you have lost the key for your Frigidaire freezer. We recommend contacting your manufacturer directly to order any parts needed for your freezer. I hope this information is helpful. -Matt
Dec 02, 2015 | Frigidaire Freezers
Ok, upright freezer, frigidaire, read -12 after power outage but working ok..when I tried to reset temp to 0, light went off, freezer went off, front display reads 56..any ideas?
Thank you for your post, Cynthia!
Based off the information you have provided your Frigidaire freezer is not cooling properly and is now displaying the temperature of 56. It sounds like your freezer is not on, even though it has power the compressor is not turned on. I would suggest pressing either the down or up arrow three times within five seconds. That should power on your compressor and it should start cooling properly. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Feb 28, 2015 | Frigidaire Freezers
Doesnt seem like motor is rinning and display numbers not totally lit
is there power to the plug, plug a light or fan into the socket to be sure there is power. if no power check to see if there is a GFCI plug close by and also check circuit breaker
Jun 18, 2014 | Freezers
Door warning says hi temp, door adjar,light out
Good Afternoon Floyd,
I see that you are having trouble with your Frigidaire freezer, model# FFU17K1CW, stating "HI TEMP" and that the door ajar light is out. The model number that has been provided does not show that it has a "door ajar" light. What I recommend would be giving your appliance a hard reset, by either unplugging it or shutting the power off at the circuit breaker for 2-3 minutes. If you are still having trouble with the HI TEMP light showing, please respond back with your model number which is shown inside your refrigerator on either the right or left hand wall so I may better assist you. Hope this is helpful.
-Best Regards-
WP
Apr 07, 2014 | Frigidaire 16.7 cu. ft. / 473 liter...
The temp on my freezer is on normal and was working ok then just stopped and the red light is on turned up the temp to make it colder and the fast freeze but not working and everything is defrosting
Hi Denise, thank you for allowing me to assist you!
Did the unit previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will typically sound and the red light, if equipped, will also glow. First, deactivate the alarm to the unit by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the unit. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Best regards!
Sep 24, 2013 | Frigidaire 13.7 cu. ft. / 388 liter...
My freezer does.not freeze and the hi temp light is on.
Had the same problem, I unplugged freezer for two days, pluged back up, has worked fine since.
Jul 11, 2012 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Upright freezer orange and red light on but green light off can you advise? Frigidaire freezer.
Draw fan has failed, temp unreachable over the past cycle of 24hrs, turn your unit off for 24hrs and defrost it, restart and should work fine for a few days, if so, replace fan and defrost element only. Call service tech for this unless you are clued in on this work, not that costly.
Aug 28, 2011 | Frigidaire Freezers
Freezers Logo
247 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
