Question about Genius G-PEN F350 Ultra slim tablet. Exquisite slim pad design (31100001100)
Paint shop pro 12
I recently upgraded to Vista from XP. My tablet worked just fine with PSP when I had XP. Now it only works in Paint Tool SAI, Fire Alpaca, etc. Not in PSP 12. Any suggestions? Do I need to go back to a lower PSP to get it to work?
  • psp_tara
    psp_tara May 08, 2013
    Thank you! I figured out my tablet is too old to work with PSP X2, so I went back to X and it works perfectly now :D
    New Friend:
I don't know much about tablets but, software drivers may need to be upgraded to be compatible with Vista. (or) check for software upgrades to match the operating system.
Posted on May 08, 2013
2 Suggested Answers
SOURCE: G-Pen Genius 450 doesnt work in cs4,xp
I have two cricut machines that the start button will not turn the machine on. What can I do?
Posted on Apr 05, 2010
Paint tool sai doesnt recognize the tablet
i have the same problem maybe update the driver
Mar 28, 2010 | Computers & Internet
Paint shop pro tools in psp 9 and 8 question
How much memory do you have on board?? Paint Shop, Photoshop all have high memory requirements to function properly. Freezing up is usually a sign of not enough memory. I would say 2 gigs memory should be about the minimum now. 3-4 would be better.
Oct 13, 2009 | Computers & Internet
Paint shop pro x2 ultimate upgrade wont rum on Vista Home
I havent actually solved the problem but I did get PaingShopProUltimate to run by starting up in "SAFE MODE" I tried it out and everything seemed to work ok. but of course this is not very convenient.
Sep 05, 2009 | Corel Paint Shop Pro Photo X2 Full Version...
Paint Shop Pro will not respond AT ALL!
not a hardware or major software prob, but see that if any other software have the same prob...?
you will have to scan your pc through a best virus cleaner or remover. then will have to install a fresh O.S, and then install Paint Shop Pro X2, it will run faster then before..
take care
shafky
Jun 20, 2009 | Corel Paint Shop Pro® X Full Version for...
PSP 9 won't work in Windows Vista
Try installing and running it in compatability mode for windows XP.
Dec 29, 2008 | Computers & Internet
PSP X2 Ultimate Not Responding
Hi, I got a fabulous response from Corel and it fixed my same problem! Here is what they sent me. The first step did not work alone, but may have been necessary for the second step to work properly. Good luck!
We are working on a permanent fix for this issue. Use the following workaround to allow launching of Paint Shop Pro Photo versions X1 or X2:
Delete or rename the Paint Shop Pro Photo XI database file: ImageDB.db.
Database file locations
On Windows XP: C:\Documents and Settings\<username>\Application Data\Corel On Windows Vista: C:\Users\<username>/AppData/Roaming/Corel Here are instructions to easily delete the ImageDB.db file.
  1. On XP systems, Go to Start | Run. On Vista systems, Click on Start button and then highlight the "Start Search" field.
  2. Type %appdata% and click Ok (or push Enter on keyboard on Vista systems).
  3. Double-click on the Corel folder.
  4. Delete* the ImageDB.db file and then close this window.
You should now be able to successfully run Paint Shop Pro Photo. *NOTE: if you receive a message that the file cannot be deleted or is in use, Restart the computer, then immediately try deleting the file. It should delete fine after a restart.
If Paint Shop Pro Photo X2 still hangs or is slow responding, try the following: Do the following to delete the Paint Shop Pro Photo X2 Database files. The program will recreate the files upon next launch. First Close Paint Shop Pro Photo X2 if is it running.
  1. Go to Start | Run, Type %temp% and click Ok. (on Vista, click Start button, then highlight Start Search. Type %temp% and then push enter on keyboard)
  2. On the Windows® Explorer Tool bar, Click the Up Folder button. The Up Folder button looks like a folder with a green arrow pointing up. If you don’t see it, Click View | Go to | Up one level. (On Vista, click Organize | Layout | Menu bar. Once displayed, go to View | Go to | Up one level).
  3. Double click on the Application data folder. NOTE: The Application Data folder is a hidden folder. Make sure you have enabled viewing of Hidden files and folders to see this folder. We have included instructions* below for enabling this view.
  4. Double-click on the Corel folder.
  5. Delete all content in the Corel Folder and then close this window
  6. Try running Paint Shop Pro Photo X2 again and note how it functions.
* To enable viewing hidden files and folders do the following:
  1. Go to Tools | Folder Options.
  2. Click on View tab.
  3. In the large white area marked Advanced settings, check the "Show Hidden Files and folders" radio button.
  4. Click OK to accept this setting. You should now see the Application data folder as described above.
Dec 02, 2008 | Corel Paint Shop Pro Photo X2 Full Version...
On psp vista not opening
if is paint shop pro? Paint shop pro 7? According to the publisher it is vista compatible. You can try setting the exe to run in XP compatibility mode.
Locate the exe file in explorer, right click on the file name, click properties, select the compatibility tab and check the box “Run this program in XP SP2 compatibility mode.
write me a line.
Sergio
Mar 11, 2008 | Sony ACY-BR81/OB
Genius G-PEN F350 Ultra slim tablet. Exquisite slim pad design (31100001100) Logo
156 people viewed this question
Top Genius Computers & Internet Experts
micky dee
Alun Cox
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
