Question about Philips Zenia Voice Cordless Phone
Phone- philips CD135
Hello! I have a problem with phone philips CD135. on screen is still "searching". I can't calling.wahat happend? thanks
2 Suggested Answers
  • 71 Answers
SOURCE: Philips CD135 Twin Cordless Phone
Disassembly the battery pack, and power on after that.
Posted on Jan 21, 2009
  • 71 Answers
SOURCE: cannot make or receive calls from phone screen flashing searching
Put it back on the charger for a while. If that doesn't work power cycle the base, and then put it back on the charger for a little while.
Posted on May 15, 2009
0 characters
1 Points
After power cut the phone will not connect,it just keeps reading searching in the screen no dialing tone,the line appears ok as a normal plug in phone works ok can you help many thanks. I cannot find the...
I think if you switch off by holding down the 'exit' key for about 10 sec, then switch on again (same key) it might recover. Mine did, but seems to need the process repeating from time to time. When switched on again it still has to search for about 5 minutes.
Jan 07, 2010 | Vtech Digital Cordless Telephone VT-2568
My philips cd135 cordless does not ring when recieving in coming calls what is the solution.
Your phone is prob on Ringer Off mode. Press menu and then scroll down to Personal Set, press menu and Handset Tone will appear on display, press menu and Ring Volume will appear on display, press menu and then scroll to select volume, low, med or high. Do not select ringer off.
Jan 02, 2010 | GE Cordless Phone & Answering Machine...
CD135 will not stop searching
Clicked and hold down the ringer buton, followed by registering the phone.
Aug 23, 2009 | Philips 2252 Twin Cordless Phone
Just bought a Philips Digital Phone Model No.CD135. Is THERE NO BACK LIGHT on this phone as it is difficult to read screen even in daylight. I would not have purchased it otherwise. If not do you have a...
I contacted Philips by phone and the told me that there is no back light on Model No CD135. I think that is stupid as you can have a back light on the cheapest mobile phone. All handset phones should have a light so it can be used in bad light.
Sep 26, 2008 | Phones
Philips model cd135
Hi there Fred
Here are links to user guides for your unit. Good luck, thanks for using FixYa
Mar 15, 2008 | Phones
CD135 phone answerphone function has stopped working
Hello, I have the opposite problem. I'm trying stop the answering machine so I can use the one that comes default with my phone line.
If anyone can help, please email me on
Dec 28, 2007 | Philips Zenia Voice Cordless Phone
Oct 28, 2007 | Philips DECT 2252S Cordless Phone
Philips Zenia Voice Cordless Phone Logo
331 people viewed this question
Top Philips Phones Experts
Are you a Philips Phone Expert? Answer questions, earn points and help others
