Question about Garden
Craftsman 917.273505 16.5 hp honda engine not firing
Craftsman 26 hp Kohler engine 54
to be honest the enigne ahas a control that the left side must fire and run before the right starts to fire it sounds to me like you have a fuel issue possibly the carb. is gummed up and dirty.
Jul 27, 2012 | Craftsman Kohler Courage 26 hp 54" Garden...
17.5 intek engine will not start, engine has fire and gas. craftsman LT2000 42 in deck lown mower
Is the flwheel key ok? Or you may problem like me. Pull
valve cover and see if both pushrods move.
Jul 19, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 16hp Honda engine on my Craftsman riding mower and it will not fire. I have checked the plugs, carburator, switch on seat. no luck!
just trying to grasp the situation here: I am assuming that it will not fire means it is cranking but not starting.... pull the plugs and have them laying where you can see if they are sparking, if they are then the coil is good, this means that the gas is not getting to the plugs, you will need to disconnect the gas line on the fuel filter, gas should come out of the hose, if not then the line or the bottom of the tank is clogged, if it does then hook it back up and disconnect the line after the filter, check for gas, if none the filter is clogged, if yes then disconnect the gas line from the carburetor, same as before. Hope this helps Tim if the situation is different then post and if I am still here I will answer
Apr 17, 2011 | Craftsman 175 hp 42" Lawn Tractor (CA) ()
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
Craftsman 16 HP Electric start 41" mower - on a overhead valve briggs and stratton two stroke engine the hollow push rod bent. We pulled the head and everything seemed in working order. The replacement...
On any pushrod engine you have to make sure that the timing is correct or nearly correct when first firing it up, if you had the cam in the wrong position the pushrod had no place to go when the cam lobe came around=bend push rod.
Sep 24, 2010 | Garden
My craftsman 42in rider quits after about 30 to 45 minutes. The carb solenoid is good and the gas cap is venting ok. I have to wait about 20 to 30 minutes before it will start again. What should I check...
try the coil,does it get fire to the sparkplug after it quits and what color is the spark? blue spark is good, red is weak fire, and not enough to fire the engine up.
Jun 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
LT2000 has no fire. Starter engages, fuel on plug but not firing
check all the wires for ground even a small nick in the wires will keep the engine from firing up, then check the ignition switch for wear..good luck
Mar 27, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What engines will fit craftsman dyt 4000 (18.5 blew w/ 290 hours)
Hi there
The only thing you have to do is have the size (diameter) and lenght (from cranckcase to end of shaft) of the shaft you have on your b&s and just go to your local Honda dealer , give them your shaft size and they should be able to give you all the options for a brand new motor . I really believe you can get a Honda 20hp model GXV620 or a 24hp model GXV670 that will replace your B & S motor .
Hope this help .
Sep 01, 2009 | Garden
Engine wont fire has spark gas not getting thruogh
pour alittle bit in carb & if it starts then it could be the fuel pump or the fuel lines
Jul 19, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
