I have a Mastergrip Router in my workshop.
Howdo you adjust this router for the cutter togo up and down.
  • 7,627 Answers
Is it wired or wireless? Does it connect to the Internet?
Posted on May 03, 2013
What hp router is best to make cabinet raised doors
I used to use a Ryobi 2.5 hp and it worked fine but if you are concerned go higher hp. It's probably more important that the router is a variable speed model. The bigger the size of cutter required for raised panel doors the more torque and revs are produced. You need to ensure starting on slowest speed and adjust up to speed required. Speed should be based on size of cutter and to me is set by sound( a nice hum, not screaming) and vibration( NO VIBRATION)! The cut needs to be done in several passes, maintaining constant feed speed,( don't burn your expensive cutter) allowing cutter and machine to do work maintaining the hum and no vibration. And of course set your guards etc!! If this is on going work for you perhaps look into a spindle moulder with attachment to take router cutters
Cheers Capt Mark
May 10, 2014 | Makita RF1101 Electric Routers, Fixed &...
What is the router bit depth for a shop fox dovetail jig
Usually with router dovetail jigs one has to find the depth by trial and error as the fitting is very critical and any discrepancy doubles as the cut is on both sides of the joint.
I think you may have to play this game.
You will need offcuts of the same size as the finished work that are long enough to go into the clamps of the device and then just fit the joint by trial and error. It is the way we do it in the trade. Sharpening of the cutter and different thicknesses of wood all affect the fit of the joint.
If my memory serves me raising the cutter up toward the machine makes the joint looser and lowering it makes it tighter. If I was in my workshop with the machine in my hand I would remember for sure
May 31, 2010 | Tools & Hardware - Others
Router bits
Mike, The fit is just a little more snug than you expect. The collet is springy, and will expand to fit your bits, even if they were oversize (which is very unlikely). Put on a leather glove and just push the shank of the bit into the collet. Do not try to file down the shank of your router bits, you will only make them run eccentric. You don't need to remove the collet. Just loosen the locking nut about a half turn after it is easy to turn. Good luck. Thanks for using FixYa. Al Kupchella
Apr 20, 2010 | Freud FT2000E 3 Router
How do i hook up one router to get a signal from another one
You can set up a sort of siamese-twinning of routers to share a WAN connection through the use of what is called WDS. Information on how this works can be found here:http://www.keenansystems.com/newug/bblog/?postid=17.However, WDS slows down your internet connection by half, works only over relatively short distances, and doesn't work between different brands and models of router.A better general solution to setting up a point-to-point connection (example: to extend your wireless network from your house to an outbuilding workshop) uses a bridge instead of a second router. A router is an access point, while a bridge is like a more powerful version of the wireless card in your computer. Engenius makes relatively inexpensive indoor/outdoor bridge units (such as the model 1650). Since they are directional, you can point them directly at the house and extend your network over very long distances with very little power.
Oct 27, 2009 | Linksys Wireless-G WRT54G Router
Ive got a kenzo router and the router bits do not fit . ive got quarter inche cutters and when the collet is done up tight the cuters are still not tight. its not a half inch router as ive measured it. any...
Your router bits must have a 6mm shaft, whereas your router with the collet closes down on a 1/4" or 6.4mm shaft. You will need to get a metric collet for your router spindle, or get a new set of 1/4" bits
Sep 28, 2009 | Freud FT2000E 3 Router
Help setting up my home network.
If your printer only has a usb cord than u will want to hook it up to one of your pc's and set it up as a shared network printer. If it has an ethernet port you can hook it up directly to a router or switch.
PS to set your printer as shared goto ControlPanel > Printers > Right click on your printer > Click Sharing... Set it up to have a name you'll reconize and you should be good togo.
May 23, 2009 | D-Link AirPlus Xtreme® G DI-624 Wireless...
How do i find my network key or create one for security?
Login to your router and check to see if wireless security is setup:
Use Internet Explorer and type 192.168.2.1 in the address bar.
Login using the password you created when you setup the router.
You can view the wireless security settings and retrieve the key.
If security is not setup you can enable it....directions here:
http://www.usr.com/support/5461/5461-ug/wireless.html
Mar 11, 2009 | U.S. Robotics MAXg USR5461 (738168036790)...
The plunge lock "slips" when the router is used in a table
You can try to adjust the lever that moves the plunge and see if that helps, but a plunge router isn't made for upside use. If you have the option and use the router upside down often, you may want to get a fixed base.
Jan 01, 2009 | Bosch Plunge Router
Wifi problems
You need the wireless connection to be blue tooth enabled.
Here's a good read on how bluetooth works-
http://electronics.howstuffworks.com/bluetooth.htm
Jan 06, 2008 | Palm LifeDrive Handheld
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
