Question about Vivitar Vivicam 5388 Digital Camera
Camera lens wont open
I have a vivitar 5388 and when i turn on my camera the automatic lens cover doesnt open... what is wrong with it. how can i fix it? please help!
  • Anonymous Jan 02, 2008
    I have an 8400 with the same problem. By accident, the chrome ring
    (around the lens) popped off. My lens worked after that! I replaced the
    chrome ring and it still works.
  • Anonymous Mar 25, 2009
    I HAVE A VIVITAR5388 THE LENS WON'T NOT OPEN COMPLETELY TO TAKE PHOTOS AND LENS WON'T CLOSE EITHER
Where can i find athe driver instalation for free for the vivican 5388 for my xp computer i have a problem with my cd rom and can't install it with it....pleassse!!!!
Posted on Mar 04, 2008
I have an 8400 with the same problem. By accident, the chrome ring (around the lens) popped off. My lens worked after that! I replaced the chrome ring and it still works.
Posted on Jan 02, 2008
SOURCE:
How to pop the battery of a vivitar 882 hd camcorder
It's not sealed just, fortunately. It's just difficult to open.
The door should be on the same side of the camera as the lens.
Turn the camera upside down, and using both thumbs, push against the flat area, about 2 cm (or, about an inch) below the lens. Push from the lens toward the Vivitar name. It may not move the first time, but it should come loose after a few attempts.
This is for the Vivitar DVR 882HD. If you have a Vivitar 882 (without the DVR), it should be the same instructions, but the door to the battery case might be on the other side...I don't know if it is or not, because I don't have that version. In either case, though, just keep trying, and it should open for you.
Nov 29, 2013 | Vivitar Video Cameras
Camera Vivitar 5388 manual says takes max 1G memory chip. Does that mean anything bigger doesn't work at all. Rob.
It means anything bigger won't work in the ViviCam 5388. They may work in other cameras, depending on the camera.
Jul 19, 2010 | Vivitar Vivicam 5388 Digital Camera
Why doesnt my lens come out?? I just bought it and its not working
If it is still under warranty, return it.
This is more than likely a lens problem, and is not the easiest thing to fix.
Apr 18, 2010 | Vivitar Vivicam 5388 Digital Camera
My Vivitar Vivicam 5388 lens will not move or shutter operate
Hi cda_graham
Usually it is a flat battery which causes this problem. You have to put in new battery once again and try.
Good luck
luciana44
Oct 06, 2009 | Vivitar Cameras
The lens will not come out
Hi there.
Face the camera towards the floor and firmly tap the back of the camera while turning it on, this should hopefully free the lens so it can open, make sure that the batteries are fully charged or at least new.
Good luck and thamks for using FixYa!!
May 24, 2009 | Vivitar Vivicam 5388 Digital Camera
Lens wont go back in
Probably grit in the mechanism. That happened to my Olympus, but after frequent re-trying eventually the problem cured itself. It is unlikely that a repair will be economic as the price of digital cameras is so low.
Apr 01, 2008 | Vivitar Vivicam 5388 Digital Camera
Automatic lens cover is stuck
The lens mechanism is damaged.The only known solution is to get a replacement lens unit and replace it
Aug 08, 2007 | Vivitar Vivicam 5388 Digital Camera
Vivitar Vivicam 5388 Digital Camera Logo
221 people viewed this question
Top Vivitar Cameras Experts
Ekse
Damen Wong
Damen Wong
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
