Question about Corel Roxio Easy VHS to DVD with USB 2.0 TV/Video Capture Device - Complete
Roxio usb 2861 driver
I need to download the drivers for my Roxio 2861 usb
I have had Roxio Creator 2011 for 3 years and have been able to copy many of my vinyl Lp's onto the system. However I have not used it for about 8 months and when I tried to 'record' some more LP's I...
If you didn't install the driver of the USB record player, it won't pick up all but the basic functions of the unit. try upgrading the driver of the LP usb player.
Nov 18, 2013 | Roxio Creator 2011
Windows 7 says I need a digital driver
Hi David,
I have worked for the tech support for this product before, and if you are using a 64bit computer, you will need to go to the ROXIO website to download the drivers for this particular product because normally this is only for 32 bit users.
Regards,
meir
Oct 27, 2011 | Roxio Easy CD & DVD Burning
Roxio in windows 7 won't support ac3 audio
Please co to roxio.com and download updated drivers for windows 7
Jan 09, 2011 | Roxio Easy Media Creator 10 Suite
Is there a patch available to make my Photosuite7 run on Windows 7 ?
Hello henn..... What you are seeking is a driver. Go to the Roxio website where you will see a link to their free downloadable drivers. Select the driver for photosuite 7 and windows 7. Download it and then run it. Joe
Thanks for choosing Fixya!
Dec 22, 2010 | Roxio PhotoSuite 7 Platinum for PC
Roxio Creator Classic 6.2.0.110; after dragging doc into data field and clicking the burn icon, message appears: "There are no supported recorders available. Make sure that your recorder is powered on...
well i would go out to the roxio web page and select either tech support or look for drivers and downloads, this is the only way you can be assured you have the most up to date drivers. sometimes the cd's are shipped with outdated drivers. follow the prompts it may delete the old drivers or just update them. then power your machine off wait 12 seconds and then reboot and try again. it is frustratring i know but you need to reboot to update your machine
Jun 01, 2010 | Roxio Easy Media Creator 7.5 for PC
I am running Vista and trying to istall easy vhs to dvd into my computor It has accepted all but says usb 2861 device has failed and to check with you to solve this problem Bruce e mail
If you are using more than one USB devices at a time - especially on the same USB physical port (through a hub, say), then there may be insufficient power for the device. If you unplug the device and plug it back in again (preferably on a physical port to itself), if the device is working ok, windows should pick it up and search/ask you for appropriate drivers or manufacturers disk.
Btw give the device at least 10 seconds after unplugging it before plugging it back in again.
Allan
Dec 09, 2009 | Roxio Easy VHS to DVD for PC
This version of windows does not support this version of Roxio DLA. .this product which was created by Roxio Inc. has been blocked from running because it might keep my computer from starting in the...
Check the system requirements on the side of the software box and see if it will run and what version it will run on. My guess is that the roxio software is older and will not work on your version of the OS.
rmatheson@wowway.com
Oct 01, 2008 | Computers & Internet
Incompatible Driver(s)
I would uninstall Photosuite.
I don't think that Roxio is supporting that program anymore. I have version 7.0 and it does some goofy things in Windows XP they never fixed in the slide show mode.
Jun 10, 2008 | Roxio PHOTOSUITE 5 PLATINUM CD for PC
Roxio media creator 7
goto this site and reinstall it for free http://www.brothersoft.com/downloads/roxio-easy-media-creator-7.html or goto cnet.com for the driver.
Feb 02, 2008 | Roxio Easy Media Creator 7
Corel Roxio Easy VHS to DVD with USB 2.0 TV/Video Capture Device - Complete Logo
18 people viewed this question
Top Corel Video Cameras Experts
Are you a Corel Video Camera Expert? Answer questions, earn points and help others
