Question about AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor / Cen
Can you buy just the on high and low switch the pumpl
  • 717 Answers
You cannot purchase just the high/low parts for motors. There are wires going from the controls to the high side and the low side of the motor.
Rod
US Parts Center
Posted on May 14, 2013
The high beams on my 1981 Toyota diesel pick do not work. When I switch to high beam it's darkness. Ideas?
Buy dual beam light bulbs. When a single bulb is installed or the dual bulb got the high beams burned. It wont work.. Also check if the switch of the low-high beam is working properly. To make it easy. Buy a dual bulb and try it. Good luck
Dec 27, 2015 | Toyota Cars & Trucks
2002 hyundai santa fe fuel filter location
Fuel filter is inside fuel tank. It is an integral part of the fuel pump. It can be replaced but ONLY by very qualified mechanics. Fire explosion risk is too high.
May 16, 2014 | 2002 Hyundai Santa Fe
Went to warm up my car and switched my low beams off. when I got ready to drive off switched low beams back on and wouldn't come on. High beams work but no lows. already changed bulbs
Your dimmer switch is bad (lever used to flip between hi/low beams) they're only plastic and they go bad. Before you change check fuses, buy I highly suspect dimmer switch.
Feb 21, 2011 | Chevrolet TrailBlazer Cars & Trucks
2003 Kia Sedona replaced low beam bulbs checked fuses still won't work high beams n fog lights work can u help
IF THERE IS NO POWER AT EITHER LOW BEAM LIGHT SOCKET & YOU ARE SURE ABOUT THE FUSES, SWAP THE WORKING HIGH BEAM BULBS WITH THE LOW. IF THAT DOESN'T DO IT YOU NEED TO REPAIR OR REPLACE THE BEAM SELECT SWITCH, { DIMMER SWITCH } KNOWN AS THE COMBINATION SWITCH, UNDER THE STEERING WHEEL. CAN USUALLY BE DONE WITHOUT PULLING THE STEERING WHEEL. TEST BEFORE BUYING, MAY BE COSTLY. GOOD LUCK , DR.VOLT
Jan 21, 2011 | 2003 Kia Sedona
My heat in my cutlass supreme turns off when i switch the switch to high but works on low
Three possibilities. AND all you can do yourself!
1. Hi/Low Blower Relay. However these usually fail on low and works on High.
2. Blower Control Switch.
3. Blower Motor Resistor.
If you do not have one: buy a Voltmeter, available for $6 at Walmart.
If you do not have one: buy a Haynes or Chilton Manual at most auto parts stores for $20-$25 dollars. I say this because you are obviously going to keep this vehicle. It will have most of the information with pictures to assist you.
Quickest way to determine which one?
Finding the Resistor....Go on line to autozone.com or advanceauto.com. Answer the questions on year, make, model and engine and go to "look up parts" or click on "Replacement Parts".
Pull up the Hi/Low Blower Relay.
Know you know what you are looking for.
This Relay is located near the Blower Motor.
The System goes: Switches, Relay and/or Resistor, Motor.
Unplug the electrical connection from the Switches going to the Relay.
Turn the engine on. Turn the Selector to Low and using a voltmeter, check for voltage coming from the Switch. Turn to High and rechaeck for voltage coming fom the Switch. No voltage on High? The Switch is bad.
Do the same with the Relay to Resistor connection and or Relay/Resistor to Motor connection. Check the Low and the High voltages.
Let me know if this helped or if you have additional information or questions. Feel free to contact me at FixYa.com!
Feb 11, 2010 | 1986 Oldsmobile Cutlass Supreme
Low Beam headlights don't work. High Beam work fine and diriving lights work as well.
hi from uk provided you have checked bulbs are ok? then this fault may be the relay for the low /dipped beam has gone faulty if you check h/book you may find location of low beam relay there is relay for high and one for low beams if you find both relays ? try switching? this will confirm relay fault if you then have low beam but no high ? b4 you buy new relay other than tis the other possible fault may be the actual di/high beam stick control ?
Nov 09, 2009 | 1998 GMC Sierra
Was low on freeon add some but it still dose not get cold .and yes the pumpl is running whats up ?03-10-09 22:42
test with a gauge to make sure it's in safe range.
Is the a/c clutch cycling on and off more than 4 times/minute? If yes, you ares till low.
Do not overcharge or you could damage compressor.
Mar 11, 2009 | 2004 Ford Freestar
Bad blower switch?
no is not the switch that neded to be replace but the resistor device mownted in the blower compartiment for cooling it you can buy it at the dealer part store or get a use one at the wreking yard and save $$$
Dec 18, 2008 | 1999 Dodge Durango
AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor  / Cen Logo
29 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
